Mysportwish 1st Gear December 9, 2011 Share December 9, 2011 hello anyone has this very small tiny bug crawling on walls & ceiling? you have to go near to see them. anyone know how to get rid of them? thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Rainbowbiatch 6th Gear December 9, 2011 Share December 9, 2011 more info please... or take pic and post it up here... Link to post Share on other sites More sharing options...
Jamesc Hypersonic December 9, 2011 Share December 9, 2011 No such problem. Most of us here are very clean. Link to post Share on other sites More sharing options...
Mysportwish 1st Gear December 9, 2011 Author Share December 9, 2011 seeing is believing.... you hv to go close to the wall 10cm to see it.. it is very tiny and i dun hv a duper camera to snap it... i hv some friends having this as well.. even if you search internet, ppl in US also hv similar feedback... my intent is to ask if anyone hv a solution to this issue thanks. Link to post Share on other sites More sharing options...
Rainbowbiatch 6th Gear December 9, 2011 Share December 9, 2011 seeing is believing.... you hv to go close to the wall 10cm to see it.. it is very tiny and i dun hv a duper camera to snap it... i hv some friends having this as well.. even if you search internet, ppl in US also hv similar feedback... my intent is to ask if anyone hv a solution to this issue thanks. u need to kw the root of the problem b4 any solution. is the area moist/wet? have u cleared it off b4 and it reoccurs?if ans is no, have u tried just wiping them off and see if they come back? the info u have is too little dude.. Link to post Share on other sites More sharing options...
Topspin 2nd Gear December 9, 2011 Share December 9, 2011 That wingless little bug (about 2mm long) feeds on mold growing in the wall/ceiling. Remove the mold and the bug problem goes away. Need to ask why is the mold growing on your wall in the first place. Condensation due to next door switching on aircon? My own way of controlling it is to apply borax solution on the wall/ceiling to control mold and keeping the room well ventilated even if there no one in the room. Where possible, switch on the aircon once a while. The bug is quite harmless, but the mold is very harmful!! It can cause asthma to both adults and children if you breathe in the mold spores daily. 1 Link to post Share on other sites More sharing options...
Bicolor 5th Gear December 9, 2011 Share December 9, 2011 Can't remember what they were called - will have to look it up when I have the time, but they are quite harmless. Since they feed on mould or microscopic fungi the best way to get rid of them is to ventilate the area well and keep the humidity down (not always possible in Singapore). You can spray the area thoroughly with a normal household insecticide but this is a temporary solution at best. Alternatively just wipe them away every time you see them. Link to post Share on other sites More sharing options...
Csnewbie 1st Gear December 9, 2011 Share December 9, 2011 hello anyone has this very small tiny bug crawling on walls & ceiling? you have to go near to see them. anyone know how to get rid of them? thanks. only your walls are white then u can see rite? i spray baygon regularly. yucks Link to post Share on other sites More sharing options...
Tuna_seng Clutched December 9, 2011 Share December 9, 2011 hello anyone has this very small tiny bug crawling on walls & ceiling? you have to go near to see them. anyone know how to get rid of them? thanks. They are sent by the ISD. Bigger ones are sent by CIA. You may want to try Baygon. Link to post Share on other sites More sharing options...
Csnewbie 1st Gear December 9, 2011 Share December 9, 2011 They are sent by the ISD. Bigger ones are sent by CIA. You may want to try Baygon. come to inquire abt which positions....... Link to post Share on other sites More sharing options...
Happily1986 5th Gear December 9, 2011 Share December 9, 2011 I believe those buggers are Mould mites (Tyrophagus putrescentiae) You gotta take action quick cos once they run out of mould to feed on, they will start targetting anything that is starchy. You need to eliminate the source of the dampness that is causing the mould to recurr, failing which you will be literally stuck in a vicious cycle as the buggers will come back sooner or later. If your room is inherently dark and devoid of natural lighting, i suggest you ventilate the room on a regular basis. Leave a small gap in your window. I don't think the humidity problem in your room is so drastic till you have to fall back on a home class dehumidifier. You must get rid of the mould as soon as possible. Breathing in mould spores on a daily basis can trigger asthma and other health concerns. Here is how to deal with it 1.) Sometimes your wall or your ceiling can be semi porous due to the plaster being subpar. Slather on a healthy layer of plaster sealant and choose paint that is specifically mould resistant. Paint 2.) Spray borax solution or wipe the affected area about once a day. You need to import Borax solution by ordering online as it is not easily available locally. 3.) These buggers are resistant to common pathogenic compounds found in your run of the mill insecticides so you have to specifically find pyrethrin based insecticides. Go look for them in Home Fix. Link to post Share on other sites More sharing options...
Bicolor 5th Gear December 9, 2011 Share December 9, 2011 Just remembered the name, they are known as Psocids or also "booklice". They are most probably not mould mites, which are found in other environments and can be pests. The common ones on walls in flats don't do much harm apart from being rather offputting to many people. http://en.wikipedia.org/wiki/Tyrophagus_putrescentiae Similar-looking insects might also be springtails, if they jump upon being disturbed. But I believe the booklice are the ones in question 99% of the time whenever tiny crawling bugs on walls are mentioned. http://en.wikipedia.org/wiki/Springtail Link to post Share on other sites More sharing options...
Happily1986 5th Gear December 9, 2011 Share December 9, 2011 Just remembered the name, they are known as Psocids or also "booklice". They are most probably not mould mites, which are found in other environments and can be pests. The common ones on walls in flats don't do much harm apart from being rather offputting to many people. http://en.wikipedia.org/wiki/Tyrophagus_putrescentiae Similar-looking insects might also be springtails, if they jump upon being disturbed. But I believe the booklice are the ones in question 99% of the time whenever tiny crawling bugs on walls are mentioned. http://en.wikipedia.org/wiki/Springtail i see. i helped solved a friend's problem and i thought that was the case here as in the culprits are the same ones. Link to post Share on other sites More sharing options...
Icedbs Turbocharged December 9, 2011 Share December 9, 2011 guys...how about tiny little bugs.....(like wat describe here), but it has wings and can fly.....? They seems to be invading my bathroom.....everytime I spray, kill, they will come back again. Link to post Share on other sites More sharing options...
Csnewbie 1st Gear December 9, 2011 Share December 9, 2011 so still need pyrethrin or not? i half way into enquiring Link to post Share on other sites More sharing options...
Csnewbie 1st Gear December 9, 2011 Share December 9, 2011 guys...how about tiny little bugs.....(like wat describe here), but it has wings and can fly.....? They seems to be invading my bathroom.....everytime I spray, kill, they will come back again. since you cant sterilize the whole world, solution is to spray regularly [laugh] Link to post Share on other sites More sharing options...
Bicolor 5th Gear December 9, 2011 Share December 9, 2011 guys...how about tiny little bugs.....(like wat describe here), but it has wings and can fly.....? They seems to be invading my bathroom.....everytime I spray, kill, they will come back again. Are they shaped a little like moths? Thus resembling tiny moths? If so, these are moth flies, which are the most common pests in bathrooms. They feed on the lining of scum inside the pipes and drainage systems. Spraying has limited effect as you are only treating the symptoms, not the cause. A good temporary solution is simply to clean the insides of all accessible pipes and pour boiling water in. Pest control companies will be able to use specific chemicals and methods to treat the insides of the drainage and thus eradicate them, but because they are common and found everywhere they will often come back after some time. Link to post Share on other sites More sharing options...
Bluepica 4th Gear December 9, 2011 Share December 9, 2011 How about those flat oval shape like got mouth opening at both ends that sticks on the wall? It's grey in color ↡ Advertisement Link to post Share on other sites More sharing options...
Mold/Fungus on the ceiling
Ceiling fan
Ceiling fan
Buying Ceiling fan and lighting from JB
Ceiling Fan in Car
Ceiling Fan in Car
Recommendations for wall paintings
Help: ceiling n wall cracks are leaking water
Ceiling water seepage marks
