Spare tire. do u remove or leave in boot?
Ivansyl
  On 12/5/2011 at 4:06 AM, Cowpeh said:
my car comes with 18" tires.. but the spare tire from manufacturer comes with 16".. If i ever have to use it, will it poses a problem?
is not meant for u to drive long distance or even speed, will not be a problem for u to drive to nearby workshop
The suspension will sort of balance the car out
I don't know if most of you had a tyre puncture, that means deflated through nail or nipple leak, or tyre bust like when you hit the tyre hard on a sharp or hard object which leaves a tear in the tyre.
The 1st scenario is a simple case of removing the mail, patching it up or replacing the defective nipple and pumping it back up.
The 2nd scenarion is more serious and really need an immediate solition.
So far I have only met with the 1st scenario. I don't carry a spare in my car since 1990 but carry along a foot pump. Instead of changing tyres I pump up the deflated tyre within 2 min and off I go to the nearest tyre shop.
once i kena a wooden block at AYE, and one of my front right rims wrecked....as i am using BBK, so the 15" spare cannot put in front, so got to swap the rear to front, then put the spare at the rear...
Edited by Rncw
  On 12/5/2011 at 6:05 AM, Cateye said:
Even if i keep the spare, i cant use cos i have BBK front and Enlarge rear disk..... :wub:
Similar reasons for me to remove my spare tyre and save same weight. My spare tyre is drum rims and cant fit after I upsized my rotors.
  On 12/3/2011 at 10:32 AM, Ivansyl said:
as above. wanted to know if the majority of drivers leave their spare tire in their boot or leave it at home.
My Car dun come with spare tire
  On 12/5/2012 at 8:10 AM, Deckbuild said:
Definitely good to leave it, but to some that don't know or don't bother to learn the basic of changing spares, have or not doesn't matter....
jialat... i dunno how to change [:/]
btw... i just upgraded from my stock rim (14") to aftermarket rim (15"), the spare in my boot is stock (14") how ah... if really need to swop? can use mah or i need to replace that spare too. [;)]
Internal Moderator
have you all seen before....
subwoofer that can fit in your spare tyre?
for saving space?
haha damn cool.
saw it yesterday at Turf City.
If you put one 14" tyre, your car would not be levelled - your coffee / coke etc would spill [:p]
Joking aside, you could have gone for one more 15", so that it would be complete set when you travel around, esspecially up north!
Don't worry about that, at the most the car will sink at one side, when you get your original tyre done, just change it back.
Must learn the basic seriously, if driving in sg, we can still depend on EMAS vehicle, in msia, we are on our own.
Found one example above, different cars comes with different jack but they are more or less the same, break down triangle is very important as well. Always carry a touch in your car.
