ismailmiller 1st Gear December 19, 2020 Share December 19, 2020 My IS250 Just had some ticking sound coming from the Dashboard area. Sound gets louder when moving on roads with some bumps and uneven roads. The issue was due to the airbag clips got loose and needs adjustment. ↡ Advertisement Link to post Share on other sites More sharing options...
east41st 3rd Gear January 2, 2021 Share January 2, 2021 Something "interesting" happened today. It was cold today. When I started the car it shows outside temp of 22 deg and my aircon is set at 24 deg. As i started driving i realise the aircon vents at driver side started to emit warm air. This was a pleasing relief to my frozen hands, but unusual as i could not find any temp controls for this or override it. The passenger side air vent however continues to emit cold air through out. This went on until i reached my destination. The next time I started the car everything is back to normal again. Anyone any thoughts on this? Or is this a sign of impending issue with the aircon. Link to post Share on other sites More sharing options...
RH1667 Hypersonic January 2, 2021 Share January 2, 2021 1 hour ago, east41st said: Something "interesting" happened today. It was cold today. When I started the car it shows outside temp of 22 deg and my aircon is set at 24 deg. As i started driving i realise the aircon vents at driver side started to emit warm air. This was a pleasing relief to my frozen hands, but unusual as i could not find any temp controls for this or override it. The passenger side air vent however continues to emit cold air through out. This went on until i reached my destination. The next time I started the car everything is back to normal again. Anyone any thoughts on this? Or is this a sign of impending issue with the aircon. I have the same experience, not sure if it air con problem, or just the car trying to meet the temperature set 😅. 1 Link to post Share on other sites More sharing options...
east41st 3rd Gear January 3, 2021 Share January 3, 2021 15 hours ago, RH1667 said: I have the same experience, not sure if it air con problem, or just the car trying to meet the temperature set 😅. Funny it happens only to driver's side and not passenger side. I was alone. Link to post Share on other sites More sharing options...
RH1667 Hypersonic January 3, 2021 Share January 3, 2021 17 minutes ago, east41st said: Funny it happens only to driver's side and not passenger side. I was alone. 😊 I did not check if only driver side , because felt comfortable inside 😁 1 Link to post Share on other sites More sharing options...
Toeknee_33 Turbocharged January 3, 2021 Share January 3, 2021 17 hours ago, east41st said: Something "interesting" happened today. It was cold today. When I started the car it shows outside temp of 22 deg and my aircon is set at 24 deg. As i started driving i realise the aircon vents at driver side started to emit warm air. This was a pleasing relief to my frozen hands, but unusual as i could not find any temp controls for this or override it. The passenger side air vent however continues to emit cold air through out. This went on until i reached my destination. The next time I started the car everything is back to normal again. Anyone any thoughts on this? Or is this a sign of impending issue with the aircon. How many zones is your climate control? Did you set different temp for different zones? Link to post Share on other sites More sharing options...
east41st 3rd Gear January 3, 2021 Share January 3, 2021 2 hours ago, Toeknee_33 said: How many zones is your climate control? Did you set different temp for different zones? I only see a 'DUAL' mode on the menu, not sure about different zones. Link to post Share on other sites More sharing options...
t0y0ta Supercharged January 3, 2021 Share January 3, 2021 (edited) On 1/2/2021 at 8:23 PM, east41st said: Something "interesting" happened today. It was cold today. When I started the car it shows outside temp of 22 deg and my aircon is set at 24 deg. As i started driving i realise the aircon vents at driver side started to emit warm air. This was a pleasing relief to my frozen hands, but unusual as i could not find any temp controls for this or override it. The passenger side air vent however continues to emit cold air through out. This went on until i reached my destination. The next time I started the car everything is back to normal again. Anyone any thoughts on this? Or is this a sign of impending issue with the aircon. Why so coincidental?? Me also same issue. Stop engine and re-start 3 times no improvement. immediately went to my workshop. After couple of restarts, back to normal. No error code in OBD. But workshop uncle had seen similar before. Diagnose intermittent stuck servo motor (also called aircon blend servo on internet). It is accessed from panel in driver footwell. Replaced for a 2xx damage and everything back to normal. I went back to research and yes this is common issue (Toyota/Lexus) and exact resolution. Edited January 3, 2021 by t0y0ta 2 Link to post Share on other sites More sharing options...
east41st 3rd Gear January 4, 2021 Share January 4, 2021 11 hours ago, t0y0ta said: Why so coincidental?? Me also same issue. Stop engine and re-start 3 times no improvement. immediately went to my workshop. After couple of restarts, back to normal. No error code in OBD. But workshop uncle had seen similar before. Diagnose intermittent stuck servo motor (also called aircon blend servo on internet). It is accessed from panel in driver footwell. Replaced for a 2xx damage and everything back to normal. I went back to research and yes this is common issue (Toyota/Lexus) and exact resolution. Hmm next servicing at Borneo I will ask them to investigate. Link to post Share on other sites More sharing options...
t0y0ta Supercharged January 4, 2021 Share January 4, 2021 2 hours ago, east41st said: Hmm next servicing at Borneo I will ask them to investigate. Yours still under warranty? Actually happened to me actually once before after servicing @BM maybe 2 years ago. It was working again after 2 engine restart, and then never surfaced again until this Saturday. So it may not re-occur frequently. Best you can bang table and get it changed FOC anyway. 1 Link to post Share on other sites More sharing options...
ChongLiu 1st Gear January 4, 2021 Share January 4, 2021 On 1/2/2021 at 8:23 PM, east41st said: Something "interesting" happened today. It was cold today. When I started the car it shows outside temp of 22 deg and my aircon is set at 24 deg. As i started driving i realise the aircon vents at driver side started to emit warm air. This was a pleasing relief to my frozen hands, but unusual as i could not find any temp controls for this or override it. The passenger side air vent however continues to emit cold air through out. This went on until i reached my destination. The next time I started the car everything is back to normal again. Anyone any thoughts on this? Or is this a sign of impending issue with the aircon. exact same thing happened to me last Sat. Warm air blew to driver side, and cold air to passenger side, after a restart everything back to normal again. Seem to be a very wide spread occurence with Lexus? LOL... 1 Link to post Share on other sites More sharing options...
t0y0ta Supercharged January 4, 2021 Share January 4, 2021 1 hour ago, ChongLiu said: exact same thing happened to me last Sat. Warm air blew to driver side, and cold air to passenger side, after a restart everything back to normal again. Seem to be a very wide spread occurence with Lexus? LOL... Maybe because of the sudden low temp? Mine also occured on Sat morn when the outside temp (22deg) was lower than my normal set temp (24deg) on my dual-zone. Link to post Share on other sites More sharing options...
Altis77 Clutched January 4, 2021 Share January 4, 2021 Mine happened this morning too. Driver side blew hot air but passenger/rear side are ok. Couldn’t recover after restart. Finally manage to recover after workshop guy reset the program setting. Spent $30. Still need to monitor whether it will reoccur. 1 Link to post Share on other sites More sharing options...
t0y0ta Supercharged January 4, 2021 Share January 4, 2021 49 minutes ago, Altis77 said: Mine happened this morning too. Driver side blew hot air but passenger/rear side are ok. Couldn’t recover after restart. Finally manage to recover after workshop guy reset the program setting. Spent $30. Still need to monitor whether it will reoccur. Wow so many happening at same time period.... Link to post Share on other sites More sharing options...
inlinesix Hypersonic January 4, 2021 Share January 4, 2021 7 minutes ago, t0y0ta said: Wow so many happening at same time period.... Could it be 24deg set? Why not set at 20 deg and see? Link to post Share on other sites More sharing options...
Koizee 1st Gear January 5, 2021 Share January 5, 2021 (edited) Hi, I recently encountered the car air con selection button in the infotainment system was auto off (resulting in blowing hot air )whenever I restarted the car in the past 2 days, even when I set the temperature to 20 degree it was still blowing hot air. I had to manually on the air con instead, there is no air con selection button on the dashboard but only in the infotainment climate setting, so far it happened about twice few months back and I have feedback to BM about it, they have no idea of the actual clause but they say it could be due to the additional wiring I have added (leg room light and HUD)? Anyway from what I could remember, it only happens when the weather is cold, so far it doesnt happen when the weather is hot. Edited January 5, 2021 by Koizee Added additional line Link to post Share on other sites More sharing options...
Volvobrick Supersonic January 5, 2021 Share January 5, 2021 1 hour ago, Koizee said: Hi, I recently encountered the car air con selection button in the infotainment system was auto off (resulting in blowing hot air )whenever I restarted the car in the past 2 days, even when I set the temperature to 20 degree it was still blowing hot air. I had to manually on the air con instead, there is no air con selection button on the dashboard but only in the infotainment climate setting, so far it happened about twice few months back and I have feedback to BM about it, they have no idea of the actual clause but they say it could be due to the additional wiring I have added (leg room light and HUD)? Anyway from what I could remember, it only happens when the weather is cold, so far it doesnt happen when the weather is hot. Why not set to 18 or LO to test? Won't harm the car. 1 Link to post Share on other sites More sharing options...
east41st 3rd Gear January 5, 2021 Share January 5, 2021 20 hours ago, t0y0ta said: Yours still under warranty? Actually happened to me actually once before after servicing @BM maybe 2 years ago. It was working again after 2 engine restart, and then never surfaced again until this Saturday. So it may not re-occur frequently. Best you can bang table and get it changed FOC anyway. Yes still under warranty. Upcoming servicing will ask them, if it does not occur in the mean time. ↡ Advertisement Link to post Share on other sites More sharing options...
MAZDA 6
MAZDA 6
2026 Volvo ES90
2026 Volvo ES90
[Spyshots] 2026 2nd Generation Mercedes Benz GLB
Mercedes Owners Thread
