Roberttan 5th Gear December 21, 2019 Share December 21, 2019 (edited) On 12/19/2019 at 3:55 PM, Kb27 said: Where to find tyres that can use for 10 years ? So no need to change tyres at all, only after renew COE. Expand all Passengers or Commercial tires are not developed to use for 10 years If Yes ,commercially tire companies most will closed shop. Most Premium brands Passenger Tires are Developed for Safety than Durability , unlike Commercial TIres Durability first. Most Premium Brands Passengers tires are Made generally LAst around 40,000 to 50,000 KM.(except those High Performance racing tires.) if One is so low Mileage the 40,000 km can last for him 10 years is possible, But we are advised not to use a tire more than 5 or 6 years (that doesn't meant after the 5 or 6 years tire will burst ) Edited December 21, 2019 by Roberttan ↡ Advertisement Link to post Share on other sites More sharing options...
Ceecookie 5th Gear December 21, 2019 Share December 21, 2019 On 12/19/2019 at 3:55 PM, Kb27 said: Where to find tyres that can use for 10 years ? So no need to change tyres at all, only after renew COE. Expand Those u see at bumper boats plying pulau ubin lo 😂 2 Link to post Share on other sites More sharing options...
riverbill Neutral Newbie April 26, 2020 Share April 26, 2020 Never heard that anyone changed their tires after 10 years, It depends on your drive, I usually changed my tires after 80k and I think it's too much and there's a risk I take. Link to post Share on other sites More sharing options...
Jamesc Hypersonic April 26, 2020 Share April 26, 2020 I change my batt every 2.5 years. I heard batts only last 1 to 1.5 years depending on use. I think I get 2.5 years because I use a battery desulfator. It sends a charge to break the sulfate crystals on the lead plates for about 20 seconds and then stops for 2 minutes and then sends the charge for another 20 seconds. I connect it only when I drive so that it doesn't drain the battery but when its switched on it uses less electricity than the car's own clock. This keeps the battery in good condition and it lasts for 2.5 years. 2 Link to post Share on other sites More sharing options...
Beregond Supersonic April 27, 2020 Share April 27, 2020 talking about changing tyres n battery . better pray no WS kenna, imagine if they announce WS must close, how many cars will be queing up to replace tyres n battery😁😁 Link to post Share on other sites More sharing options...
Roberttan 5th Gear April 27, 2020 Share April 27, 2020 On 4/26/2020 at 4:23 PM, Jamesc said: I change my batt every 2.5 years. I heard batts only last 1 to 1.5 years depending on use. I think I get 2.5 years because I use a battery desulfator. It sends a charge to break the sulfate crystals on the lead plates for about 20 seconds and then stops for 2 minutes and then sends the charge for another 20 seconds. I connect it only when I drive so that it doesn't drain the battery but when its switched on it uses less electricity than the car's own clock. This keeps the battery in good condition and it lasts for 2.5 years. Expand can share more about the product and cost and how to do the connection ? thanks thanks 1 Link to post Share on other sites More sharing options...
Kklim Supercharged April 27, 2020 Share April 27, 2020 (edited) On 12/19/2019 at 3:55 PM, Kb27 said: Where to find tyres that can use for 10 years ? So no need to change tyres at all, only after renew COE. Expand My made-in-Malaysia Dunlops maybe can. 4 years liao flower still very nice 😆 I rotate and balance them frequently. Waiting for CCB to be over so I can go in and get another set. Edited April 27, 2020 by Kklim Link to post Share on other sites More sharing options...
Jamesc Hypersonic April 27, 2020 Share April 27, 2020 (edited) On 4/27/2020 at 3:04 AM, Roberttan said: can share more about the product and cost and how to do the connection ? thanks thanks Expand The one I got was made by someone in his home in Singapore. It cost $60 more than 10 years ago. But now there are so many and its only $20. Just need to connect one side to positive and one side to negative. The trick is to keep cleaning your batt from when its new and not try to clean it when its 2 years old and dead. To revive a 2 year old dead batter need a bigger revive machine that cost $1 - $2k. Features: Batteries often fail because "sulfates" slowly develop and cover the battery plates. This sulfating process also weakens the electrolyte and this combined with the gradual coating of the plates slowly and almost imperceptibly reduces the battery's ability to receive, store and then deliver power. This sulfating process gradually impairs battery function and causes a capacity loss until the battery can no longer perform the desired task and so the battery is deemed to have "failed". However using an Auto Pulse Battery Desulfator can reverse the process by dissolving the sulfates, cleaning the plates and restoring the electrolyte strength so improving a battery's life and capacity for an extended period. The Auto Pulse Battery Desulfator/ Rejuvenator/ Recovery unit uses no external power and generates a high-frequency pulse to dissolve a batteries "sulfates". FUNCTION The High-frequency Peak Pulse delivers an electronically controlled pulse to the battery causing crystalline sulfates to dissolve back into the electrolyte and so restoring battery function and electrolyte strength regaining the batteries ability to receive charging current and deliver discharge current. ADVANCED TECHNOLOGY Many desulfator products use an old technology inductor design to generate the pulse to desulfate a battery. This old technology creates a harsh induct or peak that can be damaging to the battery plates. Utilising our new capacity pulsing method a “soft” peak is generated so dissolving sulfates without damaging the battery plates. Old technology also requires a large inductor so necessitating a physically large desulfator device whereas using our advanced technology design the Auto Pulse Desulfator device is very compact yet provides BIG performance. NEW CYCLIC PULSING FUNCTION In a similar manner to a Pulse battery charger (charge – rest –charge – rest etc) a cyclic desulfating pulse function (pulse – rest – pulse – rest etc) optimizes a batteries recovery process. This method of desulfation has been implemented in the new Auto Pulse Desulfator AUTO PULSE DESULFATOR BENEFITS Increases Battery Power Extends Battery Life Battery Charge Faster Longer Discharge Prevents Sulfate Build-up Reduces Evaporation COMPETITIVE ADVANTAGES Fully Automatic voltage selection. 12V 24V 36V and 48V New Cyclic pulse generation method for improved capacity recovery "Soft" Peak Pulsing Auto cutoff function to prevent over discharge of battery User Configurable override for manual voltage selection: MANUAL VOLTAGE SELECTION If the battery voltage is very low the automatic voltage selection may fail to set the correct voltage. In this instance it is possible to manually set the desired operating voltage. By pressing the voltage select button. The LED screen will first display the working voltage and if you want to then alter the working voltage setting just press the key again and the unit will change to next value. After setting the desired voltage the display will switch off to conserve battery power. Edited April 27, 2020 by Jamesc 2 Link to post Share on other sites More sharing options...
Jamesc Hypersonic April 27, 2020 Share April 27, 2020 (edited) I also think some batteries last longer than others. I only use Made In Japan batteries. https://www.sgcarmart.com/news/events_features.php?AID=2953 GS Yuasa actively adopts high quality materials in the production of the ECO-R battery. Made with high grade resin moulded together with advanced technology for use in the new battery, the point on environmental friendliness is thus emphasised. By using high grade resin in the battery case, up to 12 percent of CO2 emissions can be reduced during production, compared to employing other materials, therefore helping consumers to save the environment. Edited April 27, 2020 by Jamesc 3 Link to post Share on other sites More sharing options...
kingkyzo Neutral Newbie April 27, 2020 Share April 27, 2020 I never change my ride tires for 1 year. When is the best time to change it? Any recommendation on tires brand? Link to post Share on other sites More sharing options...
SiLangKia Supersonic April 27, 2020 Share April 27, 2020 On 4/27/2020 at 3:07 PM, kingkyzo said: I never change my ride tires for 1 year. When is the best time to change it? Any recommendation on tires brand? Expand If it's a new car, 1 year shld be fine based on normal usage (less than 20k km a year) recommendation depends on what you prioritise, performance or comfort or a semi good balance of both, what car is this for? 3 Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged May 2, 2020 Share May 2, 2020 On 4/27/2020 at 4:09 AM, Jamesc said: I also think some batteries last longer than others. I only use Made In Japan batteries. https://www.sgcarmart.com/news/events_features.php?AID=2953 GS Yuasa actively adopts high quality materials in the production of the ECO-R battery. Made with high grade resin moulded together with advanced technology for use in the new battery, the point on environmental friendliness is thus emphasised. By using high grade resin in the battery case, up to 12 percent of CO2 emissions can be reduced during production, compared to employing other materials, therefore helping consumers to save the environment. Expand I second this. I just changed to my third Yuasa EcoR last week. First yuasa battery I used on previous car, and battery ok for more than 3 years until I sold the car (car was 7.5 years when I sold) On current car, next Yuasa ecoR battery was used when the stock battery died after 14 month. Yuasa worked without any issues for 2 years but I change it out to a Korea Koba battery bec there is a battery promotion combo with Nanopulser (although test shows Yuasa is still around 60% and I could just add water) the koba obviously dying last week after 1.5 years so I went to get another Yuasa Eco R. And it’s surprisingly not that much more expensive than made in India amaron for a made in Japan Yuasa 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic May 2, 2020 Share May 2, 2020 On 4/27/2020 at 3:07 PM, kingkyzo said: I never change my ride tires for 1 year. When is the best time to change it? Any recommendation on tires brand? Expand Change every 3.3 or 2.5 years based on usage. When you scrap your car you know why. Link to post Share on other sites More sharing options...
Wildfaye29 Turbocharged May 3, 2020 Share May 3, 2020 @Jamesc @Chucky2007 where do u get the Yuasa EcoR from? im looking for a 44B19. Link to post Share on other sites More sharing options...
Jamesc Hypersonic May 3, 2020 Share May 3, 2020 On 5/3/2020 at 5:12 AM, Wildfaye29 said: @Jamesc @Chucky2007 where do u get the Yuasa EcoR from? im looking for a 44B19. Expand https://www.sgcarmart.com/directory/listing.php?BRSR=0&COM=gs+yuasa+authorised+dealer&RPG=15 SgCarMart is the best. 2 Link to post Share on other sites More sharing options...
Inlinefour Twincharged May 3, 2020 Share May 3, 2020 On 5/2/2020 at 8:55 AM, Jamesc said: Change every 3.3 or 2.5 years based on usage. When you scrap your car you know why. Expand I got new tyres and battery before deregistering and the dealer so damn happy 1 Link to post Share on other sites More sharing options...
Johnnylim 5th Gear May 3, 2020 Share May 3, 2020 On 5/2/2020 at 7:25 AM, Chucky2007 said: I second this. I just changed to my third Yuasa EcoR last week. First yuasa battery I used on previous car, and battery ok for more than 3 years until I sold the car (car was 7.5 years when I sold) On current car, next Yuasa ecoR battery was used when the stock battery died after 14 month. Yuasa worked without any issues for 2 years but I change it out to a Korea Koba battery bec there is a battery promotion combo with Nanopulser (although test shows Yuasa is still around 60% and I could just add water) the koba obviously dying last week after 1.5 years so I went to get another Yuasa Eco R. And it’s surprisingly not that much more expensive than made in India amaron for a made in Japan Yuasa Expand Yuasa battery need top up water? How often need to top-up? Thanks. Link to post Share on other sites More sharing options...
Roberttan 5th Gear May 5, 2020 Share May 5, 2020 On 5/3/2020 at 12:52 PM, Johnnylim said: Yuasa battery need top up water? How often need to top-up? Thanks. Expand SORRY TO hijack my understanding Yuasa battery is mostly maintenance Free MF ,you may still see the Opening cover which allow to open and add distilled water (not battery water or Acid) in actual fact they are not required to add anything under normal operating conditions. just my Sharing got Battery Origin can easily find the Print on every battery. ↡ Advertisement Link to post Share on other sites More sharing options...
Battery for Honda Vezel
My EV journey to the i4
Change Disc Rotors
Change Disc Rotors
