Achtung 6th Gear January 20, 2012 Share January 20, 2012 was it a 'HAPPY' dyno? On 1/20/2012 at 5:16 AM, Leoquarius said: Dyno-ed my SLK 200 after tuning from Dave. Horsepower up by about 30 torque up by about 40Nm. Maybe I'm plain lucky that his tuning works? Maybe bros might want to go dyno yr car before commenting? Dave also did mention something abt going full throttle for a while after tuning which I find it rather amusing.. ↡ Advertisement Link to post Share on other sites More sharing options...
Scherer Neutral Newbie November 26, 2012 Share November 26, 2012 KWP2000 Online Shopping Security High Quality, Low Price & Excellent Service Color : silvery white Weight : 700g Dimension:230*160*80mm Regular Price: $53.99 Buy it Now : $45.59 Supported Vehicle: Suitable for almost all cars Product Description Function: 1.Read and analys your current ECU software. B.Upgrad the ECU software with a re-mapped file. C.Repair ECUs with software problems or corruption. How do you use the KWP2000 PLUS? 1.You need a computer. Installing KWP2000 Plus software. 2.Connect USB cable to your PC; 3.Connect to your car via standard 16-pin OBD2 connector; 4.Supports high speed ECU flashing 5.Led indications for USB-power Car-power/rx/tx 6.Support KWP2000+ software and other KWP/ ISO software How to Read and Write data? Read and Write 1.Click read button to read out the original data 2.Click write button and select the file you want to write 3.Save the file to you HD, edit or forward it -Follow the instructions on screen 4.switch off ignition and wait 10 seconds Package list: 6 pc x Connect cables 1 pc x KWP2000+ Main unit 1 pc x Driver CD ↡ Advertisement Link to post Share on other sites More sharing options...
NTUC issues…and problems
Encounters with tyre shop
