Lorinser 1st Gear October 27, 2011 Share October 27, 2011 Hello all, Does anyone know where to repair a Focal 4.75 car amplifier? Keep blowing the fuses. AudioEdge no longer the local agent. Any input is appreciated. Thanks !!! ↡ Advertisement Link to post Share on other sites More sharing options...
Jasles6912 Clutched October 27, 2011 Share October 27, 2011 Try this add.. dunno if they still doing Focal ONG RADIO 10 UBI CRESENT , 04-25 UBI TECHPARK 408564 SINGAPORE 65 / 674 13 930 [email protected] www.ongradio.com Link to post Share on other sites More sharing options...
WendyT Neutral Newbie November 2, 2011 Share November 2, 2011 I guess the add that Jasles shared is a nice place to bring your stuff for repair..:) Anyway have you guys heard that Mazda's new Takeri concept car will be unveiled at the Tokyo Auto Show late next month? The vehicle will come out a new regenerative braking system. The brakes will power the car's electrical functions and thereby conserve fuel. Source of article: New Takeri concept car hints at next generation Mazda6 Link to post Share on other sites More sharing options...
Rexi1212 Neutral Newbie November 5, 2011 Share November 5, 2011 Any one know where to repair car amplifier.Please help me out. Link to post Share on other sites More sharing options...
Nc35 Neutral Newbie November 5, 2011 Share November 5, 2011 you can try audioDr. 96996444. look for ken. Link to post Share on other sites More sharing options...
Lorinser 1st Gear November 5, 2011 Author Share November 5, 2011 you can try audioDr. 96996444. look for ken. Thanks for the info.. I did managed to reach him.. Hope that he can fix Link to post Share on other sites More sharing options...
paulshim Neutral Newbie January 12, 2015 Share January 12, 2015 you can try audioDr. 96996444. look for ken. Me driving an 8 yr old sunny. Amplifier is interminttent ... sometimes working and sometime not... when it works...all of a sudden it gives out a loud blast and stop working. After i disloged the front panel for a day or 2..it works again. Any advise on how much to cost to repair or replace it. I just need a radio...not crazy about sound system in car. Hope not to spend too much cos car left less than 2 years to drive. Any good idea? Pls help, Thank you Link to post Share on other sites More sharing options...
Simpleonly 5th Gear January 16, 2015 Share January 16, 2015 Bro, If you only need radio and not particular on sound system in the car. Do you need the amplifier in the 1st place? You can just remove the amp and drive(connect) the speaker using you head unit directly. earlier and not much cost involve..... Me driving an 8 yr old sunny. Amplifier is interminttent ... sometimes working and sometime not... when it works...all of a sudden it gives out a loud blast and stop working. After i disloged the front panel for a day or 2..it works again. Any advise on how much to cost to repair or replace it. I just need a radio...not crazy about sound system in car. Hope not to spend too much cos car left less than 2 years to drive. Any good idea? Pls help, Thank you 1 Link to post Share on other sites More sharing options...
paulshim Neutral Newbie January 16, 2015 Share January 16, 2015 Bro, If you only need radio and not particular on sound system in the car. Do you need the amplifier in the 1st place? You can just remove the amp and drive(connect) the speaker using you head unit directly. earlier and not much cost involve..... Oh, I dont really need an amplifier as long as i can still listen to radio for traffic news. But I do not know where are the amp wiring located in the sunny. Anyway you got a very good idea, i didnt know our radio set can direct drive the speaker. Thanks alot Link to post Share on other sites More sharing options...
Simpleonly 5th Gear January 16, 2015 Share January 16, 2015 (edited) Bro in this case are you aware if there is actually any amp in your car? :-) Your current speaker might actually be connected to the player by default for all u might know.. Best to get your trusted audio shop to check if you are not too sure on this. Faulty player, amp , speaker or even a simple lose connection might cause those intermittent sound that u mention. Amp is usually install under the front seat or at the boot area. Oh, I dont really need an amplifier as long as i can still listen to radio for traffic news. But I do not know where are the amp wiring located in the sunny. Anyway you got a very good idea, i didnt know our radio set can direct drive the speaker. Thanks alot Edited January 16, 2015 by Simpleonly 1 Link to post Share on other sites More sharing options...
paulshim Neutral Newbie January 16, 2015 Share January 16, 2015 Bro in this case are you aware if there is actually any amp in your car? :-) Your current speaker might actually be connected to the player by default for all u might know.. Best to get your trusted audio shop to check if you are not too sure on this. Faulty player, amp , speaker or even a simple lose connection might cause those intermittent sound that u mention. Amp is usually install under the front seat or at the boot area. Thank you Bro for your advise. You are right, I didnt see any amps at my boot. The audio set is provided by Tan Choong when I first bought the car from them brand new. Maybe I will try to check behind the front panel of the audio set, see if there is any loose cables. I dont hv any audio shop.. Care to recommend any, thanks alot Link to post Share on other sites More sharing options...
Simpleonly 5th Gear January 16, 2015 Share January 16, 2015 Thank you Bro for your advise. You are right, I didnt see any amps at my boot. The audio set is provided by Tan Choong when I first bought the car from them brand new. Maybe I will try to check behind the front panel of the audio set, see if there is any loose cables. I dont hv any audio shop.. Care to recommend any, thanks a lot Sorry, out of touch with audio shop as I go to Ken as mention in this thread. But he is a busy man... you can try to call him to check if he can slot you in. His shop is at toh guan centre now... Good Luck!! 2 Link to post Share on other sites More sharing options...
paulshim Neutral Newbie January 16, 2015 Share January 16, 2015 Sorry, out of touch with audio shop as I go to Ken as mention in this thread. But he is a busy man... you can try to call him to check if he can slot you in. His shop is at toh guan centre now... Good Luck!! Thank you. 1 Link to post Share on other sites More sharing options...
FourZero Hypersonic January 18, 2015 Share January 18, 2015 Thank you Bro for your advise. You are right, I didnt see any amps at my boot. The audio set is provided by Tan Choong when I first bought the car from them brand new. Maybe I will try to check behind the front panel of the audio set, see if there is any loose cables. I dont hv any audio shop.. Care to recommend any, thanks alot Try Tis shop: Soon Lee Audio 727 Geylang Rd Singapore 389638 Hope this helps👍😄 Link to post Share on other sites More sharing options...
Thomas88 Neutral Newbie April 7, 2016 Share April 7, 2016 Does anyone here have the full address of Ken at Toh Guan Centre? Link to post Share on other sites More sharing options...
Auto_emocion 2nd Gear April 21, 2016 Share April 21, 2016 Go and look for Fred from Sound Flux @ to guan ctr level 5. Repair is cheap and good. Link to post Share on other sites More sharing options...
musicman128 Neutral Newbie March 7, 2018 Share March 7, 2018 Anybody has any current contacts for car amplifier repairs? I've been given an amp to install in my ride but one channel has intermittent output. Asked a few repair guys but nobody seems to want to do it... only home audio equipment. Feels kind of wasted if it is a simple problem like a cold solder joint to give it up and have to buy a new amp. Any suggestions greatly appreciated... Link to post Share on other sites More sharing options...
Mr_biscuit 3rd Gear April 22, 2018 Share April 22, 2018 Anybody has any current contacts for car amplifier repairs? I've been given an amp to install in my ride but one channel has intermittent output. Asked a few repair guys but nobody seems to want to do it... only home audio equipment. Feels kind of wasted if it is a simple problem like a cold solder joint to give it up and have to buy a new amp. Any suggestions greatly appreciated... Hi, What is the brand and model of your car amplifier? Have you tried contacting the local agent? ↡ Advertisement Link to post Share on other sites More sharing options...
Xiaomi EV is Coming
Xiaomi EV is Coming
Our car community ❤️🚗
COE Bidding - December 2024
Join us on a curated driving adventure for car enthusiasts! 🚗 Sgcarmart Adventures: Car Factories from Past to Present - 24 November 2024
Used car dealers tampering odometer readings
Where you cut your hair?
