Victor68 Turbocharged April 12, 2021 Share April 12, 2021 On 4/10/2021 at 11:47 PM, Albeniz said: I have recently carved up a small area (~10 square meters) as a study room. I am considering to install a portable aircon. My wish: 1. Electricity bill within reasonable range. 2. Able to function like an air-con in cooling the small room to 25 degree Celsius. 2. Should not too noisy (as intend to have zoom meeting and do some basic video recording). 3. Maintenance is not too troublesome. I hope technology has improved since the thread started 10 years ago. Do let me know if you have some experiences to share. I figure this would be the cheapest solution for me if it works, that is. Do you know of any shops which I could try out the aircon? My opinion, if you just want a temporary solution for a couple of months or occasional use, OK. Permanent arrangement, NO. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Jman888 Moderator April 12, 2021 Share April 12, 2021 On 4/10/2021 at 11:47 PM, Albeniz said: I have recently carved up a small area (~10 square meters) as a study room. I am considering to install a portable aircon. My wish: 1. Electricity bill within reasonable range. 2. Able to function like an air-con in cooling the small room to 25 degree Celsius. 2. Should not too noisy (as intend to have zoom meeting and do some basic video recording). 3. Maintenance is not too troublesome. I hope technology has improved since the thread started 10 years ago. Do let me know if you have some experiences to share. I figure this would be the cheapest solution for me if it works, that is. Do you know of any shops which I could try out the aircon? if really want to cool down to 25 deg or lower, sure need exhaust and exhaust make noise. I got TCL portable aircon, can cool down a 150 sq ft room really quick but noisy. However if you want to lower the noise, you can switch it to fan mode (quite quiet) after cooling down the room and it can last probably an hour (provided the room remain closed/seal). no maintenance needed, just need a small gap from the window to let the hot air out. . 5 Link to post Share on other sites More sharing options...
Watwheels Supersonic April 12, 2021 Share April 12, 2021 7 minutes ago, Jman888 said: if really want to cool down to 25 deg or lower, sure need exhaust and exhaust make noise. I got TCL portable aircon, can cool down a 150 sq ft room really quick but noisy. However if you want to lower the noise, you can switch it to fan mode (quite quiet) after cooling down the room and it can last probably an hour (provided the room remain closed/seal). no maintenance needed, just need a small gap from the window to let the hot air out. . This type has water coming out of an outlet, right? The condensate. If you attach a water hose to it, where does it go? Link to post Share on other sites More sharing options...
Jman888 Moderator April 12, 2021 Share April 12, 2021 5 minutes ago, Watwheels said: This type has water coming out of an outlet, right? The condensate. If you attach a water hose to it, where does it go? this type no water hose nor condensation. There is a small container, it collect very very little water and dry off itself. Link to post Share on other sites More sharing options...
Volvobrick Supersonic April 12, 2021 Share April 12, 2021 (edited) 11 minutes ago, Watwheels said: This type has water coming out of an outlet, right? The condensate. If you attach a water hose to it, where does it go? Don't think got water - probably drips onto the coils and evaporated away. This is a lot more inefficient than normal aircon. But short term use, easiest solution. When no longer needed, just sell off on Carouselll - I sold off one very quickly before to a student moving into hostel. Edited April 12, 2021 by Volvobrick 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic April 12, 2021 Share April 12, 2021 1 minute ago, Jman888 said: this type no water hose nor condensation. There is a small container, it collect very very little water and dry off itself. We are living where the relative humidity is very high. Cannot be very little water. Aircon works by removing moisture content in the air. Link to post Share on other sites More sharing options...
Watwheels Supersonic April 12, 2021 Share April 12, 2021 4 minutes ago, Volvobrick said: Don't think got water - probably drips onto the coils and evaporated away. This is a lot more inefficient than normal aircon. But short term use, easiest solution. When no longer needed, just sell off on Carouselll - I sold off one very quickly before to a student moving into hostel. Then the portable aircon isnt strong and it doesnt cool very well. Link to post Share on other sites More sharing options...
Jman888 Moderator April 12, 2021 Share April 12, 2021 1 minute ago, Watwheels said: We are living where the relative humidity is very high. Cannot be very little water. Aircon works by removing moisture content in the air. i dun use it so often but we use it last year while everyone WFH and on the aircon 5 days a week and about 6 hours each day during the 'summer' season even then i didn't need to clear the water container and there was no water leak at all. I still use it every now and then. One of the features stated "Patented Fogging Technology – efficient auto water evaporation" https://tcl.sg/portable-air-conditioners 2 Link to post Share on other sites More sharing options...
Jman888 Moderator April 12, 2021 Share April 12, 2021 9 minutes ago, Watwheels said: Then the portable aircon isnt strong and it doesnt cool very well. the 10/12 btu one can be quite cold when set to 20 deg, it is as good as the old window unit. Link to post Share on other sites More sharing options...
Watwheels Supersonic April 12, 2021 Share April 12, 2021 2 minutes ago, Jman888 said: i dun use it so often but we use it last year while everyone WFH and on the aircon 5 days a week and about 6 hours each day during the 'summer' season even then i didn't need to clear the water container and there was no water leak at all. I still use it every now and then. One of the features stated "Patented Fogging Technology – efficient auto water evaporation" https://tcl.sg/portable-air-conditioners If the system is detecting a lot of condensate it might shutdown the compressor and just leave the fan running. That means it is not working efficiently. For other countries where the relative humidity is low they experience very low condensate. That's understandable. But for our case if we use a portable aircon we have to attach a hose and direct it to drain the water. Cos normal aircon I already see a lot of condensate flowing out. Ppl dont see it is because the piping is hidden. So if you say the portable aircon system have little condensate it means it is not cooling efficiently. If ppl say the condensate is dispel thru the exhaust you have to see in what position the portable aircon is placed. If it is on the floor and your exhaust pipe has to go up to a window etc. It cannot work against gravity to dispel the water. The water will start to collect at the exhaust outlet and leak all over. Link to post Share on other sites More sharing options...
Cheesey74 6th Gear April 12, 2021 Share April 12, 2021 From what i understood, the current gen portable aircon really dun collect much water on the water collecton box cos they some how manage to expel the water together with the exhaust gas. My co server room got a portable 12000btu tcl back up aircon running 24 x 7 and there is really not much water on the unit water collection box, if any, only problem is the noise nia, unless wear ear plug sleep if use portable aircon in bedroom. 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic April 12, 2021 Share April 12, 2021 If you are talking about your co server room is there any windows and is outside air able to enter the room? If there is none and no outside air then the humidity in that room is likely low. But when compared to residences' typical room you will have high relative humidity and when window seals are not air tight you will typically have a lot of water coming out of the unit. Link to post Share on other sites More sharing options...
Volvobrick Supersonic April 12, 2021 Share April 12, 2021 THis is useful why you should avoid if possible. BUT it's easy to install and get rid off. Trade offs. Condensation (if any) is least of your considerations. 2 Link to post Share on other sites More sharing options...
Kangadrool Supersonic April 12, 2021 Share April 12, 2021 Why not install a window casement type aircon? 2 Link to post Share on other sites More sharing options...
Mustank Hypersonic April 12, 2021 Share April 12, 2021 On 4/10/2021 at 11:47 PM, Albeniz said: I have recently carved up a small area (~10 square meters) as a study room. I am considering to install a portable aircon. My wish: 1. Electricity bill within reasonable range. 2. Able to function like an air-con in cooling the small room to 25 degree Celsius. 2. Should not too noisy (as intend to have zoom meeting and do some basic video recording). 3. Maintenance is not too troublesome. I hope technology has improved since the thread started 10 years ago. Do let me know if you have some experiences to share. I figure this would be the cheapest solution for me if it works, that is. Do you know of any shops which I could try out the aircon? Do this then go to cookhouse there to kope ice 1 Link to post Share on other sites More sharing options...
Cheesey74 6th Gear April 12, 2021 Share April 12, 2021 1 hour ago, Watwheels said: If you are talking about your co server room is there any windows and is outside air able to enter the room? If there is none and no outside air then the humidity in that room is likely low. But when compared to residences' typical room you will have high relative humidity and when window seals are not air tight you will typically have a lot of water coming out of the unit. Yes, i do get ur point on the humidity part but just i keep seeing this new gen portable aircon advertise as having "Self-Evaporative System" so it might be true they manage to improvise on the water condensate part. Maybe some folks here with experience using the newer portable aircon can chip in n provide some updated info for us old fogey.. heehee Link to post Share on other sites More sharing options...
Albeniz Turbocharged April 12, 2021 Share April 12, 2021 For aircon to be placed at the window, which type (referring to the picture below) is better? Link to post Share on other sites More sharing options...
Twister 5th Gear April 12, 2021 Share April 12, 2021 1 hour ago, Albeniz said: For aircon to be placed at the window, which type (referring to the picture below) is better? If your Widows are sliding. The Eurospace one will be easier for installation. Got one from Best Denki, using for more than 2 years. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Dehumidifier recommendations
Car air-con
Car air-con
