Oregon 1st Gear October 14, 2011 Share October 14, 2011 Hi Guys I have an old tire patch (the push in type) now starting to leak. They say cannot patch again and need someone who can do the proper patch from behind the tire surface. Problem is they can't recommend and I don't know who does this. Anyone knows? ↡ Advertisement Link to post Share on other sites More sharing options...
Chickensoup 1st Gear October 14, 2011 Share October 14, 2011 Try Stamford tyre. Otherwise any of those Shell station tyre shop can do it. Just ask if they do patching from inside . It cost more. Link to post Share on other sites More sharing options...
Oregon 1st Gear October 14, 2011 Author Share October 14, 2011 Hi Thanks. I drove around and checked a few shops but they all don't do this. Seems like not so common these days. Link to post Share on other sites More sharing options...
Jchuacl Clutched October 14, 2011 Share October 14, 2011 Try south east at kaki bukit Hi Thanks. I drove around and checked a few shops but they all don't do this. Seems like not so common these days. Link to post Share on other sites More sharing options...
Ril3k 1st Gear October 14, 2011 Share October 14, 2011 most tyre shops shd do try soh bros at ang mo kio Link to post Share on other sites More sharing options...
Silver_blade Turbocharged October 14, 2011 Share October 14, 2011 Try south east at kaki bukit Second that. Alternatively can try stamford tyres or Chin Wah @ Killiney Road Link to post Share on other sites More sharing options...
Kklim Supercharged October 14, 2011 Share October 14, 2011 Just did one at Autotrend in Blk 1002 Toa Payoh Industrial park. $10. Link to post Share on other sites More sharing options...
Blackyv Turbocharged October 14, 2011 Share October 14, 2011 I heard patch from inside, should do it properly, if not will leak, Is it true? How they press down the patch ? Use knock or inner tube ?... Link to post Share on other sites More sharing options...
Mockngbrd Supersonic October 14, 2011 Share October 14, 2011 Stamford tyres . Link to post Share on other sites More sharing options...
Jchuacl Clutched October 14, 2011 Share October 14, 2011 If I rem correctly , dismount tyre , push from inside , and pull it from outside. I heard patch from inside, should do it properly, if not will leak, Is it true? How they press down the patch ? Use knock or inner tube ?... Link to post Share on other sites More sharing options...
Beng2 5th Gear October 18, 2011 Share October 18, 2011 Mended a few tyres this way. Remove tyre from rim, sandpaper the internal, apply glue and wait for a while, then put on the patch. So far no leak on the tyres. Cost me $10 per patch. Quite a fair price, I think. Did it at Sg Kadut tyre shop - can't remember which one, only know how to drive there. Link to post Share on other sites More sharing options...
Rao 1st Gear October 19, 2011 Share October 19, 2011 Mended a few tyres this way. Remove tyre from rim, sandpaper the internal, apply glue and wait for a while, then put on the patch. So far no leak on the tyres. Cost me $10 per patch. Quite a fair price, I think. Did it at Sg Kadut tyre shop - can't remember which one, only know how to drive there. $10 for tyre patch? i was quoted $50 . guess i kena conned. In this case i shall reveal the shop name soon its at First Centre , Serangoon Ave 4 there. there is 2 tyre shop there, one facing the yio chu kang, the other one facing serangoon ave 4. the one charge me 50 is the later ones. damn. see me drive big car charge big ... Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 19, 2011 Share October 19, 2011 Go South East Tyre. They ONLY do internal patching. Link to post Share on other sites More sharing options...
Quekwb Clutched October 19, 2011 Share October 19, 2011 $10 for tyre patch? i was quoted $50 . guess i kena conned. In this case i shall reveal the shop name soon its at First Centre , Serangoon Ave 4 there. there is 2 tyre shop there, one facing the yio chu kang, the other one facing serangoon ave 4. the one charge me 50 is the later ones. damn. see me drive big car charge big ... My friend also exprience unpleasant encounter at the tyre shop facing Sgoon Nth Ave 4. Link to post Share on other sites More sharing options...
Three2eight Neutral Newbie October 19, 2011 Share October 19, 2011 (edited) I did mine at Chung Lee Co @ 316 Tanjong Katong road. The guy has moved on from using a rubber round patch to a newer type that comes with a metal copper wire to seal off the external hole as well for a more complete seal job. Cost a bit more but is more permanent solution than the conventional plug. Edited October 19, 2011 by Three2eight Link to post Share on other sites More sharing options...
Mecontle 1st Gear October 19, 2011 Share October 19, 2011 mine free as hankook member Link to post Share on other sites More sharing options...
Lurpsexx 6th Gear March 16, 2013 Share March 16, 2013 FYI for fellow MCfers.. I think those who got quoted $10 is for external patching, as I called up Stamford Kaki Bukit and they quoted $10 bec they only do patch from outside. The Stamford branch at Lok Yang charge $35 bec they do internal patching; same price as quoted from South East Tyres for internal patching. The extra cost is for the labour to remove the tyre from the rim and then do patch from inside.. more secure if you ask me... Hope this info helps... ↡ Advertisement Link to post Share on other sites More sharing options...
Durian Sellers - recommendations and to avoid
Recommendations for wall paintings
Dirt cheap storage space.. recommendations?
Heavy and rain proof curtains/blinder recommendations?
Recommendations for light kitchen carpentry and sink works
Recommendations for a commercial van
