UR 4pts Front Lower Brace & Antiroll Bar
Mindbox33
Hi...
Wouls like to seek advises..
Me on stock suspension n 16' tyres. Will installing 4 pts front lower brace n anti roll bar helps in stability??
Ur advises much appreciated.
May not be that cheap a thrill if you factor in labour charge
FYI, labour not cheap to install front ARB becoz( for some cars ) you need to remove front cross-member to install, after that still have to do alignment. Labour plus alignment easily about $100
Myth: Adding these bars will improve handling
FACT: If that your car understeers, front bars will help.
If that your car understeers and you add rear bars, it will understeer more.
Base on my experience with minimum cost to improve handling:
Tyres - Get a better one
Air pressure: Get it right and always check weekly.
Alignment: To improve alot on handling, set a more aggressive camber (for my MPV, I set it like how WRX drivers would).
The trade off would be higher tyre wear.
Then after these, depending where you want to improve then mod accordingly.
If that car still understeer, add front bar.
If that you dont want the tyre wear, add front bar.
BUT, what is your annual mileage per year?
Some travel only 20K per year and use a good tyre.
Before it worn out, they have to change the tyre due to age.
Adding front bars will increase understeer. Stiffening the rear with bars will increase oversteer [;)]
Hmm? I thought adding front struts will reduce understeer? [confused] Front struts reduces chassis flex of the front bulk of the car and thus results in better steering response, no? Please enlighten me. ^_^
Anyway, when I was driving a Lancer GLX, a front strut bar didn't give me any significant difference. Steering felt more precise only after I complimented the front struts with a lower 4 points brace. Bodyroll was still as pronounced though. Not sure if it's a placebo effect but I believe car manufacturers didn't install these bars in sportscars for nothing.
they were discussing anti-roll bars, not strut bars. I agree with Pitbull's advice.
not too sure which model u r refering to but my vios ARB was diyed....
Front tower strut reduce front chassis flex and thus gives you more traction, thats why you have better response. Anyway, you have to corner hard to really feel it, daily commute hardly can feel.
Undercarriage struts gives "more feel".
To reduce roll, you need ARB.
Most cars are built to understeer as it's easier to control for most drivers compared to oversteer.
Actually to b more fairer to my question n to rest of bros who input their valuable advises...i tink i will try try at least once to feel it myself... At least i knw wat u guys trying to tell me... [rolleyes]
Yeah, just try it. You may like it. Hear say no point, try for yourself is the best
