Acertey Clutched September 12, 2011 Share September 12, 2011 (edited) Hi Guys, Recently i just did the following: Change of all Engine Mounting, Change of All Suspension; Gear Box Over haul; Rotor & Brake Pad Change(Front done, rear using drum which not done); Brake Oil Change However every time when i brake, there seems to be a jerk which a sound that "thump" with a jerk forward before coming to a full stop. Even before i did the above changes the "thump" before come to a full stop is there. Initially i thought is the engine mounting. Does any brothers here encountered the same problem? Edited September 12, 2011 by Acertey ↡ Advertisement Link to post Share on other sites More sharing options...
SimonTan 2nd Gear September 12, 2011 Share September 12, 2011 Did it happen for reverse braking? The sound is from normal gentle braking or only during sharp hard braking or with ABS activated type of emeregench braking? Link to post Share on other sites More sharing options...
Acertey Clutched September 12, 2011 Author Share September 12, 2011 reverse no sound but also jerk. Normal braking... Link to post Share on other sites More sharing options...
Civic6656 1st Gear September 12, 2011 Share September 12, 2011 It could be the gearbox mounting is worn... Link to post Share on other sites More sharing options...
Mecontle 1st Gear September 12, 2011 Share September 12, 2011 front suspension not proper calibrate ? if u press front sides of ur bonnet see if it vibrates up & down (bad) or not shaking (good) Link to post Share on other sites More sharing options...
SimonTan 2nd Gear September 12, 2011 Share September 12, 2011 Something that is loose. Like some mounting for gearbox or suspension arm. Or it could even be your car seat that is loose. Hard to say. Link to post Share on other sites More sharing options...
Spiderman302 2nd Gear September 12, 2011 Share September 12, 2011 Hi Guys, Recently i just did the following: Change of all Engine Mounting, Change of All Suspension; Gear Box Over haul; Rotor & Brake Pad Change(Front done, rear using drum which not done); Brake Oil Change However every time when i brake, there seems to be a jerk which a sound that "thump" with a jerk forward before coming to a full stop. Even before i did the above changes the "thump" before come to a full stop is there. Initially i thought is the engine mounting. Does any brothers here encountered the same problem? Is it a Honda City ? Link to post Share on other sites More sharing options...
Acertey Clutched September 12, 2011 Author Share September 12, 2011 wah spot on Honda city, 2007. Engine Mounting i just all changed, Suspension also, shouldn't be these 2 becos before i change this thump is already there. Link to post Share on other sites More sharing options...
Acertey Clutched September 13, 2011 Author Share September 13, 2011 anybody can help? Link to post Share on other sites More sharing options...
Asure7 1st Gear September 13, 2011 Share September 13, 2011 (edited) Not sure if it helps since different cars, although similar symptoms. Many E60s (after about 40-60k) has this problem: Jerk just before stopping. After all the troubleshooting, change this change that, it's gearbox mechatronics problem. It jerks under "D", but not when it is in "S" (sports) mode. Found that it jerks if the gear shifts to 1st gear just before stopping (using "manual" mode). Had to change the mechatronics for $4-5k and the problem went away. But it doesn't really happen when reversing though. Did you change your ATF, and use the original Honda one? (assuming the gearbox overhaul was properly done) Edited September 13, 2011 by Asure7 Link to post Share on other sites More sharing options...
Acertey Clutched September 13, 2011 Author Share September 13, 2011 yes i did, in fact i also did a gearbox overhaul. Before the gearbox overhaul this loud thump is already there, but the thing is after gear box over haul the thump is still there, it's weird. Unless the gear the is link to the starter clutch is also damaged Link to post Share on other sites More sharing options...
Watwheels Supersonic September 13, 2011 Share September 13, 2011 Last time I encounter this was on a European car, the thump sound during braking is caused by the programming of the gearbox, downshift of the autobox when slowing down/braking. Feedback to AD, AD feedback to HQ and they follow up with new software couple of weeks later, did a reflash, thumping gone. Link to post Share on other sites More sharing options...
Jim 1st Gear September 13, 2011 Share September 13, 2011 yes i did, in fact i also did a gearbox overhaul. Before the gearbox overhaul this loud thump is already there, but the thing is after gear box over haul the thump is still there, it's weird. Unless the gear the is link to the starter clutch is also damaged This is a very important question: Which transmission fluid did you use? If this is a CVT Honda City, you *must* use CVTF or HMMF. If it is ATF-Z1, you must change it *immediately*. And if your mechanic use ATF-Z1 for your CVT City, you should change mechanic too. Link to post Share on other sites More sharing options...
Acertey Clutched September 13, 2011 Author Share September 13, 2011 i use CVTF.... oil correct... Link to post Share on other sites More sharing options...
Jim 1st Gear September 13, 2011 Share September 13, 2011 i use CVTF.... oil correct... In that case, I agree it is probably the startup clutch is worn. You can try and re-calibrate the gearbox... I am not exactly sure how it is done, but the general idea is you disconnect the battery so the ECU forgets the old settings and then reconnect back, start the car and shift the gear from P to L and back again twice. I doubt it will fix a worn clutch, but no harm trying. Link to post Share on other sites More sharing options...
Spiderman302 2nd Gear September 13, 2011 Share September 13, 2011 wah spot on Honda city, 2007. Engine Mounting i just all changed, Suspension also, shouldn't be these 2 becos before i change this thump is already there. I owned a honda city autogear first generation years back. Got the same problem. Everytime reach traffic light. Gear still engaged but no right foot. There will be a slight "Thong" sound with a slight jerk forward motion at a particular speed.(dont remember what speed). Jist like the car suddenly go free gear. Called Kah motor, they said its inherited character of the gear box. Ask me to ignore. Link to post Share on other sites More sharing options...
Acertey Clutched September 14, 2011 Author Share September 14, 2011 wah like that, this type of response from KM. Cos i just overhaul the CVT gearbox, can say my starter clutch is in good condition with the correct oil. Actually i am curious what does the starter clutch connects to besides the gear box. Cos when my mechanic took it out, i can see some teeth worn off on the starter clutch. I just wondering if that portion is CAM Shaft or Engine Block if is damage? Link to post Share on other sites More sharing options...
Spiderman302 2nd Gear September 14, 2011 Share September 14, 2011 wah like that, this type of response from KM. Cos i just overhaul the CVT gearbox, can say my starter clutch is in good condition with the correct oil. Actually i am curious what does the starter clutch connects to besides the gear box. Cos when my mechanic took it out, i can see some teeth worn off on the starter clutch. I just wondering if that portion is CAM Shaft or Engine Block if is damage? Too bad you cant go back to KM as your warranty is over. I am no expert in this area. My apology I cant answer your questions. ↡ Advertisement Link to post Share on other sites More sharing options...
Anybody into quantum physics, relativity or just a science freak?
Online purchase for car parts
i Wake Up Naked Today Morning
ODO Mileage Tampering
