How not have creases on shirt caused by seat belt?
Jujitsuka
Hi Bros any frdly advice?
Is there any iron or chemical when applied when ironing shirt will make it more resistant to creases by sealt belt?
do the dangerous way like some taxi uncle did...Use a seat belt clip to loosen the belt...But risk your life lor...
usually only the belt at your tummy causes the crease, i just lower the belt to my belt and problem solve
Don't wear seatbelt...haha.
In psychological terms, it's actually safer. Because if you do not wear seatbelt, you know that you will fly out if kenna accident. Therefore, you will tend to drive safer.
But if you put on seatbelt, you will think 'Aiya, even if kenna accident I will be protected by the seatbelt' therefore you will drive more recklessly.
:D
Turbocharged
actually, why can't they design the seatbelt like those in the plane?
Then it will not crease the shirt too much since it is the diagonal strap which make the crease. Is there a purpose to that diagonal strap besides adjusting length?
