Knock sound from steering while stationary
Eugn86
Hi guys, anyone encountered this problem before?
My car is producing some knocking and creaking sound from the car. I realised when the car is stationary and i turn the steering wheel from center to either left or right, midway towards full-lock there will be a couple of knock sounds, and disappears while continuing to full-lock. The same thing happens when going from full-lock to center position. This knocking sound comes again while turning at low speeds especially in car parks with all the humps and irregular surfaces. Any idea what is causing this problem? [:(]
Confirm its either ur whole drive shaft (left or right side) or the cv joint at the drive shaft is having problem.
I had the SAME probs as u for the last 6 mths...
I went elite drive shaft car center the last time as recommended by many... Look for jason 64820215, at sin mind road..
I changed my oem left drive shaft at 160nett including labor... The lowest aft i check w many reputable workshop
