Sp33dst3r Neutral Newbie July 26, 2011 Share July 26, 2011 Beside Motul and Redline, what other oil are also Group V ester base oil? http://www.technilube.com/faqs_info/base_oils.php ↡ Advertisement Link to post Share on other sites More sharing options...
Satria_neo Clutched July 26, 2011 Share July 26, 2011 So far, I have only heard of Motul and Redline using Ester base stocks. Most of the companies are using PAO. However, additives used in the oil is considered more important than base stock. This is because base stock alone do not provide sufficient protection for the engine. You need anti-wear and scuffing additives, cleaning agents, anti-foaming etc..... Lots of additives are needed. Of course there are certain conditions where base stock is considered very important due to operating environment but it does not apply to street cars. Link to post Share on other sites More sharing options...
Sp33dst3r Neutral Newbie July 26, 2011 Author Share July 26, 2011 Redline oil good? My car is turbocharged. Link to post Share on other sites More sharing options...
Elements_Trading Neutral Newbie July 26, 2011 Share July 26, 2011 (edited) WTS: Shell Helix Engine Oil. Limited stock available. Pm me for information. Edited July 26, 2011 by Elements_Trading Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged July 26, 2011 Share July 26, 2011 Redline oil good? My car is turbocharged. not bad.... im using it now. confirm better than M1 frm Giant...... Link to post Share on other sites More sharing options...
Lotus4712 Neutral Newbie July 26, 2011 Share July 26, 2011 I never like mobil 1 from giant or carrefour if they are made in US. Only mobil 1 made in eu can do. Castrol gd too. These are from own personal experience. Link to post Share on other sites More sharing options...
Spiderman302 2nd Gear July 26, 2011 Share July 26, 2011 Anybody use AMSoil 5w30 100% syn ? Care to give your feedback ? Link to post Share on other sites More sharing options...
SimplyTWL 1st Gear July 26, 2011 Share July 26, 2011 Only Motul and Castrol the best. Once you use motul, you won't want to change engine oil to another brand. Link to post Share on other sites More sharing options...
Satria_neo Clutched July 28, 2011 Share July 28, 2011 Anybody use AMSoil 5w30 100% syn ? Care to give your feedback ? Yes, I am using the new Amsoil API:SN oil 10W30 grade. Its very good value for money. Link to post Share on other sites More sharing options...
Satria_neo Clutched July 28, 2011 Share July 28, 2011 Redline oil good? My car is turbocharged. Yes, redline oil is pretty good. Link to post Share on other sites More sharing options...
Fennmax Clutched July 28, 2011 Share July 28, 2011 Is castrol edge ester based oil? Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear July 28, 2011 Share July 28, 2011 Redline oil good? My car is turbocharged. get 5w40 or higher. better to change every 5,000km. Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear July 28, 2011 Share July 28, 2011 I never like mobil 1 from giant or carrefour if they are made in US. Only mobil 1 made in eu can do. Castrol gd too. These are from own personal experience. yes, want to use M1, only get M1 Gold. Link to post Share on other sites More sharing options...
Solar Turbocharged July 28, 2011 Share July 28, 2011 get 5w40 or higher. better to change every 5,000km. may not be necessary to change every 5k. recommended oci for me is 10k.. been doing that since my car broken-in. 5yrs now, no funny noise, no engine damage or performance loss. 5k is probably for those who track or heavily modded.. the thrashing may have badly cooked the oil Link to post Share on other sites More sharing options...
Satria_neo Clutched July 29, 2011 Share July 29, 2011 Yes agreed. How long your oil can last largely depends on your driving tool. City driving. Numerous col starts etc definitely shorten lifespan of the oil. Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear July 29, 2011 Share July 29, 2011 bro Sp33dst3r devil ride is a TC car. 10k might not be recommended. =p Link to post Share on other sites More sharing options...
Mona-vie 1st Gear July 30, 2011 Share July 30, 2011 For TC cars, 10K is not recommended. You will end up killing your turbo bearings in the long run. Stick with 5K instead. Link to post Share on other sites More sharing options...
Mona-vie 1st Gear July 30, 2011 Share July 30, 2011 may not be necessary to change every 5k. recommended oci for me is 10k.. been doing that since my car broken-in. 5yrs now, no funny noise, no engine damage or performance loss. 5k is probably for those who track or heavily modded.. the thrashing may have badly cooked the oil TC or NA? If NA 10K no problem, if TC not recommended. This is because the oil is also used to cool and lubricate your turbo bearings. ↡ Advertisement Link to post Share on other sites More sharing options...
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
