Opel17 6th Gear October 30, 2011 Share October 30, 2011 Hi bro Tianmo, thanks for your 2 PMs. Cheers ↡ Advertisement Link to post Share on other sites More sharing options...
Tianmo Hypersonic October 30, 2011 Share October 30, 2011 Hi bro Tianmo, thanks for your 2 PMs. Cheers hope it helps!!!!.............enjoy!!!.............cheers!!! [laugh] Link to post Share on other sites More sharing options...
K3037 Neutral Newbie October 30, 2011 Share October 30, 2011 Open door panel to check. Maybe minor, DIY with epoxy or wire will resolve the problem. Know what need to change. So to prevent the carrothead chop. I had repaired my office's MB sprinter window, and it lasted for a few years now. The plastic slider broke. Only stitched with fine wire and bond with epoxy. I think it is even tougher than orginal. Sounds good, use fine wires and then apply epoxy. Never thought of it. Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 31, 2011 Share October 31, 2011 (edited) Suction cups are widely used by professional auto window mechanics to reduce labour and time. Edited October 31, 2011 by Yeobh Link to post Share on other sites More sharing options...
Skipper Neutral Newbie May 22, 2012 Share May 22, 2012 Hi Bro Tianmo I just got some problem with my power window and saw yr post Can you PM me for the spare part WS also ? I stay in west Thks for yr help ! Link to post Share on other sites More sharing options...
Fibo 4th Gear October 5, 2012 Share October 5, 2012 Hyundai matrix, December 2005 window on the driver side Spoilt - no response when pressing the window button. The other three windows are ok. Same problem happened three years ago and a mechanic charged $20 to tighten some loose part which I think was mechanical. Same problem occur again. I went to a new workshop and the mechanic said the motor need replacement. Part and Labour $185. can you guys advise is this a fair price, or do you think it is not the motor since the other three windows are ok? Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 5, 2012 Share October 5, 2012 Hyundai matrix, December 2005 window on the driver side Spoilt - no response when pressing the window button. The other three windows are ok. Same problem happened three years ago and a mechanic charged $20 to tighten some loose part which I think was mechanical. Same problem occur again. I went to a new workshop and the mechanic said the motor need replacement. Part and Labour $185. can you guys advise is this a fair price, or do you think it is not the motor since the other three windows are ok? Normally driver window spoil faster cos usuge is higher. Price $185 is ok to change new motor but check if its original oem or aftermarket.? Last time i chg spoil in 1month go back ws found out its cheepo made in china n ws say no warranty. I straight away drive off never to go back there again. Went to regular ws n ty get original jap 2nd hand motor fm scrapyard cheeper n it lasted >5 years till i sold car. Btw car was coe corona cd. Link to post Share on other sites More sharing options...
Fibo 4th Gear October 5, 2012 Share October 5, 2012 Bro, I appreciate your response! this is first time I patronize this workshop. Since this is reasonable, I may use their service again. Great day to you! Link to post Share on other sites More sharing options...
Club21z 4th Gear October 5, 2012 Share October 5, 2012 Just to share recently my window fail too. Press button on both front passenger no response, picanto btw. Changed the relay for $65 at yew tee industrial. Link to post Share on other sites More sharing options...
WTF 4th Gear October 5, 2012 Share October 5, 2012 Hyundai matrix, December 2005 window on the driver side Spoilt - no response when pressing the window button. The other three windows are ok. Same problem happened three years ago and a mechanic charged $20 to tighten some loose part which I think was mechanical. Same problem occur again. I went to a new workshop and the mechanic said the motor need replacement. Part and Labour $185. can you guys advise is this a fair price, or do you think it is not the motor since the other three windows are ok? I changed mine with labour at $200......my ride is Altis though...... Link to post Share on other sites More sharing options...
Fibo 4th Gear October 5, 2012 Share October 5, 2012 Thank u for sharing! Great day to you! Link to post Share on other sites More sharing options...
TVT Supercharged October 5, 2012 Share October 5, 2012 I changed mine with labour at $200......my ride is Altis though...... You change one side or 4 sides for $200 ? Link to post Share on other sites More sharing options...
WTF 4th Gear October 5, 2012 Share October 5, 2012 You change one side or 4 sides for $200 ? Of course 1 side lah........if 4 sides spoilt I must be damned suay........... Link to post Share on other sites More sharing options...
Throttle2 Supersonic October 5, 2012 Share October 5, 2012 Dear bros, I may need your professional advise. Dis morning, while reaching my office, i begin to wind up my window as i normally wind it down during morning. As my window begins to wind up, i heard a crack sound like something broke to pieces. Then the next thing is my window cannot be wind up. I can still hear the sound of the motor running when i press the button but the window is simply not moving. I can even use my hand to pull up the window, but the max i can pull is almost fully closed... there's still a small gap to fully closed n the window stuck there... do u guys haf any idea wat happened? Thanks I know exactly what is wrong with it. The lifter or regulator of your power window is broken. It is a simple cabling system housed in a plastic frame. It is normal and common due to wear and tear. My personal experience is with continental cars, BMW , Mercy, Porsche. Replacement requires removing the door panel. for frame door, requires more adjustments for normal door, it is simpler and should take no longer than 90mins. Cost varies of course, expect to pay some labor fee. My CLS350 replaced both passenger and driver (cost $400 for one side) My 911 replace driver side (cost $400++) for japanese cars i would expect less than half that cost. Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 5, 2012 Share October 5, 2012 Bro, I appreciate your response! this is first time I patronize this workshop. Since this is reasonable, I may use their service again. Great day to you! Cheers bro. Link to post Share on other sites More sharing options...
13177 Hypersonic November 12, 2012 Share November 12, 2012 Just to share recently my window fail too. Press button on both front passenger no response, picanto btw. Changed the relay for $65 at yew tee industrial. Which workshop you went? $65 is for parts plus labour? Link to post Share on other sites More sharing options...
Vsafe Neutral Newbie November 12, 2012 Share November 12, 2012 just PM. how much Link to post Share on other sites More sharing options...
Peas85 Neutral Newbie November 26, 2012 Share November 26, 2012 Call Mr. Ah Wah (Power window repairier for used car - he repairing for car marts & dealers islandwide -- He'll repair at your door step) 9006 9797 and inform his your car model and which window so that we could prepare the parts. thanks bro for the info. he repaired my power window yesterday ↡ Advertisement Link to post Share on other sites More sharing options...
Window grill lock
Window grill lock
Home power back up
Home power back up
Honda Stream 2009 No Power and High fuel Consumption
Alcades power optimizer
Home window - Sliding or casement?
STEK NEX Series Carbon Ceramic with Graphene Window Tint
