Power window problems
Sash1401
Dear bros,
I may need your professional advise. Dis morning, while reaching my office, i begin to wind up my window as i normally wind it down during morning. As my window begins to wind up, i heard a crack sound like something broke to pieces. Then the next thing is my window cannot be wind up. I can still hear the sound of the motor running when i press the button but the window is simply not moving. I can even use my hand to pull up the window, but the max i can pull is almost fully closed... there's still a small gap to fully closed n the window stuck there... do u guys haf any idea wat happened? Thanks
Sounds like the teeth of the gear pinion assembly gave way. But the assembly is enclosed in a casing, not likely for something to get caught in between the teeth. It could probably fail due to fatigue. Anyway I think the assembly & the motor comes as a set for the power window.
As long as the mechanics got the spare parts ready in shop...then it's a two hour job.
Else have to order parts...then it's a half day job.
Warranty over Liao... I juz managed to pull up the window fully... Maybe if today no time I can still postphone to another day... Hopefully it's nothing serious too
last time mine is can go down cannot go up.............the gearing damage......replace part was i think $145......labor charge $60.............but I think labor on the high side...can get cheaper else where.....
what is your ride???
I had the same problem more than a yr ago.
The power window is usually termed as window regulator.
The cracking sound is likely to the cracking of the plastic pulley bracket [either end of the slide rail] or the plastic window attachment.
I had DIY replaced with a new window regulator, but now the plastic window attachment cracked again.
Recently, I checked with STAR Automotive [Jln Boon Lay]. If a new window regulator is provided, they will do the job for S$55.00, not sure have to add 7% GST.
If you intend to postpone the repair, do take note that the window glass may slide down anytime due to road vibration, humps, etc.. Suggest you use at least 2 suction cups to hold the window in place, against the door frame rubber seal.
  On 7/18/2011 at 4:07 AM, Sash1401 said:
Mime is company van... Ford transit connect... Looks like its the sAme prob
if you are in the west or northwest...............i can PM you one spare part shop cum WS..........he charge like 20-30$ for labour and parts you buy from him........
realli so cheap ? care to pm me as well ?
Open door panel to check.
Maybe minor, DIY with epoxy or wire will resolve the problem.
Know what need to change. So to prevent the carrothead chop.
I had repaired my office's MB sprinter window, and it lasted for a few years now. The plastic slider broke.
Only stitched with fine wire and bond with epoxy. I think it is even tougher than orginal.
Edited by 5936
QUOTE (Tianmo @ Jul 18 2011, 12:22 PM)
Hi Bro, can u PM me the add for the WS u mentioned? Thank u so much.... I juz went to check n was told the mechanism spoilt... when i press the buttom, motor moves but the window did nt.... further more there's a draging sound... the mechanic told me no nid to open up as he hear he know its the mechanism spoilt liao coz open up to check got additional cost... i got him to check the pricing wif installation, he told me $540.... I almost fainted!!! coz i juz got my radiator hose replaced last week n nw today got dis new prob... so damn suay!!!!
Edited by Sash1401
Opel17 Posted Today, 11:46 AM
Hi Bro, where do i get the suction cups u mention? if i dun repair, will the inspection fail when my power window is not working?
just PM....
  On 7/18/2011 at 8:57 AM, Hiphiphoray said:
That time the power window motor kaput.
Basket!!! Sonata NF model is one whole piece one.
Must replace the whole panel assembly....... [lipsrsealed]<_<
last time mine also sonata NF........lucky is gear system only.......think is the belt broken or something like that......motor boh dai ji............
if motor ok than not too ex.................if motor up loli tio siao liao!!! [:(] [:(]
Edited by Tianmo
