Stanchiam 1st Gear July 17, 2011 Share July 17, 2011 (edited) Decide to do an oil change around 6000km since i feel the oil is black click on the link to see the process, cost me around $20. http://bit.ly/nqaxvs encourage bros to diy since it is simple and easy not much tools needed Edited July 17, 2011 by Stanchiam ↡ Advertisement Link to post Share on other sites More sharing options...
Ithunk 1st Gear July 17, 2011 Share July 17, 2011 (edited) thanks for sharing but my nut is located deep inside...will need to jack anyway to add workshops nowadays use an oil sucker Edited July 17, 2011 by Ithunk Link to post Share on other sites More sharing options...
Cynidejunkie Neutral Newbie July 17, 2011 Share July 17, 2011 yeah. i noticed that also. wonder why. Link to post Share on other sites More sharing options...
Stanchiam 1st Gear July 17, 2011 Author Share July 17, 2011 (edited) yeah. i noticed that also. wonder why. fast, do not need to unscrew, jack up or wait for oil to drain just suck out old oil then pour in new oil but disadvantage is not all old oil is drain away and those metal debris still stuck in the magnetized nuts coolant i know they do that, didnt know engine oil also do that. Edited July 17, 2011 by Stanchiam Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 17, 2011 Share July 17, 2011 (edited) Receive this info from friends - that Toyota Prius Hybrid & Corolla 1800 & 2000 cc are using plastic canister oil filter. To remove the canister, mechanic needs to exercise care and use the right tool to prevent damage to the plactic canister Edited July 17, 2011 by Yeobh Link to post Share on other sites More sharing options...
Fusionkoh Neutral Newbie July 22, 2011 Share July 22, 2011 Bro, since not much people is replying i guess not much harm done. However, the oil that you are using is very misleading. Always remember that good oil don't come cheap and cheap oil don't come good. For point A to point B cars, of coz any oil that passes through SG is at least of min required quality. However, it really depends of the spec of your car, your driving style and how often you are willing to change your oil. If your have all the required knowledge of engine oils and their compatibilities, of coz you can use that knowledge to save cost. Otherwise, i recommend sticking to the safest class of oil(5w40 or 0w40), fully syn and not hydrocracked and stick to 10k servicings. Also go for known brands, eg shell, mobil, castrol, OWS etc. Generally shld cost you btw 60 to 80 bucks if you manage to buy from giantmarts or servicing cost ranging from 110 to 140 for oil change + filter + labour. Link to post Share on other sites More sharing options...
5936 1st Gear July 22, 2011 Share July 22, 2011 Heng ah... mine is the standard type Link to post Share on other sites More sharing options...
5936 1st Gear July 22, 2011 Share July 22, 2011 May I ask what is the difference between hydrocracked oil and if may know the thermal cracked oil? Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged July 22, 2011 Share July 22, 2011 thanks for sharing but my nut is located deep inside...will need to jack anyway to add workshops nowadays use an oil sucker never go to those shop which use "oil sucker"... those are short cut use to simplified the work... you oil should be drain from drain nut... Link to post Share on other sites More sharing options...
Ithunk 1st Gear July 22, 2011 Share July 22, 2011 (edited) Bro, since not much people is replying i guess not much harm done. However, the oil that you are using is very misleading. Always remember that good oil don't come cheap and cheap oil don't come good. For point A to point B cars, of coz any oil that passes through SG is at least of min required quality. However, it really depends of the spec of your car, your driving style and how often you are willing to change your oil. If your have all the required knowledge of engine oils and their compatibilities, of coz you can use that knowledge to save cost. Otherwise, i recommend sticking to the safest class of oil(5w40 or 0w40), fully syn and not hydrocracked and stick to 10k servicings. Also go for known brands, eg shell, mobil, castrol, OWS etc. Generally shld cost you btw 60 to 80 bucks if you manage to buy from giantmarts or servicing cost ranging from 110 to 140 for oil change + filter + labour. thanks for the info...but i know of a cheaper place which sell engine oil by the tons....anyway the current is ok...alot depends on the oil specs for the engine but yeah the oils u mentioned are good brands Edited July 22, 2011 by Ithunk Link to post Share on other sites More sharing options...
Ithunk 1st Gear July 22, 2011 Share July 22, 2011 (edited) never go to those shop which use "oil sucker"... those are short cut use to simplified the work... you oil should be drain from drain nut... lol the oil sucker did not work so used the traditional nut....anyway it was the workshop reccomended by the dealer and their prices are reasonable....and of course i know the rate....if they keep their prices normal and the same i will go back again... anyway changing engine oil is a pretty straight forward...but of course one must know how to jack and the tools needed for the nut anyway the first vehicle was an eg so learnt as much as i can about vehicles and talking to mechanics and of course i will never pay 72k for piece of paper called coe Edited July 22, 2011 by Ithunk Link to post Share on other sites More sharing options...
Nismo22 Neutral Newbie July 22, 2011 Share July 22, 2011 try using liquimoly oil , together with their oil addictive , although somewhat ex, but the result is good .. , hear the sound and the engine response.. imbal.. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged July 22, 2011 Share July 22, 2011 lol the oil sucker did not work so used the traditional nut....anyway it was the workshop reccomended by the dealer and their prices are reasonable....and of course i know the rate....if they keep their prices normal and the same i will go back again... anyway changing engine oil is a pretty straight forward...but of course one must know how to jack and the tools needed for the nut anyway the first vehicle was an eg so learnt as much as i can about vehicles and talking to mechanics and of course i will never pay 72k for piece of paper called coe the "sucker" method is pretty popular in US due to high labour cost. its straight forward but its not an effective way to hange oil. Such oil changing method will left the containminated oil in the engine... although the oil drain method will also left some old oil inside, but the sucking method is worst... Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 22, 2011 Share July 22, 2011 (edited) Old habits and practice are very difficult to change. The workshops in Japan have been using vacuum oil changer for more than 30 yrs. In Singapore , service stations were introduce to Japanese make vacuum oil changers ( Brand: Kitajima) with large glass dome as early as late 1970's. Surprising, up to date the idea still don't catch on even though shop operators are facing high rental, worker shortage and very small working space. High resistance to change in turns directly translate to low productivity and that means lower profit. Edited July 22, 2011 by Yeobh Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 22, 2011 Share July 22, 2011 (edited) Photo shows a oil drain plug repair set with all the various taps, plugs and copper washers. This Taiwan tool maker has produce this hot selling cake to meet the growing repair demands on damag drain plugs by shops that still change engine oil via the drain plug. Edited July 22, 2011 by Yeobh Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 24, 2013 Share July 24, 2013 (edited) Extracting engine oil and other vehicle fluid will be fun and enjoyable for DIYers with this manually operated vacuum extractor. No more crawling under the car and getting burn by hot engine oil pan, dripping oil, exhaust pipe etc. Edited July 24, 2013 by Yeobh Link to post Share on other sites More sharing options...
Kangadrool Supersonic July 24, 2013 Share July 24, 2013 Where can I buy this pump? Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 24, 2013 Share July 24, 2013 Just PM U ↡ Advertisement Link to post Share on other sites More sharing options...
Tool to change Spark Plug
Change Disc Rotors
Change Disc Rotors
X for twitter change request
