Bluepica 4th Gear July 14, 2011 Share July 14, 2011 Recently I was tailed by a white Forte at night without headlight but just the pole lamp. To make things worst, the pole light was is RED color! At first I thought is was the back of a car! This was only one of the so many vehicles that have changed the color of their vehicle's lightings. Turning signal changed to white/blue or even red. Back number plate lighting using bright white LED Using yellow spot light color (though not the spotlight itself) as headlamp. All these lights modifications are being nuisance to other road users if not sending a wrong signal to them. ↡ Advertisement Link to post Share on other sites More sharing options...
Old-driver 5th Gear July 14, 2011 Share July 14, 2011 I have also came across some drivers who don't turn on their headlights though the sky is pitched dark! I know some cars have their panels illuminated but turning on the lights is part of the routine when we learn driving. Link to post Share on other sites More sharing options...
Rosschang 1st Gear July 14, 2011 Share July 14, 2011 I tot one will only see such modification in m'sia... surprise surprise Link to post Share on other sites More sharing options...
Nightkids 6th Gear July 14, 2011 Share July 14, 2011 On 7/14/2011 at 8:17 AM, Bluepica said: Recently I was tailed by a white Forte at night without headlight but just the pole lamp. To make things worst, the pole light was is RED color! At first I thought is was the back of a car! This was only one of the so many vehicles that have changed the color of their vehicle's lightings. Turning signal changed to white/blue or even red. Back number plate lighting using bright white LED Using yellow spot light color (though not the spotlight itself) as headlamp. All these lights modifications are being nuisance to other road users if not sending a wrong signal to them. 哇。。。。。真牛!!!!!! Link to post Share on other sites More sharing options...
Passion 5th Gear July 14, 2011 Share July 14, 2011 I also change my boot number plate light to white after the sales person told me last longer? What's wrong? Don't affect you also. Anyway, everything else is stock. Link to post Share on other sites More sharing options...
Yuan 6th Gear July 16, 2011 Share July 16, 2011 On 7/14/2011 at 8:37 AM, Old-driver said: I have also came across some drivers who don't turn on their headlights though the sky is pitched dark! I know some cars have their panels illuminated but turning on the lights is part of the routine when we learn driving. That is becoming more common on the road these days. Seen so many cars like this in the evening. Link to post Share on other sites More sharing options...
Powerkeong Neutral Newbie July 16, 2011 Share July 16, 2011 How about modified lorries with blink link and rainbow LED running around outside the car? and nightrider with blinking lights all over the place? what signal does that send you? Morale of the story. Just drive carefully. Link to post Share on other sites More sharing options...
Darthrevan Supercharged July 16, 2011 Share July 16, 2011 On 7/14/2011 at 8:45 AM, Rosschang said: I tot one will only see such modification in m'sia... surprise surprise pple with bad taste exist in all places Link to post Share on other sites More sharing options...
Lanevomax 1st Gear July 17, 2011 Share July 17, 2011 if it is not a auto level HID , it can be more worst. Link to post Share on other sites More sharing options...
Blackyv Turbocharged July 17, 2011 Share July 17, 2011 Actually, I do not have problem with how people want to pimp up their ride but I hate those pimp up ride hogging the right lane.... ride pimp up untilled stylo Milo urs drive like a grandma ... Link to post Share on other sites More sharing options...
Kzy Neutral Newbie July 17, 2011 Share July 17, 2011 On 7/17/2011 at 2:01 AM, Blackyv said: Actually, I do not have problem with how people want to pimp up their ride but I hate those pimp up ride hogging the right lane.... ride pimp up untilled stylo Milo urs drive like a grandma ... hahas..true true... =D Link to post Share on other sites More sharing options...
Blackchicken Neutral Newbie August 2, 2011 Share August 2, 2011 worse are those..on headlight...front fog light plus rear fog light...as if singapore blackout...damn glaring no matter u are in front or behind them.. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear August 2, 2011 Share August 2, 2011 On 7/14/2011 at 8:17 AM, Bluepica said: Recently I was tailed by a white Forte at night without headlight but just the pole lamp. To make things worst, the pole light was is RED color! At first I thought is was the back of a car! This was only one of the so many vehicles that have changed the color of their vehicle's lightings. Turning signal changed to white/blue or even red. Back number plate lighting using bright white LED Using yellow spot light color (though not the spotlight itself) as headlamp. All these lights modifications are being nuisance to other road users if not sending a wrong signal to them. I believe we all very thankful if you could report such observations to the Authority. Such modifications are likely to be among illegal modifications that endanger us. Many thanks. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear August 2, 2011 Share August 2, 2011 On 7/16/2011 at 5:04 PM, Powerkeong said: How about modified lorries with blink link and rainbow LED running around outside the car? and nightrider with blinking lights all over the place? what signal does that send you? Morale of the story. Just drive carefully. I believe should be report them to the Authority. Such modifications compromise our road safety. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear August 2, 2011 Share August 2, 2011 On 7/16/2011 at 4:06 PM, Yuan said: That is becoming more common on the road these days. Seen so many cars like this in the evening. Hmm... could that be another technique by Insurers to raise motor insurance premium with more accidents? Link to post Share on other sites More sharing options...
Tannhauser Neutral Newbie August 3, 2011 Share August 3, 2011 they are just trying to be rice , ignore them Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear August 3, 2011 Share August 3, 2011 On 8/3/2011 at 12:37 AM, Tannhauser said: they are just trying to be rice , ignore them Sushi/porridge? Link to post Share on other sites More sharing options...
Mrpega Neutral Newbie August 3, 2011 Share August 3, 2011 yeah..hehe..bloody rice-er =) ↡ Advertisement Link to post Share on other sites More sharing options...
Worth to be a Grab Driver now?
Giving up uni for bus driver
Quad Light Bulb Size
Driver of Maserati found guilty of causing grievous hurt to policeman, faces 59 other charges
