Ceiling Fan Mounting Bracket
Octopus
  On 7/19/2011 at 8:21 AM, Pisces69 said:
I tot HDB dont approve celing fans. Install at your own risk.?????
HDB guideline on ceiling fan can be found here:
http://www.hdb.gov.sg/fi10/fi10324p.nsf/w/...al?OpenDocument
1) Weight of fan should not exceed 6 kg
2) Clear height from finished floor level to fan blades should be at least 2.4 m
3) Hardened steel expanding bolt should not exceed 8 mm in diameter and penetration depth of steel plug should not exceed 40 mm
  On 7/19/2011 at 1:16 PM, Octopus said:
Yes, ID will install the fan. But unlike other brand ceiling fan where the package include mounting bracket, KDK fan does not provide it. That is why I am looking for the correct bracket.
OH. Strange ty dont provide the correct mounting bracket?
But just make sure its properly done. Dont want the bugger to fly off n come crashing down at full speed. [dizzy][crazy]
Oh so now they FINALLY approve.
Last time I install, ty say do at yr own risk. HDB dont approve.
But my current fans I think r OK cos installed by proper contractor.
Hi Guys,
I have bought a sensa 4 KDK fan from M'sia and hope like to get recommendation for electrician/contractor to install for me.
Any recommendation? Heard KDK fan needs to balanced if not it will wobble... so if you have a good electrician/contractor , please recomend.
Appreciate.
Regards
Mine is the v60wk, and when there is wind from outside of the house, the fan will swing slightly. The yuragi function even worse, the fan will swing wildly. But I get used to it.
Edited by Coltplussport
Supercharged
One way is to drop-by a electrical shop that sell KDK ceiling fan and ask them to introduce you a contractor. Say your existing fan got problem...once get the number you can tell the contractor you need him to install the fan and then negotiate a rate from there.
Any bros got any idea how much does it cost to install a ceiling fan??
I was like quoted like $70 odd for installing
So I would like to know if anyone knows anyone (contractor)  as I want to do the following
(1) Remove existing ceiling fan with regulator with new fan and regulator
(2) Install a new ceiling fan in apartment (condo) where there is a false ceiling and tap some electricity from the lights for it
tks in advance for any inputs
Look for Erik 97977292
  • Praise 2
tks Bro..... Ill call him in the next few days once I have decided on the models
Tidy installer as got him to install 3PCs as hardly find mature guy to do this job
  On 7/18/2011 at 2:54 PM, Octopus said:
Just got reply from Capital Distributors (i.e. KDK local distributor) that the plate + ring bracket is the correct one for KDK fan.
CCMPL selling this bracket at $3 each.
Hi ..May i know CCMPL is which shop and the location? Thank you so much.
Actually there are many KDK resellers around so why need to target CCMPL if you're not already familiar with them? (can visit kdk website for their info)
BTW, if you want it cheap, get it from JB. Ceiling fan is maybe 1/2 to 2/3 the price.
Edited by Kusje
