Csbo Neutral Newbie July 12, 2011 Share July 12, 2011 Hi ALL, anyone knows how to power a blender using a battery? Or anyone is able to help me modify the blender socket head so that it can be powered using a battery pack. I need it to be portable, so can't get power from power point. Need to modify it by getting power to drive the blender using battery supply. Greatly Appreciated. Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 12, 2011 Share July 12, 2011 (edited) Use a DC to AC inverter Edited July 12, 2011 by Yeobh Link to post Share on other sites More sharing options...
SimonTan 2nd Gear July 12, 2011 Share July 12, 2011 Not possible with normal battery. Get those 12V convert to 240V converters. Can get at car accessories shop or autobeg. Then get a 12V car battery! Very messy....but if you got the desire...can be done. Link to post Share on other sites More sharing options...
Acieed 1st Gear July 12, 2011 Share July 12, 2011 I'm afraid a blender normally requires quite a lot of power, and the regular invertor such as the 120W one recommended earlier by other bros will not work. In any case, check your blender on how much current is required and look around for an invertor that can supply at least twice the capacity. Link to post Share on other sites More sharing options...
Watwheels Supersonic July 12, 2011 Share July 12, 2011 Go ask your lecturer and borrow from your poly lab lah. Link to post Share on other sites More sharing options...
Ahwhye 5th Gear July 12, 2011 Share July 12, 2011 get a UPS....fully charge it, then you are good to use it.....everything in, no need modification or wat wiring......can last how long? depend on capacity lor......portable? ehhh...on the heavy side lah, how "portable" u wan?.... Link to post Share on other sites More sharing options...
Ahwhye 5th Gear July 12, 2011 Share July 12, 2011 Oh...btw....battery pack is DC, blender is usually AC, not just modify socket niah niah hor.... if you are not even certain of this fact, you better dun try, else your name+photo appear on newspaper then not very nice liao...... Hi ALL, anyone knows how to power a blender using a battery? Or anyone is able to help me modify the blender socket head so that it can be powered using a battery pack. I need it to be portable, so can't get power from power point. Need to modify it by getting power to drive the blender using battery supply. Greatly Appreciated. Thanks! Link to post Share on other sites More sharing options...
Aimnfire 4th Gear July 12, 2011 Share July 12, 2011 Oh...btw....battery pack is DC, blender is usually AC, not just modify socket niah niah hor.... if you are not even certain of this fact, you better dun try, else your name+photo appear on newspaper then not very nice liao...... hahaha which page is that the front page or the obituary lol Link to post Share on other sites More sharing options...
Vince69 Neutral Newbie July 12, 2011 Share July 12, 2011 Hi ALL, anyone knows how to power a blender using a battery? Or anyone is able to help me modify the blender socket head so that it can be powered using a battery pack. I need it to be portable, so can't get power from power point. Need to modify it by getting power to drive the blender using battery supply. Greatly Appreciated. Thanks! Just do a search using Google, search string "portable blender battery operated", you will get a list of ideas like this one on what are the availiable blenders that are battery operated example: http://www.nextag.com/portable-blender/stores-html Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 13, 2011 Share July 13, 2011 No I didn't recomend TS to us a 120watt inverter , the picture is only an illustration.My new blender is 600watt - very powerful Link to post Share on other sites More sharing options...
Csbo Neutral Newbie July 13, 2011 Author Share July 13, 2011 Anyone knows where to buy portable blender that is battery operated? Thanks. Link to post Share on other sites More sharing options...
Adrianli Hypersonic July 13, 2011 Share July 13, 2011 Welcome to the world of r/c. I believe the battery packs we use for large r/c machines should be able to provide sufficient power for ur blender. U might even want to consider swapping the ac motor for a dc brushless motor. My "Coke Can" size motor for my r/c boat is capable of 10,000watts of power. Otherwise, get a 12V inverter from Sim Lim Tower and get a couple of 3S lipo 5000mah 30C batteries from r/c shop. Confirm to run ur blender. BTW, these are the batteries that run my motor, two of them parallel togather : Link to post Share on other sites More sharing options...
Csbo Neutral Newbie July 13, 2011 Author Share July 13, 2011 Welcome to the world of r/c. I believe the battery packs we use for large r/c machines should be able to provide sufficient power for ur blender. U might even want to consider swapping the ac motor for a dc brushless motor. My "Coke Can" size motor for my r/c boat is capable of 10,000watts of power. Otherwise, get a 12V inverter from Sim Lim Tower and get a couple of 3S lipo 5000mah 30C batteries from r/c shop. Confirm to run ur blender. BTW, these are the batteries that run my motor, two of them parallel togather : I attached 2 photos showing the blender with 2 pipes attached to it and the motor with the power socket, how to change the motor inside? And also how to connect the battery to give power to the blender? Link to post Share on other sites More sharing options...
Csbo Neutral Newbie July 13, 2011 Author Share July 13, 2011 I attached 2 photos showing the blender with 2 pipes attached to it and the motor with the power socket, how to change the motor inside? And also how to connect the battery to give power to the blender? Blender. Link to post Share on other sites More sharing options...
Adrianli Hypersonic July 13, 2011 Share July 13, 2011 I attached 2 photos showing the blender with 2 pipes attached to it and the motor with the power socket, how to change the motor inside? And also how to connect the battery to give power to the blender? Can open the casing n have a look inside??? The motor is inside the casing. Link to post Share on other sites More sharing options...
Csbo Neutral Newbie July 13, 2011 Author Share July 13, 2011 Can open the casing n have a look inside??? The motor is inside the casing. The whole thing is fixed one. I try open and let you know? Really experienced a lot of things for my project.. You know of any underwater battery operated motor? Maybe can connect shaft to the blender and motor outside in the water. Link to post Share on other sites More sharing options...
Adrianli Hypersonic July 13, 2011 Share July 13, 2011 Blender. Please dont tell me tis is ur final yr project. It looks like a home-made DIY project. U using aquarium grade Eheim-type hose n connectors??? There are proper PVC pipes n plastic valves available at hardware stores. Basic engineering, using a ball valve for regulating flow is a no-no. Please select the correct valve for the correct function. Link to post Share on other sites More sharing options...
Csbo Neutral Newbie July 13, 2011 Author Share July 13, 2011 Please dont tell me tis is ur final yr project. It looks like a home-made DIY project. U using aquarium grade Eheim-type hose n connectors??? There are proper PVC pipes n plastic valves available at hardware stores. Basic engineering, using a ball valve for regulating flow is a no-no. Please select the correct valve for the correct function. Sorry to say but it is. Yeah got those Eheim pipes and valve from Qian Hu fish farm. ↡ Advertisement Link to post Share on other sites More sharing options...
Shopee Singapore
Shopee Singapore
Need Advice on Self Storage
ALL Escalator/Elevator/Excavator related accidents!
