Oil catch tank and airbleed DIY
Stanchiam
hmm..
today fetch wife to work and back from work
found that gear 1 and 2 when i accelerate, will have voom sound, as if air is suck into the engine
can feel acceleration increased, just hope will not affect fuel consumption
higher end, no difference at all
to catch the oil(gas)
engine will be cleaner and less carbon build up
oo how does it work? where is this oil(gas) coming from? cos i wanna try something like this also
Oil catch tank looks like m/cycle fuel filter.
Most of these I saw were bigger and made of metal.
yap, it also filters
Wow...another DIY...You diy guru =)
Also saw your SP of the firewall, the dismantling of the dashboard seem complicated with so many things to remove....must have taken lots of time to do that.. [sweatdrop]
okay. care to share on your fuel consumption after you install this? btw whats your ride?
i have only installed it yesterday, today first day try out
all i can say is i like it very much, like my gear +1 level
change 2nd gear like already 3rd gear
just not sure about fuel consumption, hopefully dont increase
my ride? u mean my car?
it is the infamous flying rolling flipping qq ...lol
Edited by Stanchiam
:blink: :blink: :blink:
Btw, I would like to remind folks who install oil catch tank to do 2 things.
1. dispose the engine oil collected in the tank properly.
2. Connect the tube from the oil catch tank back to intake manifold. The reason is to reduce pollution. This is because engine oil vapour is hazardous to health (can cause cancer) and its a pollutant. It would be irresponsible to vent engine oil vapour into the atmosphere and let others breath in the fumes.
1. sure, think will be able to last at least half a year before full
2. of course must connect back to intake manifold, else will be leaking, cannot control the amount of air bleeding into engine.
For 2, not necessary. Some just seal up the hose connector at intake manifold and vent the engine vapour into the atmosphere. OF course, this prevents engine oil vapour from getting into intake, hence keeping it clean but it also means the gas is vent into atmosphere.
oh, for my car, i need air into the intake to increase torque etc
didnt know people will seal up the connector
I guess different engines work differently. For me case, I get slightly better FC w/o the hose. This is because the valve cover valve just vents hot blow by gas and engine oil into the combustion chamber. Something that is unwanted.
However, perhaps you engine is designed to get additional air from the valve since its positive pressure.
