Happily1986 5th Gear June 10, 2011 Share June 10, 2011 Different era my first computer was a Compro Pentium 3 (Katmai) 550MHz, 8MB VRAM and 64MB RAM. ↡ Advertisement Link to post Share on other sites More sharing options...
Jman888 Moderator June 10, 2011 Share June 10, 2011 I dun play PC when young cos no such thing Then in uni start to experience one from friend, that time only DOS and my first game was Larry, also in DOS when Larry was 'doing' it was 'censored' [laugh] Link to post Share on other sites More sharing options...
Davidklt Supercharged June 10, 2011 Share June 10, 2011 There is also this brand call IPC. Link to post Share on other sites More sharing options...
Cracker 1st Gear June 11, 2011 Share June 11, 2011 I believe many years back all local computer manufacturers closed down for one reason or another. the local companies closed down due to the lack of market share... up to mid 90s, pple are either buying these local brands or DIY...The local brand while provided a one stop solution..will charge a big premium if you wanted the latest graphic cards or more RAM & HDD. hence lots of pple turned toward DIY set which cost much cheaper. The big guys like IBM, HP and Dell were more interesting in the corporate biz ( at least in Spore)...Hence the DIY biz totally wiped out the local companies...I was doing self asembled set till the mid 2000s...when I decided to give up and get a set from Dell instead...Nowaday unless one is doing rocket science data crunching or those high end gamers where even the mouse or mousepad will affect the response time ....most of the mid-level model from the above brands can do the job efficiently. nowaday when I go to Sim Lim Sq,,most pple are buying routers, printers and other accessories,,,,not so much of buying a casing,,,power supply, motherboard..etc etc to DIY a system. Link to post Share on other sites More sharing options...
Yeshe Turbocharged June 11, 2011 Share June 11, 2011 3.5" ?? not 5 1/4" meh ?? ha ha ha....still got single side...double side thing... still got 8" one ok [laugh] Link to post Share on other sites More sharing options...
Yeshe Turbocharged June 11, 2011 Share June 11, 2011 I think Verbatim is the popular brand for floppy. Maxell!! Link to post Share on other sites More sharing options...
Donut Supercharged June 11, 2011 Share June 11, 2011 Alot of oldies here...... Hahahhaa!! Link to post Share on other sites More sharing options...
Tonyhawk 1st Gear June 11, 2011 Share June 11, 2011 Sample config.sys: [laugh] DEVICE=C:\Windows\HIMEM.SYS DOS=HIGH,UMB DEVICE=C:\Windows\EMM386.EXE NOEMS FILES=30 STACKS=0,0 BUFFERS=20 DEVICEHIGH=C:\Windows\COMMAND\ANSI.SYS DEVICEHIGH=C:\MTMCDAI.SYS /D:123 this brings back loads of memories.... so much time wasted on a tiny file. ↡ Advertisement Link to post Share on other sites More sharing options...
Computer advice needed
Computer repair Clementi
Singapore public servants' computers to have no Internet acc
Dell obsolete CPU
Dell obsolete CPU
Chuwi Aerobook
Chuwi Aerobook
Do you switch off you PC mains ?
Home office AIO computer
How do I repair the zipper on my Samsonite computer bag?
