Shor 1st Gear June 9, 2011 Share June 9, 2011 (edited) Recently my car tremble when it's on red light no matter I put the gear to D or N . I was wondering what went wrong. Was thinking that might be the engine mounting, what will be more likely? Any bros know? Any inputs appreciate. Thank you very much! If that's engine mounting, is it necessary to replace all four ? And what will be the costs like? Edited June 9, 2011 by Shor ↡ Advertisement Link to post Share on other sites More sharing options...
Royong Neutral Newbie June 20, 2011 Share June 20, 2011 encounter similar condition b4. The problem is the engine mount. But it is adviseable to look for specialist for your car model. Cause the mechanic (who specialise in my car model suzuki swift) recommend me to just change one of the engine mount as it is a common wear and tear for swift. if I go to other mechanic, most probably they will recommend me to change all three engine mount. Link to post Share on other sites More sharing options...
5936 1st Gear June 20, 2011 Share June 20, 2011 idling speed a bit low. For older conti car, it may be dirty idling controller. my 2 cents Link to post Share on other sites More sharing options...
Grimicer Clutched June 20, 2011 Share June 20, 2011 sounds a lot like engine mount issues, however, they have been recommendations to change all 4 engine mounts as if you change 1 engine mount and it does not solve the problem, you need to change the other 3 which is double labor charge. (and the labor charge is not cheap!) Link to post Share on other sites More sharing options...
Shor 1st Gear June 20, 2011 Author Share June 20, 2011 It's recommended to change all 3 or 4 at one time. Save the trouble and labor fee for the next time. sounds a lot like engine mount issues, however, they have been recommendations to change all 4 engine mounts as if you change 1 engine mount and it does not solve the problem, you need to change the other 3 which is double labor charge. (and the labor charge is not cheap!) Link to post Share on other sites More sharing options...
Nikamura Neutral Newbie June 20, 2011 Share June 20, 2011 It's recommended to change all 3 or 4 at one time. Save the trouble and labor fee for the next time. yep really depends on what car you driving.. for swift its always the one on the driver side that give way. but TS got experince hearing a "tock" sounds when accelerating off from stationary? if not that it might be the ignition coil gonna up the lorry too. 2 pcs of it.. not cheap to change too. Link to post Share on other sites More sharing options...
Edca 1st Gear June 20, 2011 Share June 20, 2011 I'm having this problem too. But my car just less than 3 years. How come so fast got problem? Link to post Share on other sites More sharing options...
Grimicer Clutched June 20, 2011 Share June 20, 2011 I'm having this problem too. But my car just less than 3 years. How come so fast got problem? what car are you driving? Link to post Share on other sites More sharing options...
Royong Neutral Newbie June 21, 2011 Share June 21, 2011 If ur car is less then 3 yr, do u still hv warranty? Try going bk to change for a new set for free. U nor know. Link to post Share on other sites More sharing options...
Elevatorman Neutral Newbie June 21, 2011 Share June 21, 2011 The next time it happens, take a look on the RPM, does it drop when tremble. I think engine mount should not cause RPM to drop. Recently my car tremble when it's on red light no matter I put the gear to D or N . I was wondering what went wrong. Was thinking that might be the engine mounting, what will be more likely? Any bros know? Any inputs appreciate. Thank you very much! If that's engine mounting, is it necessary to replace all four ? And what will be the costs like? Link to post Share on other sites More sharing options...
Shor 1st Gear June 21, 2011 Author Share June 21, 2011 Mine RPM did not drop. But the tremble is minor, I just leave it. Actually engine mount is very cheap, but the labor is much more Expensive. The next time it happens, take a look on the RPM, does it drop when tremble. I think engine mount should not cause RPM to drop. ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding - November 2024
Join us on a curated driving adventure for car enthusiasts! 🚗 Sgcarmart Adventures: Car Factories from Past to Present - 24 November 2024
Buying a Consignment Car
Man who evaded taxes on over 1,800 imported vehicles gets jail in default of S$6 million fine
Our car community ❤️🚗
Bid for car registration number
