SimplyTWL 1st Gear June 5, 2011 Share June 5, 2011 For worn engine mounting, strong engine vibration is felt at idle position. For my case, each time i stop for a red light with gear in D (Mine's an AT) the vibration is very strong. You can feel your dashboard, steerling wheel and chairs vibrating.. However the vibration is lessen when gear is engaged in N or P. Got my mounting checked at two workshop and they confirmed that it is the mounting that is worn out. Went to get the mounting from stockie and get it installed at workshop. Hope that helps. ↡ Advertisement Link to post Share on other sites More sharing options...
13177 Hypersonic June 5, 2011 Share June 5, 2011 Symptoms of worn engine mount confirm is strong engine vibration at idle or even when your car is coming to a slow, you will feel your steering wheel and even dashboard area is vibrating. Just have the mounting change and all vibration will be gone. Link to post Share on other sites More sharing options...
Remixes Clutched June 5, 2011 Share June 5, 2011 if u on coilover set the damping to the softest ,before that 2 -3clicks harder and it feels like my mounting gone. 2nd if u throttle body dirty ,car feel sluggish some vibration might occured. today i did these 2 steps car feel better. Link to post Share on other sites More sharing options...
Yuan 6th Gear June 5, 2011 Share June 5, 2011 Thanks guys for the experience..but stick to topic ok? Okay. Sorry for the drift. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear June 5, 2011 Share June 5, 2011 Please share... thanks! Sometimes engine/car obviously shook more than usual when starting/stopping engine. ↡ Advertisement Link to post Share on other sites More sharing options...
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
My engine after 150,000 kms
