13177 Hypersonic April 20, 2022 Share April 20, 2022 57 minutes ago, Jman888 said: I installed one for main door but not the gate as we usually dun lock the gate. Then my mum being old folk who dun use the digital lock will sometime lock the gate and we a bit headache cos we dun bring keys and got locked out if no one at home If you use digital lock for gate and door, then your mum would not lock for both liao, then your house would become open house?! Lol. ↡ Advertisement Link to post Share on other sites More sharing options...
Ghgan 6th Gear April 20, 2022 Share April 20, 2022 32 minutes ago, Jman888 said: the one I installed no need to drill hole, just tap on existing lock. If no battery can still use key, problem is we dun bring keys out anymore, thought of leaving a set of keys in the shoes cabinet outside but then defeat the purpose Just put the spare key inside your car, and 1 more with your neighbor, inlaw or parents. Or like my friend use blue tack and paste it inside the riser behind the water or gas pipe, flower pots or any location nearby that is not easily found, but like you said defeat the purposes for determine thief. Link to post Share on other sites More sharing options...
13177 Hypersonic April 20, 2022 Share April 20, 2022 24 minutes ago, Ghgan said: Just put the spare key inside your car, and 1 more with your neighbor, inlaw or parents. Or like my friend use blue tack and paste it inside the riser behind the water or gas pipe, flower pots or any location nearby that is not easily found, but like you said defeat the purposes for determine thief. The places you mentioned all quite common for people to hide their keys le, so not difficult to find. Lol. Link to post Share on other sites More sharing options...
mersaylee Hypersonic April 20, 2022 Share April 20, 2022 21 minutes ago, 13177 said: The places you mentioned all quite common for people to hide their keys le, so not difficult to find. Lol. The key to happiness is in the pants...just saying 😁 2 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged April 21, 2022 Share April 21, 2022 On 4/20/2022 at 11:28 AM, inlinesix said: For padlock, you can do that. There is a battery status on app. No worry about no power. For August (Main Door), need a physical key to do that. Is it easy to replace for hdb lock set? Link to post Share on other sites More sharing options...
inlinesix Hypersonic April 21, 2022 Share April 21, 2022 23 minutes ago, Sdf4786k said: Is it easy to replace for hdb lock set? Only the inside mechanism is replaced. Not difficult. 1 Link to post Share on other sites More sharing options...
gallenong Neutral Newbie May 3, 2022 Share May 3, 2022 2022 Best Selling Digital lock in Singapore, Epic 5G smartphone digital lock Something affordable with all the function you need , comes along with 1+2 years warranty or 5 year warranty Top 5 function 1. 100 fingerprint 2. Program up to 20 cards, 4 given 3. Password 4. Guest pin , one time pin through mobile app 5. Bluetooth/Wifi unlock remotely (wifi bridge$50) Door Digital lock + Gate Digital lock Bundle Promotion!!!!!! 1. $550 for Satin Gold Card 2. $799 for Epic 5G space grey 3. $849 for Epic 5G satin gold (Best Seller) 4. $1199 for Epic 5G 24K gold platted Gate design up to 1000+ you can choose 1. 3x7 HDB gate $680 only! 2. 4x7 HDB door $780 only! Maindoor Laminate up to 1000+ you can choose 1. 3x7 Solid premium Laminate Main door $899 only! 2. 4x7 Solid premium Laminate Maindoor $1299 only! Need Fire rated add $400 only! Less $100 with purchase of main door and less $100 with purchase of My President Hotel quality mattress Order Now and get it today 82800035 Gallen(is me) (24/7) speak English and Mandarin Link to post Share on other sites More sharing options...
Dp26 5th Gear August 28, 2022 Share August 28, 2022 Think my digital lock is faulty le. Existing is Samsung push pull one Any good recommendations for a repairman? Or any cheap good lock for replacement? Link to post Share on other sites More sharing options...
Rayleigh 6th Gear August 28, 2022 Share August 28, 2022 3 hours ago, Dp26 said: Think my digital lock is faulty le. Existing is Samsung push pull one Any good recommendations for a repairman? Or any cheap good lock for replacement? For me, it is my existing samsung lock for gate: SH1321. Although i changed to new alkaline battery, occasionally it cant trigger the lock mode. In short, when i close the gate, the lock is NOT actuated and gives out a short buzzer. Most of the times it is ok. Anyway, i gottten an identical spare model from Lazada recently. Will replace it if really kong. Link to post Share on other sites More sharing options...
Kopites Supersonic August 28, 2022 Share August 28, 2022 42 minutes ago, Rayleigh said: For me, it is my existing samsung lock for gate: SH1321. Although i changed to new alkaline battery, occasionally it cant trigger the lock mode. In short, when i close the gate, the lock is NOT actuated and gives out a short buzzer. Most of the times it is ok. Anyway, i gottten an identical spare model from Lazada recently. Will replace it if really kong. Try use 50% (4 batt) batt instead of the full 8 batt capacity. There is a reset pinhole. Those phone pin will do. Poke and hold a few seconds for it to reset. I have the same issue as your few months back. Change to 50% or 75% loaded batt capacity. Reset the with pin and verything working fine now. 1 Link to post Share on other sites More sharing options...
Ghgan 6th Gear August 28, 2022 Share August 28, 2022 Can consider this Unicor brand direct replacement for samsung https://shopee.sg/Fingerprint-Push-pull-Digital-lock-Push-from-outside-Replacement-for-Samsung-Unicor-Made-in-Korea-i.443357476.5794365108 8 hours ago, Dp26 said: Think my digital lock is faulty le. Existing is Samsung push pull one Any good recommendations for a repairman? Or any cheap good lock for replacement? 2 Link to post Share on other sites More sharing options...
Rayleigh 6th Gear August 28, 2022 Share August 28, 2022 6 hours ago, Kopites said: Try use 50% (4 batt) batt instead of the full 8 batt capacity. There is a reset pinhole. Those phone pin will do. Poke and hold a few seconds for it to reset. I have the same issue as your few months back. Change to 50% or 75% loaded batt capacity. Reset the with pin and verything working fine now. Thanks bro. Will give it a try. Link to post Share on other sites More sharing options...
Sadan 6th Gear August 28, 2022 Share August 28, 2022 @Dp26 You can try Interlock. Seems like they do repair for Samsung push-pull lock https://www.interlock.com.sg/repair-service-for-samsung-gateman-yale-kaba-digital-lock.html I engaged them previously to install Xiaomi/ Lock-in lockset. So far, happy with their service and the lockset. Can consider replacing with Gateman for a cheaper and simpler lockset. 1 Link to post Share on other sites More sharing options...
Kopites Supersonic August 28, 2022 Share August 28, 2022 2 minutes ago, Sadan said: @Dp26 You can try Interlock. Seems like they do repair for Samsung push-pull lock https://www.interlock.com.sg/repair-service-for-samsung-gateman-yale-kaba-digital-lock.html I engaged them previously to install Xiaomi/ Lock-in lockset. So far, happy with their service and the lockset. Can consider replacing with Gateman for a cheaper and simpler lockset. What is the price range? 1k plus can get a new replacement set. Link to post Share on other sites More sharing options...
Sadan 6th Gear August 28, 2022 Share August 28, 2022 @Kopites No idea on the repair cost. May wish to contact them directly for quote. I only engage them previously for installation of new lockset. 😊 Link to post Share on other sites More sharing options...
Kopites Supersonic August 28, 2022 Share August 28, 2022 7 hours ago, Sadan said: @Kopites No idea on the repair cost. May wish to contact them directly for quote. I only engage them previously for installation of new lockset. 😊 Thanks. Not at the moment. As mentioned current set after I have done the manual reset is working fine now. Probably would keep the option to repair as an alternative if prices is reasonable. 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic August 29, 2022 Share August 29, 2022 After looking high and low for slim digital lock for gate, i gave up. Instead, I use digital padlock. $180. 2 Link to post Share on other sites More sharing options...
Dp26 5th Gear August 29, 2022 Share August 29, 2022 Called Samsung and also 3rd party locksmith. Samsung side is “kill people put fire” come down charge $100 for labour and transport. $120 for after office hours. change the mechanism or motherboard charge another ~$120. 3rd party locksmith recommended by Samsung can come down in 2 hrs but charge another $50 more. 😭 called 3rd party they don’t have the spare parts on hand so need onsite verification and also downtime to order. If can repair they charge around $130. No guarantees on success of repair also really first world problem ↡ Advertisement Link to post Share on other sites More sharing options...
Door Protector Stripes, an important exterior feature against dings?
Pedal Lock & Auto Lock
Digital IC in Singpass app
Window grill lock
Window grill lock
