Vice78 Neutral Newbie October 15, 2011 Share October 15, 2011 I've used the Pioneer before. Pretty decent. Can consider. ↡ Advertisement Link to post Share on other sites More sharing options...
GinoDavis Neutral Newbie April 10, 2018 Share April 10, 2018 Myvi 1.5 adv user herePlanning to get one underseat sub.Current setupFactory touch screen HUFront speakers replaced with JBL CS762 2 way coaxial.Rear door speaker: 6" stockWith this setup bass is too low at volume 15I have no plan to change HU or addin amplifier. The current HU is capable of delivering 20W RMS X4Can someone help to chose from below.Kenwood KSC-SW11PioneerTS-WX120ADB drive euphoria EPS 8Tq Link to post Share on other sites More sharing options...
Nicholas 5th Gear April 10, 2018 Share April 10, 2018 Myvi 1.5 adv user here Planning to get one underseat sub. Current setup Factory touch screen HU Front speakers replaced with JBL CS762 2 way coaxial. Rear door speaker: 6" stock With this setup bass is too low at volume 15 I have no plan to change HU or addin amplifier. The current HU is capable of delivering 20W RMS X4 Can someone help to chose from below. Kenwood KSC-SW11 PioneerTS-WX120A DB drive euphoria EPS 8 Tq Can't go wrong with Kenwood n Pioneer, not sure about DB. I have a Ksc-Sw01, used for 7 years already. Link to post Share on other sites More sharing options...
GinoDavis Neutral Newbie April 13, 2018 Share April 13, 2018 Can't go wrong with Kenwood n Pioneer, not sure about DB. I have a Ksc-Sw01, used for 7 years already. To for replying Do you remember how the sub amp powered. Is it directly from battery? Link to post Share on other sites More sharing options...
Nicholas 5th Gear April 13, 2018 Share April 13, 2018 To for replying Do you remember how the sub amp powered. Is it directly from battery? Of course. I recently moved it to new car myself. Wife say cannot buy new one cause still working, haha! It's very easy. Yellow or red wire power wire from sub tap to fuse box (or battery) under glove box like dashcam. Blue from sub go behind headunit to Amp power on (blue/white), that is to tell the sub to turn on when headunit turn on. Then connect 2 rcas to back of headunit's subwoofer out. Above is for without Amp. Other than power and ground, all of my cables connect to amp so easier to install. Actually all instructions can be found in manual but most more or less same. Just double check the color codes. Link to post Share on other sites More sharing options...
GinoDavis Neutral Newbie April 13, 2018 Share April 13, 2018 I see the sub draws 8.5 A. So is it better to connect to battery or incase if we are taping from fuse box, which fuse to use Link to post Share on other sites More sharing options...
Nicholas 5th Gear April 13, 2018 Share April 13, 2018 (edited) I assume you have the KSC-SW11 where the max consumption is stated 8.5A. From factory it uses a 10A fuse so it's safe to tap to a 10A fuse. As for which ones, depends on your car which component uses 10A? Then choose one that is non critical like rear wiper, cigarette lighter socket, car audio..etc. Before you do all these, disconnect the car battery's negative first. Edited April 13, 2018 by Nicholas Link to post Share on other sites More sharing options...
GinoDavis Neutral Newbie April 15, 2018 Share April 15, 2018 I assume you have the KSC-SW11 where the max consumption is stated 8.5A. From factory it uses a 10A fuse so it's safe to tap to a 10A fuse. As for which ones, depends on your car which component uses 10A? Then choose one that is non critical like rear wiper, cigarette lighter socket, car audio..etc. Before you do all these, disconnect the car battery's negative first. Thanks. Really helped Link to post Share on other sites More sharing options...
GinoDavis Neutral Newbie April 19, 2018 Share April 19, 2018 I assume you have the KSC-SW11 where the max consumption is stated 8.5A. From factory it uses a 10A fuse so it's safe to tap to a 10A fuse. As for which ones, depends on your car which component uses 10A? Then choose one that is non critical like rear wiper, cigarette lighter socket, car audio..etc. Before you do all these, disconnect the car battery's negative first. Hi one more doubt. since my stock head unit does not come with RCA out, need to splice from the speaker wire. is it necessary to use Hi-Low converter? Link to post Share on other sites More sharing options...
Nicholas 5th Gear April 19, 2018 Share April 19, 2018 Hi one more doubt. since my stock head unit does not come with RCA out, need to splice from the speaker wire. is it possible necessary to use Hi-Low converter? You can get something like this: Link to post Share on other sites More sharing options...
Nicholas 5th Gear April 19, 2018 Share April 19, 2018 Or this I guess you can also cut a RCA up but I've never tried before so I can't advice on that. Link to post Share on other sites More sharing options...
GinoDavis Neutral Newbie April 20, 2018 Share April 20, 2018 Or this mKZEbD8eq90RZS_SVPypoeA.jpg I guess you can also cut a RCA up but I've never tried before so I can't advice on that. Thanks alot Link to post Share on other sites More sharing options...
Nicholas 5th Gear April 20, 2018 Share April 20, 2018 Thanks alot Today I go tidy up my cables, there's a chance no need RCA. I think can just splice to the sub harness itself. Sorry if I gave wrong above earlier. Link to post Share on other sites More sharing options...
andrewyewkc 5th Gear April 23, 2018 Share April 23, 2018 Can someone help to chose from below. Kenwood KSC-SW11 PioneerTS-WX120A DB drive euphoria EPS 8 Tq The TS-WX120A has been replaced by the TS-WX-130DA with a slight increase in power. https://www.pioneer-car.eu/uk/products/ts-wx130da Link to post Share on other sites More sharing options...
Salnts 2nd Gear November 17, 2018 Share November 17, 2018 The TS-WX120A has been replaced by the TS-WX-130DA with a slight increase in power. https://www.pioneer-car.eu/uk/products/ts-wx130da I wanted to check with you guys I am new to ICE recently I changed my speakers and. Added a pioneer amp(GM-A6704) and today I decided to add an active amp to make the sound fuller (TS-WX-130DA) One thing is I have no idea what do I need to set on the remote eg: freq, deeep/dynmaic bass etc One thing I noticed was the installer just connected the sub directly to my HU( JVC V230BT) wouldn’t there be a need to connect to my existing amp? Can someone share or tell me how should I set all these parameters on my active sub and on my HU. I am driving an attrage. Thanks Link to post Share on other sites More sharing options...
andrewyewkc 5th Gear November 17, 2018 Share November 17, 2018 I wanted to check with you guys I am new to ICE recently I changed my speakers and. Added a pioneer amp(GM-A6704) and today I decided to add an active amp to make the sound fuller (TS-WX-130DA) One thing is I have no idea what do I need to set on the remote eg: freq, deeep/dynmaic bass etc One thing I noticed was the installer just connected the sub directly to my HU( JVC V230BT) wouldn’t there be a need to connect to my existing amp? Can someone share or tell me how should I set all these parameters on my active sub and on my HU. I am driving an attrage. Thanks Your active sub-woofer has its own built-in amplifier, that is why the installer can connect it directly to your HU. 1 Link to post Share on other sites More sharing options...
Salnts 2nd Gear November 17, 2018 Share November 17, 2018 Your active sub-woofer has its own built-in amplifier, that is why the installer can connect it directly to your HU. i see. thank you andrew for your reply.. what are the usual settings i should set? 1) deep bass vs dynamic 2) frequency to set? Link to post Share on other sites More sharing options...
andrewyewkc 5th Gear November 18, 2018 Share November 18, 2018 i see. thank you andrew for your reply.. what are the usual settings i should set? 1) deep bass vs dynamic 2) frequency to set? I am not an audiophile so some sifu will be able to give you better advice. Deep bass or dynamic will depend on the type of music that you are playing. As for frequency, this article might help: https://www.svsound.com/blogs/svs/tips-for-setting-the-proper-crossover-frequency-for-a-subwoofer For me, my installer just set everything and I only ask him to reduce the bass as I found it too strong. So as long as it sounds good to you, it is good. https://www.pioneerelectronics.com/PUSA/Car/Subwoofers/Powered+Subwoofer/TS-WX130DA#manuals ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Income tax Evasion
Income tax Evasion
Recommend me a hotel in Hangzhou
Car seat covers
Car seat covers
Migrating down under? Come share your experiences
