yangae Neutral Newbie December 19, 2018 Share December 19, 2018 For those still looking, the alternative I found is this "count-down" timer from RS components: https://sg.rs-online.com/web/p/surface-mount-time-switches/8215045/ Installed in two places, works well, reliable. Only drawback is the LED light is on all the time - so if you are sensitive to light in a dark bedroom, this may annoy you.. RS components has always given me really good customer service, so can buy with confidence. Hi, Thanks very much for your input. Indeed, since Seng Leong Development (SL) was struck off, there are no simple "layman" timer control for hot water storage heater. Yours is a great suggestion. What is your experience using this RS surface mount time switch as it is rated at 1000W whilst most storage heater is 3000W, do you face any issue using this with your water heater ? There are other RS switches that support 16A and 3000W but they are not exactly countdown in nature. Thanks again, great post. Regards .. Yangae ↡ Advertisement Link to post Share on other sites More sharing options...
Looking for storage space ...
Family of three electrocuted to death at Taman Jurong
