Aaronlkl Supersonic April 18, 2011 Share April 18, 2011 HAs anyone tried both? Inverter really save energy? ↡ Advertisement Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged April 18, 2011 Share April 18, 2011 Confirmed save more energy and $ Link to post Share on other sites More sharing options...
Kb27 Supersonic April 18, 2011 Share April 18, 2011 I have both. It seems the non-inverter one but with more energy saving stars use less energy. Link to post Share on other sites More sharing options...
Deathism Neutral Newbie April 18, 2011 Share April 18, 2011 I read a couple of articles online which mentioned that tangible savings comes only when the air-con operates for a prolonged period of time in a day. However, if it is used for just a couple of hours a day, the savings will be negligible and in actuality will be negated by the higher selling price of an inverter unit. The article provided some calculations though i cant recall if it was in a local context. Are these really true? Can someone who have used both inverter and non inverter units, comment? Link to post Share on other sites More sharing options...
Aaronlkl Supersonic April 18, 2011 Author Share April 18, 2011 I have both. It seems the non-inverter one but with more energy saving stars use less energy. Hi, u mean the non-inverter one save more energy? Link to post Share on other sites More sharing options...
Kb27 Supersonic April 18, 2011 Share April 18, 2011 Hi, u mean the non-inverter one save more energy? I had a Fujitsu inverter 1-split for a couple of years. Then I added a 2nd Sanyo non-inverter 1-split. This one has more "stars" rated. It seems the electrical bill didn't go up more than 2x. My usage for both is about 10 hrs each day. I would suggest you just get the normal one with more energy saving stars instead of an inverter type, if the cost is too high. Link to post Share on other sites More sharing options...
Alim 1st Gear April 18, 2011 Share April 18, 2011 Whether inverter or non-inverter, I think with proper maintenance and temp set at 25 or more, any aircon shd be able to cool the room efficiently and save electricity. Link to post Share on other sites More sharing options...
Babyt 4th Gear April 18, 2011 Share April 18, 2011 buy inverter if u need to switch on more than 1 aircon at the same time. otherwise, a non inverter will do. Link to post Share on other sites More sharing options...
Aaronlkl Supersonic April 18, 2011 Author Share April 18, 2011 I had a Fujitsu inverter 1-split for a couple of years. Then I added a 2nd Sanyo non-inverter 1-split. This one has more "stars" rated. It seems the electrical bill didn't go up more than 2x. My usage for both is about 10 hrs each day. I would suggest you just get the normal one with more energy saving stars instead of an inverter type, if the cost is too high. Am i right to say that your Fujitsu inverter has 4 ticks while the Sanyo non-inverter has 3 but both seems to be almost equally energy efficient? Link to post Share on other sites More sharing options...
Kb27 Supersonic April 18, 2011 Share April 18, 2011 Am i right to say that your Fujitsu inverter has 4 ticks while the Sanyo non-inverter has 3 but both seems to be almost equally energy efficient? I can't remember how many ticks the Fuji has. I only know I didn't get the "savings" I was hoping for. But I think nowadays, just look for those with more ticks and it should be quite efficient. Link to post Share on other sites More sharing options...
Happily1986 5th Gear April 18, 2011 Share April 18, 2011 do you notice your electricity bills going down after switching to inverter type? Mine didn't. I have this impression that the Power Company do bill projection. Do they really charge you for what you use? Link to post Share on other sites More sharing options...
Tom_kkh 1st Gear April 18, 2011 Share April 18, 2011 Whether inverter or non-inverter, I think with proper maintenance and temp set at 25 or more, any aircon shd be able to cool the room efficiently and save electricity. set at 25? might as well use fan. my air con never goes above 21. Link to post Share on other sites More sharing options...
Whathefish 5th Gear April 18, 2011 Share April 18, 2011 HAs anyone tried both? Inverter really save energy? Ultimately depends on your usage.....just like getting a hybrid car..if your mileage is very low..wat is the point of paying so much for the technology to save fuel. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear April 18, 2011 Share April 18, 2011 Inverter is good for those who uses the air-con often, and also 2-3 rooms at various loads. Inverter is similar to variable frequencies....it varies the fan coil performance according to number of rooms in use. Non-inverter will operate at the same speed, no matter 2-3 rooms are in use. So if only one room is in use, then the non-inverter one will be 'over' sized and wasting electricity. Anyway...how long can a typical air-con system last? 5 years or 10 years? My parents house, unit is already 8 years old (seldom use...mainly during CNY). Do you think its time to change to a inverter type? Link to post Share on other sites More sharing options...
marwing 1st Gear April 18, 2011 Share April 18, 2011 set at 25? might as well use fan. my air con never goes above 21. You are like my neighbour downstair. Open air-con big big. My floor very cold due to my neighbour's air-con downstair. I use sponge mattress type to sleep, shiok shiok. Free cooling. Link to post Share on other sites More sharing options...
Deathism Neutral Newbie April 18, 2011 Share April 18, 2011 i wouldn't if i were you. at least wait till the current one conks out. Link to post Share on other sites More sharing options...
Cdior 1st Gear April 18, 2011 Share April 18, 2011 Whether inverter or non-inverter, I think with proper maintenance and temp set at 25 or more, any aircon shd be able to cool the room efficiently and save electricity. ki siao. set 25... u r really wasting $. haha Link to post Share on other sites More sharing options...
Fooblack Supercharged April 18, 2011 Share April 18, 2011 price bet inverter and non-inverter should be $800 - $1k plus. The savings depend on the usage. you need to ask yourself (or a honest seller) whether your usage will be heavy enough to cover the the upfront higher price. recently, I bought a system 4 daikin non-inverter (3 ticks). The seller asked me not to get a inverter since at most, I will be switching on the aircon for 1 room for about 8hrs daily. Most of the time, will be hapzard usage for the other rooms. Unless using 2 or more rooms for more than 10 hrs per day, he will then recommend the inverter instead. ↡ Advertisement Link to post Share on other sites More sharing options...
In-Car Power Inverter - Safe or Not?
Where to buy a DC / AC Power Inverter Adapter for my car?
Inverter Air Con System3
Everything Inverter?
Where to get a gd car inverter?
