Vinceh 1st Gear April 12, 2011 Share April 12, 2011 intend to do some DIY and spray paint some of my panels, dashboard etc... may i know where i can get a good selection and to buy 1) spray paints 2) primer 3) various level of sandpaper thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Vinceh 1st Gear April 16, 2011 Author Share April 16, 2011 anyone any ideas? Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear April 16, 2011 Share April 16, 2011 Check with paint shops. Some hardware shops also carry such goods. Link to post Share on other sites More sharing options...
Fennmax Clutched April 27, 2011 Share April 27, 2011 Mustafa Link to post Share on other sites More sharing options...
Kinrad Neutral Newbie May 30, 2011 Share May 30, 2011 Hi In the United States there is PPG paint and Dupont paint including several others But those two are the best for me for a primer use a Valspar DTM 2000 and for a sand paper use a fine wet-or-dry paper it works wonders go to your local auto body shop and check if they have any in stock hope this helps!! Link to post Share on other sites More sharing options...
AngelinaS31 Neutral Newbie July 14, 2011 Share July 14, 2011 Krylon product is the best spray paint in color, i had also used it has given me a good result Link to post Share on other sites More sharing options...
Johnnyx1257 Neutral Newbie August 31, 2011 Share August 31, 2011 autopaintexpress.com has a good selection i bought touch up spray paint for my is through them they als carry all of the items you need to go along with the paint Link to post Share on other sites More sharing options...
Moredhel 2nd Gear August 31, 2011 Share August 31, 2011 intend to do some DIY and spray paint some of my panels, dashboard etc... may i know where i can get a good selection and to buy 1) spray paints 2) primer 3) various level of sandpaper thanks! Do get the high temp paints and dry every coat. Most hardware shops should have paints primers and sand paper. I get mine from serangoon north hardware shops, homely and johnsons'. Do remember when spray painting, haste makes waste. Oh btw, you might wanna get some solvent cleaner too. Link to post Share on other sites More sharing options...
Steveb123 Neutral Newbie September 26, 2011 Share September 26, 2011 (edited) There are various way to find spray paints workshop OR shop in Singapore. I would suggest "Nippon Paint" you can find varieties of spray paints and paints works. Edited September 26, 2011 by Steveb123 Link to post Share on other sites More sharing options...
Iamtheone 1st Gear September 26, 2011 Share September 26, 2011 intend to do some DIY and spray paint some of my panels, dashboard etc... may i know where i can get a good selection and to buy 1) spray paints 2) primer 3) various level of sandpaper thanks! The 'normal' spray paint sold in hardware store might not be lasting when used on Plastic panel. Link to post Share on other sites More sharing options...
Alexxx Clutched October 27, 2011 Share October 27, 2011 try hougang / Defu lane industrial area...there's a shop call Hock Lee Seng. paint shop..they might have computer mixed paint for you. thus wide selection. they can only hand mix the paint to your desired color. wide selection of sandpaper as well drawback is that you need your own spray cannister.... East side you can try Asia Paint in Euno industrial park area Link to post Share on other sites More sharing options...
Fastfive1 5th Gear October 27, 2011 Share October 27, 2011 try hougang / Defu lane industrial area...there's a shop call Hock Lee Seng. paint shop..they might have computer mixed paint for you. thus wide selection. they can only hand mix the paint to your desired color. wide selection of sandpaper as well drawback is that you need your own spray cannister.... East side you can try Asia Paint in Euno industrial park area So they can custom a paint color you want and put it into a spray can? Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear October 27, 2011 Share October 27, 2011 Can check with paint shops in your vicinity. Some hardware shops also do sell paint. Link to post Share on other sites More sharing options...
Alexxx Clutched October 28, 2011 Share October 28, 2011 So they can custom a paint color you want and put it into a spray can? they can custom the paint color u want...not sure if they rent u the can or u must have ur own.. industrial area ones have automotive paints...neighbourhood ones are mostly normal paint for wood or wall Link to post Share on other sites More sharing options...
Fastfive1 5th Gear October 28, 2011 Share October 28, 2011 they can custom the paint color u want...not sure if they rent u the can or u must have ur own.. industrial area ones have automotive paints...neighbourhood ones are mostly normal paint for wood or wall so the spray can is similar to the one that nippon paint produces? Link to post Share on other sites More sharing options...
Alexxx Clutched October 28, 2011 Share October 28, 2011 those can ones have limited color...the industrial custom ones they make for workshop to respray accident cars etc i doubt nippon ones are as good quality tho compare to customer automotive ones Link to post Share on other sites More sharing options...
Fastfive1 5th Gear October 28, 2011 Share October 28, 2011 those can ones have limited color...the industrial custom ones they make for workshop to respray accident cars etc i doubt nippon ones are as good quality tho compare to customer automotive ones I'm looking to do a custom color in a spray can similar to the one the nippon paint has. As in the color is custom but it's contained in a similar can like the one nippon spray paints come in. So that particular shop you mentioned earlier does this? Link to post Share on other sites More sharing options...
Alexxx Clutched October 28, 2011 Share October 28, 2011 I'm looking to do a custom color in a spray can similar to the one the nippon paint has. As in the color is custom but it's contained in a similar can like the one nippon spray paints come in. So that particular shop you mentioned earlier does this? i have never asked but i see lots of custom paint cans on their shelf..the size are not the usual spray paint size but 1liter size..u can call them and ask Contact Feel free to contact our friendly people for any sale queries. Office no. : 6282 6601 Fax no. : 6285 3056 Email : [email protected] Address : Block 37 Defu Lane 10 #01-43 Singapore 539214 Hours : Mondays to Fridays 8.30 am to 6.00 pm : Saturdays 8.30 am to 5.00 pm : Sundays and Public Holidays ↡ Advertisement Link to post Share on other sites More sharing options...
Where to buy canvas cloth to cover entire car?
Where to modify seat rail/bracket?
Where to mod fuel needle?
Where to get those plastics that allow your to stick the road tax/decal on screen
Wheel Spacer, where to buy?
Where you cut your hair?
Going to Batam. Where to park overnight ?
