Santafe 1st Gear March 29, 2011 Share March 29, 2011 Hi folks, I start this thread to share with you the test I did on a SDHC Kingston SD Card, 16GB Class 4 Test finished without errors. You can now delete the test files *.h2w or verify them again. Writing speed: 12.7 MByte/s Reading speed: 17.1 MByte/s H2testw v1.4 Below the results are done using a Transcend SDHC Class 10 16GB card. Test finished without errors. You can now delete the test files *.h2w or verify them again. Writing speed: 12.5 MByte/s Reading speed: 20.3 MByte/s H2testw v1.4 As owners of in car camera owner, I believe you want to have a good writing speed SD card to record your HD or Full HD video. I owned both class 4 and class 10, in terms of writing speed is the MOST important factor to record HD videos and I don't think see significant increase in writing speed except for the READING SPEED. There again, is it really worth getting the fastest class 10 SD card where the performance of writing is almost on PAR with class 4??? Anyone can share their thoughts? ↡ Advertisement Link to post Share on other sites More sharing options...
Parkingidiot 1st Gear March 29, 2011 Share March 29, 2011 class 10s are very very expensive!! Link to post Share on other sites More sharing options...
Parkingidiot 1st Gear March 29, 2011 Share March 29, 2011 there is a new type of SDHC card.. specially for VIDEO: SanDisk Link to post Share on other sites More sharing options...
Lurpsexx 6th Gear March 29, 2011 Share March 29, 2011 there is a new type of SDHC card.. specially for VIDEO: SanDisk Link to post Share on other sites More sharing options...
Ohlins Neutral Newbie March 29, 2011 Share March 29, 2011 i am using this, class 4... Link to post Share on other sites More sharing options...
Sky_vinz Clutched March 30, 2011 Share March 30, 2011 (edited) Ohlins: Roughly how much does it cost? If my in-car camera can support up to 32gb, is it really ok to stretch it up to 32gb? Or just 16gb? Will it be too much of a memory load? Edited March 30, 2011 by Sky_vinz Link to post Share on other sites More sharing options...
Vulcann 6th Gear March 30, 2011 Share March 30, 2011 there is a new type of SDHC card.. specially for VIDEO: SanDisk Link to post Share on other sites More sharing options...
Ben5266 Supercharged March 30, 2011 Share March 30, 2011 Hi folks, I start this thread to share with you the test I did on a SDHC Kingston SD Card, 16GB Class 4 Test finished without errors. You can now delete the test files *.h2w or verify them again. Writing speed: 12.7 MByte/s Reading speed: 17.1 MByte/s H2testw v1.4 Below the results are done using a Transcend SDHC Class 10 16GB card. Test finished without errors. You can now delete the test files *.h2w or verify them again. Writing speed: 12.5 MByte/s Reading speed: 20.3 MByte/s H2testw v1.4 As owners of in car camera owner, I believe you want to have a good writing speed SD card to record your HD or Full HD video. I owned both class 4 and class 10, in terms of writing speed is the MOST important factor to record HD videos and I don't think see significant increase in writing speed except for the READING SPEED. There again, is it really worth getting the fastest class 10 SD card where the performance of writing is almost on PAR with class 4??? Anyone can share their thoughts? Please try to test Sandisk class 4 and share with us the result. Maybe it could achieve 15MBps as claimed. I find it is faster than Kingston class 4 in my D90. Link to post Share on other sites More sharing options...
Santafe 1st Gear March 30, 2011 Author Share March 30, 2011 ok. Will test and post later. Link to post Share on other sites More sharing options...
Kingkong 5th Gear March 30, 2011 Share March 30, 2011 Just a thought : Could it be that the recorder had max-ed out its writing capability? Link to post Share on other sites More sharing options...
Parkingidiot 1st Gear March 30, 2011 Share March 30, 2011 Bro is this available in Sg oredi? Any idea the cost? dunno bro... i just grab this info from the web. But I saw the prices there quote about $100 Link to post Share on other sites More sharing options...
Ohlins Neutral Newbie March 30, 2011 Share March 30, 2011 Ohlins: Roughly how much does it cost? If my in-car camera can support up to 32gb, is it really ok to stretch it up to 32gb? Or just 16gb? Will it be too much of a memory load? Bro, 44 bucks from sim lim sq... I use 16 gb cos enough for my DOD900.... 10 mins per clip average 550 mb Link to post Share on other sites More sharing options...
Santafe 1st Gear March 30, 2011 Author Share March 30, 2011 Test finished without errors. You can now delete the test files *.h2w or verify them again. Writing speed: 4.75 MByte/s Reading speed: 9.87 MByte/s H2testw v1.4 Above tested on Sandisk 16gb class 4. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear March 30, 2011 Share March 30, 2011 Are you testing newly formatted cards? If no you might have to in order to get proper read-write speeds. Link to post Share on other sites More sharing options...
Santafe 1st Gear March 31, 2011 Author Share March 31, 2011 Yes, all cards are formatted before test. As the s/w will write on the card full memory to test out the speed. Link to post Share on other sites More sharing options...
Ben5266 Supercharged March 31, 2011 Share March 31, 2011 Test finished without errors. You can now delete the test files *.h2w or verify them again. Writing speed: 4.75 MByte/s Reading speed: 9.87 MByte/s H2testw v1.4 Above tested on Sandisk 16gb class 4. Thanks. That's very bad performance! Maybe the one I am using is 8GB. Link to post Share on other sites More sharing options...
Vulcann 6th Gear March 31, 2011 Share March 31, 2011 dunno bro... i just grab this info from the web. But I saw the prices there quote about $100 HOOOOOOLLY.... Give it a miss for the time being then Link to post Share on other sites More sharing options...
Santafe 1st Gear March 31, 2011 Author Share March 31, 2011 Below are the thoses tests I had done and complie. SDHC Kingston 16GB- Class 4 (1st test) Test finished without errors. You can now delete the test files *.h2w or verify them again. Writing speed: 13.5 MByte/s Reading speed: 18.4 MByte/s H2testw v1.4 SDHC Kingston 16GB- Class 4 (2nd test) Test finished without errors. You can now delete the test files *.h2w or verify them again. Writing speed: 13.5 MByte/s Reading speed: 18.5 MByte/s H2testw v1.4 Transcend Micro SD Card 8GB- Class 6 (1st Test) Warning: Only 7638 of 7639 MByte tested. Test finished without errors. You can now delete the test files *.h2w or verify them again. Writing speed: 17.6 MByte/s Reading speed: 19.9 MByte/s H2testw v1.4 Transcend Micro SD Card 8GB- Class 6 (2nd Test) Warning: Only 7626 of 7627 MByte tested. Test finished without errors. You can now delete the test files *.h2w or verify them again. Writing speed: 17.1 MByte/s Reading speed: 19.8 MByte/s H2testw v1.4 Test finished without errors. You can now delete the test files *.h2w or verify them again. Writing speed: 6.44 MByte/s Reading speed: 10.8 MByte/s H2testw v1.4 Normal Micro SD Card 2GB (1st Test) Test finished without errors. You can now delete the test files *.h2w or verify them again. Writing speed: 6.44 MByte/s Reading speed: 10.8 MByte/s H2testw v1.4 Test finished without errors. (2nd Test) You can now delete the test files *.h2w or verify them again. Writing speed: 6.48 MByte/s Reading speed: 10.7 MByte/s H2testw v1.4 8GB Scandisk Class 4 Warning: Only 7559 of 7560 MByte tested. (1st Test) Test finished without errors. You can now delete the test files *.h2w or verify them again. Writing speed: 4.64 MByte/s Reading speed: 10.7 MByte/s H2testw v1.4 Lexar 4GB Class 4 (1st Test) Test finished without errors. You can now delete the test files *.h2w or verify them again. Writing speed: 7.31 MByte/s Reading speed: 16.0 MByte/s H2testw v1.4 ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding – Feb 2025
Prepaid card
Prepaid card
COE Bidding - January 2025
2024 Suzuki Swift
2024 Suzuki Swift
Australia: Car Rental in Melbourne
COE Bidding - December 2024
