Donut Supercharged March 12, 2011 Share March 12, 2011 how to make perfect half boiled eggs? My benchmark is ya kun toast standard. Everytime their eggs are so perfect. I dun wan to see translucent egg white. I only wan soft egg white. Any one got ideas? ↡ Advertisement Link to post Share on other sites More sharing options...
Ben5266 Supercharged March 12, 2011 Share March 12, 2011 how to make perfect half boiled eggs? My benchmark is ya kun toast standard. Everytime their eggs are so perfect. I dun wan to see translucent egg white. I only wan soft egg white. Any one got ideas? I just make half boiled egg for my son this morning and.... he got hard boiled egg. Maybe I put too much water. Link to post Share on other sites More sharing options...
Ivan11 Neutral Newbie March 12, 2011 Share March 12, 2011 I use a type of utensil that is meant to make half boiled eggs. Don't know how to describe it... some coffee shops are using them also. It's a plastic thingy, whereby u put yr eggs in the top compartment and add hot water according to the water mark indicated with the no. of eggs in it. The hot water would subsequently be drained into the lower compartment. Once water are drained completely, yr eggs are ready to be serve. It is sold in those typical/traditional kitchen ware provision shop. Standard of the half boiled eggs are to my liking and close to Ya Kun standard. Link to post Share on other sites More sharing options...
Jman888 Moderator March 12, 2011 Share March 12, 2011 boil water to boiling point, off fire, put egg in but make sure egg is not straight out of fridge, leave it cover for 5 mins... but not always perfect [laugh] it also depends on what type of egg Link to post Share on other sites More sharing options...
Donut Supercharged March 12, 2011 Author Share March 12, 2011 Making perfect half boiled eggs is a skill. Not simple to master. Link to post Share on other sites More sharing options...
GLZT 6th Gear March 12, 2011 Share March 12, 2011 Agree with Ivan11, its something like a steamer, some of the kopitiam uses them, can keep warm the eggs to serve for later without affecting the eggs. All come out will be like yakun standard. Link to post Share on other sites More sharing options...
Yellowrx8 Clutched March 12, 2011 Share March 12, 2011 I did ask b4 1 of their staffs. All the eggs must not be refrigerator. Temp of the hot water & also there is a timer to time for the eggs to be place in the hot water container. Link to post Share on other sites More sharing options...
Latio2005A Turbocharged March 12, 2011 Share March 12, 2011 boil water to boiling point, off fire, put egg in but make sure egg is not straight out of fridge, leave it cover for 5 mins... but not always perfect [laugh] it also depends on what type of egg after the above that you described, drained away the hot water. Let the eggs rest for an addnl 5 minutes. Trust me, my father' recipe. He used to own a coffeeshop. Link to post Share on other sites More sharing options...
The_Bear Turbocharged March 12, 2011 Share March 12, 2011 boil water to boiling point, off fire, put egg in but make sure egg is not straight out of fridge, leave it cover for 5 mins... but not always perfect [laugh] it also depends on what type of egg I have been thinking about this too for along time. For making half boil eggs, the following variables have to be considered: 1. size of egg - the bigger ones take longer to cook 2. temperature of egg - colder eggs take longer to cook 3. temperature of water - hotter water takes less time 4. amount of water - everthing else being equal, more water equal more latent heat transfer 5. heat loss from container to surrounding - the water is cooling down all the while when the eggs are cooking 6. thickness of egg shell - some eggs comes with really thick shells, takes longer to cook So you can see that making half boil egg is nearly rocket science so don't feel too bad if you screw it up time after time. Link to post Share on other sites More sharing options...
Ben5266 Supercharged March 12, 2011 Share March 12, 2011 Can put your 6 points into math formulae? :) Boiling point is easy. But the amount of water is tricky. Link to post Share on other sites More sharing options...
Jman888 Moderator March 12, 2011 Share March 12, 2011 (edited) I have been thinking about this too for along time. For making half boil eggs, the following variables have to be considered: 1. size of egg - the bigger ones take longer to cook 2. temperature of egg - colder eggs take longer to cook 3. temperature of water - hotter water takes less time 4. amount of water - everthing else being equal, more water equal more latent heat transfer 5. heat loss from container to surrounding - the water is cooling down all the while when the eggs are cooking 6. thickness of egg shell - some eggs comes with really thick shells, takes longer to cook So you can see that making half boil egg is nearly rocket science so don't feel too bad if you screw it up time after time. you see there are w lot of people clever than phd and doctor bloody hell it is just a damn egg... good or not, open liao dun care half boil, hard boil or not boil, just eat lah [laugh] Edited March 12, 2011 by Jman888 Link to post Share on other sites More sharing options...
Jman888 Moderator March 12, 2011 Share March 12, 2011 Agree with Ivan11, its something like a steamer, some of the kopitiam uses them, can keep warm the eggs to serve for later without affecting the eggs. All come out will be like yakun standard. those steamer is already very common donkey years ago in Europe.... yes it is quite fool proof so can ignore whatever the sifu in coffee shop tell you [laugh] Link to post Share on other sites More sharing options...
Antony Neutral Newbie March 12, 2011 Share March 12, 2011 easy, go get out of ur house n find one kopitiam....joking... Link to post Share on other sites More sharing options...
Tianmo Hypersonic March 12, 2011 Share March 12, 2011 you see there are w lot of people clever than phd and doctor bloody hell it is just a damn egg... good or not, open liao just eat lah [laugh] [laugh] Link to post Share on other sites More sharing options...
Renegade777 5th Gear March 12, 2011 Share March 12, 2011 Put eggs in a container and pour boiling water over it. Then, cover it with a lid for at least 15 minutes. Link to post Share on other sites More sharing options...
The_Bear Turbocharged March 12, 2011 Share March 12, 2011 you see there are w lot of people clever than phd and doctor bloody hell it is just a damn egg... good or not, open liao dun care half boil, hard boil or not boil, just eat lah [laugh] We are having an in-depth academic discussion on the said topic, it is in everyone's best interest that all known facts are laid out empirically for the benefit of education. No details too small to be left out in the relentless pursuit of the perfect half-boil egg. I find your callous attitude toward eggs a stumbling block to learning and mastering our dominance over eggs. Only when a man master his eggs that he is able to control the kitchen, earn the respect of his women (either singular or plural) & bring about peace to the world. 修蛋, 齐厨, 制妻, 平天下. Link to post Share on other sites More sharing options...
The_Bear Turbocharged March 12, 2011 Share March 12, 2011 Can put your 6 points into math formulae? :) Boiling point is easy. But the amount of water is tricky. I would love to but I've have yet unlocked the mystries of the last domestic frontier. I've contacted MIT on my latest observations and hope that someone there will be able to contribute to solving this problem. Link to post Share on other sites More sharing options...
Tianmo Hypersonic March 12, 2011 Share March 12, 2011 We are having an in-depth academic discussion on the said topic, it is in everyone's best interest that all known facts are laid out empirically for the benefit of education. No details too small to be left out in the relentless pursuit of the perfect half-boil egg. I find your callous attitude toward eggs a stumbling block to learning and mastering our dominance over eggs. Only when a man master his eggs that he is able to control the kitchen, earn the respect of his women (either singular or plural) & bring about peace to the world. 修蛋, 齐厨, 制妻, 平天下. 正心、修身、齐家、治国、平天下!!! so teacher, what must be done before 修蛋??? ↡ Advertisement Link to post Share on other sites More sharing options...
LV stores in Chicago and San Francisco mugged
Fake eggs at our shores
How to make BOV LOUDER THAN BEFORE!!!!!
Egg freezing for women in sg
Soya Bean Milk Recipes - Make at home easy.
What u do if your wife doesn't want to make out with u?
Super fungus that kills nearly half of victims has spread
Over half of bad crashes involve motorcyclists!
