Kar_lover Supercharged March 7, 2011 Share March 7, 2011 Hi All I recently changed from Bridgestone RE001 to Dunlop Sport Maxx (not TT). This morning, roads all wet as was raining. I noticed dat with the dunlop, when i jam brake just a bit, the ABD kicks in quite easily. With my RE001, only once did my ABS kick in and that was in a really hard braking situation (in fron of with the 5 cars not so lucky and got into a chain collision, i escaped). Does this mean the dunlops not so good cos lose grip more easily triggering the ABS. Quite scary. All constructive info/opinions welcome. Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Blackyv Turbocharged March 8, 2011 Share March 8, 2011 Either the new tyre not run in yet or not as good as your previous tyre Link to post Share on other sites More sharing options...
Kar_lover Supercharged March 8, 2011 Author Share March 8, 2011 Either the new tyre not run in yet or not as good as your previous tyre Thanks. Done more than 1,000km already. Link to post Share on other sites More sharing options...
Help1 1st Gear March 8, 2011 Share March 8, 2011 does ABS really "learn" and "adapt" to the new tyre? Link to post Share on other sites More sharing options...
Robo 2nd Gear March 8, 2011 Share March 8, 2011 i dunno much abt dunlop. but am on re001 and so far it kicked in only one. the road was wet and i was entering a slip road, i wasnt paying much attention, realised that i needed to stop if not siao liao. jam the brakes abs kicked in and managed to stop just behind the waitint line. Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 8, 2011 Share March 8, 2011 its the tyre compound or on that particular road, oil stains are on the surface of the wet road which made your abs kicked in earlier than before. the latter seems to be the higher possibility.... Link to post Share on other sites More sharing options...
Kar_lover Supercharged March 8, 2011 Author Share March 8, 2011 does ABS really "learn" and "adapt" to the new tyre? Wat i believe is ABS is triggered when it senses skidding, i.e. when there is a difference between wheel rotation speed and car speed (wheel rotate slower than car speed though i am not sure how it senses car speed). If a tire has less grip, then under braking, it will be easier to skid hence ABS kick in more easily. If car skids when NOT braking then traction control will kick in instead. Link to post Share on other sites More sharing options...
Kar_lover Supercharged March 8, 2011 Author Share March 8, 2011 its the tyre compound or on that particular road, oil stains are on the surface of the wet road which made your abs kicked in earlier than before. the latter seems to be the higher possibility.... But it happened 3 different times at 3 different places this morning. Link to post Share on other sites More sharing options...
Kar_lover Supercharged March 8, 2011 Author Share March 8, 2011 found this: http://auto.howstuffworks.com/auto-parts/b...-lock-brake.htm Link to post Share on other sites More sharing options...
Kr_toy 1st Gear March 8, 2011 Share March 8, 2011 Thanks. Done more than 1,000km already. I think the tyre not finish run in yet, after 3k if the same problem happen, then it may be the tyre compound is not that good. Link to post Share on other sites More sharing options...
Wolfy3769 2nd Gear March 8, 2011 Share March 8, 2011 so far i olnly experience ABS kick-in when i do a E-brake on wet road...thus 3 times on 3 diff road is abit too much.. i wont suggest ur tire not grippy enough thus trigger the kick-in... another could be something wrong with ur ABS system.. Dunlop Sport MAXX , izzt the first time u trying it? maybe is one of the "characteristic" of the tire.. i would suggest u drive slower for the time being until u find out the cause of ur rapid ABS kick-in. Link to post Share on other sites More sharing options...
Kar_lover Supercharged March 8, 2011 Author Share March 8, 2011 so far i olnly experience ABS kick-in when i do a E-brake on wet road...thus 3 times on 3 diff road is abit too much.. i wont suggest ur tire not grippy enough thus trigger the kick-in... another could be something wrong with ur ABS system.. Dunlop Sport MAXX , izzt the first time u trying it? maybe is one of the "characteristic" of the tire.. i would suggest u drive slower for the time being until u find out the cause of ur rapid ABS kick-in. the 3 different times and places are all this morning and all three places were wet. Previously on my RE001, even wet also no problem. Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 8, 2011 Share March 8, 2011 its the tyre then..... whats the manufacturing date? Its either old and hardened OR simply lousy compound Link to post Share on other sites More sharing options...
Kar_lover Supercharged March 8, 2011 Author Share March 8, 2011 its the tyre then..... whats the manufacturing date? Its either old and hardened OR simply lousy compound 2010 tire. Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 8, 2011 Share March 8, 2011 2010 tire. fresh tyre but compound is...... maybe its more suited for dry and not so good in wet. Like those Ad07 or Ku36 Link to post Share on other sites More sharing options...
Furrynadz 5th Gear March 9, 2011 Share March 9, 2011 i used sport maxx b4, the compound is fine Link to post Share on other sites More sharing options...
Starcombat Neutral Newbie March 10, 2011 Share March 10, 2011 Depends very much on driving style too. From the description so far, for him. the new tyres are less gripy than previous ones comparatively. Link to post Share on other sites More sharing options...
Pokyman 1st Gear March 10, 2011 Share March 10, 2011 Ok, noob question, how to tell if my ABS kicks in? ↡ Advertisement Link to post Share on other sites More sharing options...
How Much Do You Know About ABS?
Looking for Job in automotive sector, need advise
In need of vehicle history software
Time to buy some US dollar?
Syria Quake
Syria Quake
