Minikong 1st Gear March 6, 2011 Share March 6, 2011 i just did a first time checked on my 3 month old car, and found out that the oile level at my dip stick ia low, any encounter such problem before? ↡ Advertisement Link to post Share on other sites More sharing options...
Ken4555 1st Gear March 6, 2011 Share March 6, 2011 On 3/6/2011 at 3:11 AM, Minikong said: i just did a first time checked on my 3 month old car, and found out that the oile level at my dip stick ia low, any encounter such problem before? if you just turned off your engine its fine... cause need time for all the oil to flow back into the oil pan mah... also is the ground you parked your car on flat level?... if you parked over nite and measured your dip stick in the morning and its low than should top up... if you tink might have leak then put news paper under your engine over night... for me i prefer the oil level to be in between... too much oil i dont like... Link to post Share on other sites More sharing options...
Minikong 1st Gear March 6, 2011 Author Share March 6, 2011 On 3/6/2011 at 3:22 AM, Ken4555 said: if you just turned off your engine its fine... cause need time for all the oil to flow back into the oil pan mah... also is the ground you parked your car on flat level?... if you parked over nite and measured your dip stick in the morning and its low than should top up... if you tink might have leak then put news paper under your engine over night... for me i prefer the oil level to be in between... too much oil i dont like... think tmororw just go back to dealer, as it is only 3 months old, hahaha Link to post Share on other sites More sharing options...
Ken4555 1st Gear March 6, 2011 Share March 6, 2011 On 3/6/2011 at 3:25 AM, Minikong said: think tmororw just go back to dealer, as it is only 3 months old, hahaha things like oil filter seal crack or never screw in tightly can cause leaks mah... anyways 3months old, engine syill running in... should have lotsa of 'debris' in the engine.... so watever reason so long not below low or your engine oil pressure light not on sure no problem one... Link to post Share on other sites More sharing options...
SimonTan 2nd Gear March 6, 2011 Share March 6, 2011 New car nest to have full oil. For cleaning and trapping the metal filings. Older cars can have lower oil, reduce drag and weight for more engine power. Link to post Share on other sites More sharing options...
ER-3682 Twincharged March 6, 2011 Share March 6, 2011 On 3/6/2011 at 3:11 AM, Minikong said: i just did a first time checked on my 3 month old car, and found out that the oile level at my dip stick ia low, any encounter such problem before? What is your mileage after 3 months.?I heard some cars,esp V.W. cars used up to 300ml of oil every 1000km. Link to post Share on other sites More sharing options...
Minikong 1st Gear March 6, 2011 Author Share March 6, 2011 On 3/6/2011 at 4:54 AM, ER-3682 said: What is your mileage after 3 months.?I heard some cars,esp V.W. cars used up to 300ml of oil every 1000km. 5k mileage for now Link to post Share on other sites More sharing options...
ER-3682 Twincharged March 6, 2011 Share March 6, 2011 On 3/6/2011 at 5:11 AM, Minikong said: 5k mileage for now Should be normal,the service will just top up for you,nothing can be done if there are no leaks,just is the nature of the engine. ↡ Advertisement Link to post Share on other sites More sharing options...
Coolant level going down
McLaren entry level sports car, 570S and its related series
A level results for University Courses
O level results coming out soon!
Poverty level in Singapore and the world, how $$$ much do you need?
High platelet count reached dangerous level
Cannot anyhow stick SPF decal liao!
PC Stick via HDMI
PC Stick via HDMI
