Ithunk 1st Gear February 18, 2011 Share February 18, 2011 for mi 750rpm is ok however there is a slight bog 500 rpm the engine will bog heavily and stall ↡ Advertisement Link to post Share on other sites More sharing options...
Mllcg 3rd Gear February 18, 2011 Share February 18, 2011 mine stalls at around 400+. 500 biting pt Link to post Share on other sites More sharing options...
Mockngbrd Supersonic February 18, 2011 Share February 18, 2011 0 ... Link to post Share on other sites More sharing options...
Dreamer143 Clutched February 18, 2011 Share February 18, 2011 Mine is at 1000 rpm with CNG fuel Link to post Share on other sites More sharing options...
Aeromania 1st Gear February 18, 2011 Share February 18, 2011 zero rpm Link to post Share on other sites More sharing options...
Fattychubby 1st Gear February 18, 2011 Share February 18, 2011 200rpm stalled.. normal idling around 400-450 rpm Link to post Share on other sites More sharing options...
ER-3682 Twincharged February 18, 2011 Share February 18, 2011 200rpm stalled.. normal idling around 400-450 rpm Yours must be a big V8 or V12,never seen such low idling speed before. Link to post Share on other sites More sharing options...
Nzy Twincharged February 19, 2011 Share February 19, 2011 Yours must be a big V8 or V12,never seen such low idling speed before. I think its possible. Mine stalls at around 300rpm and mine is just a 1.4l. Sometimes when in heavy traffic on first gear I can crawl at around 300+rpm. Link to post Share on other sites More sharing options...
Ken4555 1st Gear February 19, 2011 Share February 19, 2011 for 0rpm Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 19, 2011 Share February 19, 2011 what rpm i not sure. But its for sure when i pull out the key.... Link to post Share on other sites More sharing options...
Nf0rc3r 1st Gear February 19, 2011 Share February 19, 2011 (edited) Wa idle 500rpm? My Idle 600 with air con and headlights off i tot very low alr. =x Edited February 19, 2011 by Nf0rc3r ↡ Advertisement Link to post Share on other sites More sharing options...
Hawkers worry about stall design after fire at newly opened Bukit Canberra Hawker Centre
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
