Toeknee_33 Turbocharged May 21, 2020 Share May 21, 2020 3 minutes ago, iamahbee said: I suppose you mean the indicator lit up at 12k km and 27k km. The service interval is 15k, have you serviced your car in between? From 0 to 12000km - 1 litre of EO per 12,000km Serviced at 15,000km. from 15,000 to 27,000km - 1 litre of EO per 12,000km. It all adds up! Very consistent EO consumption. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
iamahbee 5th Gear May 21, 2020 Share May 21, 2020 2 minutes ago, Toeknee_33 said: From 0 to 12000km - 1 litre of EO per 12,000km Serviced at 15,000km. from 15,000 to 27,000km - 1 litre of EO per 12,000km. It all adds up! Very consistent EO consumption. That's what I thought... I had a Mk7 1.4 122hp for 7 years and the low oil warning came up once at 5k km and then much later at 110k km. The latter happened as my EO cap gasket was worn and oil spurts out from the top on starts. There are several factors for the EA211 engine to consume more oil than usual, I will just list them based on my experience: 1. Car is used for short journeys <9km each trip. 2. Car is always stuck in heavy traffic. 3. Driver moves off immediately after a cold start; the EA211 usually idles at 1100-1200rpm on cold starts before settling to a normal 850-900rpm. If the driver moves off immediately at a higher idle speed, the oil tends to burn. Usage patterns aside, check for these signs: 1. Oil stains around the EO cap (as with my issue stated above). 2. Oil stains/patches on the engine bay floorpan; open the bonnet and shine a torch into the gap between the radiator and engine block. 3. Specks of blackened oil spots around the exhaust pipe. 3 Link to post Share on other sites More sharing options...
Toeknee_33 Turbocharged May 21, 2020 Share May 21, 2020 32 minutes ago, iamahbee said: That's what I thought... I had a Mk7 1.4 122hp for 7 years and the low oil warning came up once at 5k km and then much later at 110k km. The latter happened as my EO cap gasket was worn and oil spurts out from the top on starts. There are several factors for the EA211 engine to consume more oil than usual, I will just list them based on my experience: 1. Car is used for short journeys <9km each trip. 2. Car is always stuck in heavy traffic. 3. Driver moves off immediately after a cold start; the EA211 usually idles at 1100-1200rpm on cold starts before settling to a normal 850-900rpm. If the driver moves off immediately at a higher idle speed, the oil tends to burn. Usage patterns aside, check for these signs: 1. Oil stains around the EO cap (as with my issue stated above). 2. Oil stains/patches on the engine bay floorpan; open the bonnet and shine a torch into the gap between the radiator and engine block. 3. Specks of blackened oil spots around the exhaust pipe. What i found from a quick check on the internet: VW says 1L every 1600km is within acceptable range. Some explanations were: (1) low tension piston rings are used to reduce friction and improve efficiency, so EO gets past the rings into the combustion chambers and gets burnt off. (2) There is more lubrication of valve seals and stems, and EO gets into the combustion chambers too. Or maybe, like Mercedes F1-style, these engines burn EO to make more power! 😁 https://enrg.io/how-mercedes-f1-engine-burns-oil-for-more-power-w-video/ 2 Link to post Share on other sites More sharing options...
Williamtkc Neutral Newbie May 22, 2020 Share May 22, 2020 On 5/21/2020 at 4:34 PM, Toeknee_33 said: What i found from a quick check on the internet: VW says 1L every 1600km is within acceptable range. Some explanations were: (1) low tension piston rings are used to reduce friction and improve efficiency, so EO gets past the rings into the combustion chambers and gets burnt off. (2) There is more lubrication of valve seals and stems, and EO gets into the combustion chambers too. Or maybe, like Mercedes F1-style, these engines burn EO to make more power! 😁 https://enrg.io/how-mercedes-f1-engine-burns-oil-for-more-power-w-video/ Thanks you guys for your sharing. Will be sending the car in for 30K servicing soon with AD. Will request them to carry out an inspection for any oil leak. Link to post Share on other sites More sharing options...
rockygun Neutral Newbie August 15, 2020 Share August 15, 2020 Hello all, I’m trying to find a light out of the problems I have. My Golf MK6 has been crashing badly since mid of July and my trusted mechanic seems to be unable to resolve all the issues despite numerous visits and spending many weeks there 😞 1st visit: engine stalled when Check Engine Light came on and started blinking. Towed to workshop to change ignition coil. Was told that it misfired. Spark plugs had no issue 2nd, 5 days later, car started jerking when shifting gears (only upwards), drove to check, no issue 3rd, 4 days later, jerking persists and sent over to check. Changed mechatronic oil 4th, next day, Check Engine Light came on again. Sent in, changed the cracked diverter valve 5th, 1 hour later, Check Engine Light came on AGAIN. Sent in, changed waste gate valve. No lights but mechanic did a diagnostic test and there is fault code. He proceeded to check on ECU. Pins corroded but due to the check, the pins broke and changed ECU. Meanwhile he cleared a lot of leaves from drainage (that’s why ECU corroded due to water) 6th, car still rev for no reason, cannot go more than 60km/h. Took back the car while waiting for another ECU. 7th, drove for 30 min after changing ECU, EPC light + Check Engine Light came on. Car started to rev even when I’m not doing anything (Parked mode and handbrake engaged). Diagnostic test shows ECU still has issues (eventually the 2nd ECU also corroded a bit due to water). 8th, car cannot accelerate even when I stepped damn hard on accelerator, goes onto limp mode as and when (beyond 50km/h and even at 30km/h). Changed thermostat switch which is leaking and causing corrosion to ECU. Another fault code appears (P0222) Throttle/ pedal position switch/ sensor B: Low input. Mechanic changed the sensor in the accelerator pedal, fault code still there Mechanic is now changing all the pins (wires) in ECU and see how it goes. TLDR; - engine stalled, misfired, changed ignition coil - jerking when changing gear, changed mechatronic oil - check engine light came on, changed diverter valve - check engine light came on, changed waste gate valve, ECU diagnosed to have problem - ECU corroded due to water, changed ECU, corroded again, changed again - cannot accelerate and car just rolls forward until I turn off engine, changed sensor in accelerator and fault code still persists Link to post Share on other sites More sharing options...
nashstruck 1st Gear May 27, 2021 Share May 27, 2021 Guys. I own a VW Golf 1.4 MK7.5. Would appreciate some help / advice. The change battery cost from AD is quite expensive. I am due to change soon because car already 2 years old. I was wondering 1. Is it OK to change battery outside or MUST I change it with AD? Does it void my 5 year warranty if I change it outside? 2. If I do change it outside, how much does it usually cost? AD quoted almost $500. Link to post Share on other sites More sharing options...
Sdf4786k Twincharged May 27, 2021 Share May 27, 2021 (edited) 1 hour ago, nashstruck said: Guys. I own a VW Golf 1.4 MK7.5. Would appreciate some help / advice. The change battery cost from AD is quite expensive. I am due to change soon because car already 2 years old. I was wondering 1. Is it OK to change battery outside or MUST I change it with AD? Does it void my 5 year warranty if I change it outside? 2. If I do change it outside, how much does it usually cost? AD quoted almost $500. Should be ok to change outside .. just make sure it’s AGM battery or try upside it .. other than this please make sure the guy perform a vcds battery initiations.. OR ask your fav workshop to chumsoing initialise for u . normally VW warranty new car for batt is 2 years .. has it cross that ? If I not sure call the hotline to check Edited May 27, 2021 by Sdf4786k Link to post Share on other sites More sharing options...
nashstruck 1st Gear May 27, 2021 Share May 27, 2021 4 hours ago, Sdf4786k said: Should be ok to change outside .. just make sure it’s AGM battery or try upside it .. other than this please make sure the guy perform a vcds battery initiations.. OR ask your fav workshop to chumsoing initialise for u . normally VW warranty new car for batt is 2 years .. has it cross that ? If I not sure call the hotline to check Thanks for the info! My battery is just 2 years 1 month old. AD says that it's now at 50%. I've also realised that the start/stop function doesn't come on as much anymore. I figured it's probably a sign that the battery is not holding a charge as well as before. I tried to ask AD for discount given it's just cross by 1 month (delay in servicing mainly due to COVID), because another staff told me they have a promotion of 25% off, but so far the AD won't budge. VAG offering $350 but AD offering 500$. Quite a big diff. Link to post Share on other sites More sharing options...
WWbarb 1st Gear May 28, 2021 Share May 28, 2021 @nashstruck Shops like Kim hoe are selling agm batteries eg. Varta for $200plus. Anyway your stock battery should be efb only. Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 28, 2021 Share May 28, 2021 42 minutes ago, WWbarb said: @nashstruck Shops like Kim hoe are selling agm batteries eg. Varta for $200plus. Anyway your stock battery should be efb only. But I guess they do not do battery registration via VCDS. Link to post Share on other sites More sharing options...
WWbarb 1st Gear May 28, 2021 Share May 28, 2021 @Hamburger Can check with Kim Hoe, many vw owners change battery there. Link to post Share on other sites More sharing options...
nashstruck 1st Gear May 28, 2021 Share May 28, 2021 Guys anyone change battery at Agent and can share what price you paid please? Link to post Share on other sites More sharing options...
WuGuangHao Neutral Newbie May 28, 2021 Share May 28, 2021 Planning to buy Golf 8, any comments or suggestion? Link to post Share on other sites More sharing options...
yellowshaun 4th Gear May 29, 2021 Share May 29, 2021 10 hours ago, WuGuangHao said: Planning to buy Golf 8, any comments or suggestion? You can read the ongoing chat at Link to post Share on other sites More sharing options...
ryt Clutched June 2, 2021 Share June 2, 2021 hi guys, anyone here tried lowering springs for 2018 1.4 tsi? Eibach, H&R, Racingline, which one is best? Not considering coilovers at the moment. Appreciate if anyone has input. Link to post Share on other sites More sharing options...
Sdf4786k Twincharged June 3, 2021 Share June 3, 2021 On 5/27/2021 at 9:47 PM, nashstruck said: Thanks for the info! My battery is just 2 years 1 month old. AD says that it's now at 50%. I've also realised that the start/stop function doesn't come on as much anymore. I figured it's probably a sign that the battery is not holding a charge as well as before. I tried to ask AD for discount given it's just cross by 1 month (delay in servicing mainly due to COVID), because another staff told me they have a promotion of 25% off, but so far the AD won't budge. VAG offering $350 but AD offering 500$. Quite a big diff. Try escalate to the guy in the fish tank .. he generally is flexible if your historical services with them is prompt and no complaints so far .. if you are one of those that every service has a ton of mysterious sound to troubleshoot type, then you probably won’t get much joy from the conversation Link to post Share on other sites More sharing options...
iameden Neutral Newbie June 6, 2021 Share June 6, 2021 hey, any vw / golf telegram group to join? Link to post Share on other sites More sharing options...
ra1nman Neutral Newbie August 3, 2021 Share August 3, 2021 was thinking of trading my mazda 3 2017 to Golf MK7. but im doing delivery for a living, is golf suitable ? delivery as in lalamove and grabfood ↡ Advertisement Link to post Share on other sites More sharing options...
Mercedes Owners Thread
Golf Club members! Lai lai!
Two golf courses to be phased out by 2024
Swift Owners
Swift Owners
2022 Toyota GR Corolla
W212 owners, please check-in
Kia Cerato GT Line Owners Check In
