Repair door lock
Quekahwhye
same happened to me. I was advised by komoco to go back to a shop opposite the carpark of its Alexandra Road service centre. costed me $70 to replace a actuator.
by the way, you can try repeatedly on and off your remote and at the same time try to unlock from inside. sometime it will help to unlock your door.
Paid less than $65 to replace lock motor and door handle inlet at Synergy Automobile at Lavender Street
Supercharged
Sorry to revive a one year old trend...
But just yesterday I had a similar problem of my left rear door unable to open. Child lock is not activated. Worse still, its door locking knob (on top) had fallen off and I can't find it anywhere. What has gone wrong? Any workshop to recommend?
Thanks.
For this case got to remove the side board panel as the linkage had lossen (Using allen keys for securiung between your "level" and the linkage) Go to any car accesories shop & they can fix it. If change of actuator required, it costs around S$ 25/- unit.
Edited by Jefkking
Supercharged
mine can lock but can't unlock
cannot turn to lock at all from both side
Then have you fixed it yet?
Supercharged
Mine one i DIY, buy and change all four aftermarket one. less than 30
I also thinking to DIY. But problem is, the door can't even open!!! Door can't open I can't remove the panel and change the mechanism inside. [:(]
Even you pull the trigger from inside also cannot open?
Supercharged
Think Shirt hanger will do...But don't do it at MSCP..later ppl tot u steal car
Ya, some kind of hook to unlock the door...haven't try it yet.
What if still can't unlock the door....? That is my worry. [smallcry]
Supercharged
hijack a bit, my driver side lock key outside keyhole is frozen...any chance to replace it?
"Frozen" means cannot poke in the key???
