Picanto 3rd Gear February 13, 2011 Share February 13, 2011 after the SP, how is the FC of your QQ? ↡ Advertisement Link to post Share on other sites More sharing options...
Stanchiam 1st Gear February 13, 2011 Author Share February 13, 2011 after the SP, how is the FC of your QQ? cant tell the difference, about the same. Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear February 13, 2011 Share February 13, 2011 I weight them. As i said, SD weight about 15kg for 1 box 40pcs. The foam can ignore cause its so light, 1 foam 100gm perhaps. I have used about 45pcs SD and 10 foam for the entire floor, no adverse effect for the added 17kg. Maybe I should take out the spare tire, that thing weight about 20kg Will replace it with a tire repair kit and pump instead. but that 15kg is just for the boot right? U are going to do your whole car? entire project is going to add 80kgs? Link to post Share on other sites More sharing options...
Stanchiam 1st Gear February 13, 2011 Author Share February 13, 2011 (edited) but that 15kg is just for the boot right? U are going to do your whole car? entire project is going to add 80kgs? "I weight them. As i said, SD weight about 15kg for 1 box 40pcs. The foam can ignore cause its so light, 1 foam 100gm perhaps. I have used about 45pcs SD and 10 foam for the entire floor, no adverse effect for the added 17kg." entire flooring, not clear enough? add 80kg? thats really funny bro. But I love your joke. My SP DIY Edited February 13, 2011 by Stanchiam Link to post Share on other sites More sharing options...
Eclipse1 2nd Gear February 13, 2011 Share February 13, 2011 TS, can I check with you, where did you buy the roller? and does it comes with different sizes and what kind of cost is it?? Link to post Share on other sites More sharing options...
Stanchiam 1st Gear February 13, 2011 Author Share February 13, 2011 (edited) TS, can I check with you, where did you buy the roller? and does it comes with different sizes and what kind of cost is it?? bought from china GN where i bought their SD, only 1 size and 25rmb. Entire handle made from metal (should be steel, not sure) Edited February 13, 2011 by Stanchiam Link to post Share on other sites More sharing options...
Ngck 3rd Gear February 13, 2011 Share February 13, 2011 bro, do the roof.... so when raining not so noisy... Link to post Share on other sites More sharing options...
Stanchiam 1st Gear February 14, 2011 Author Share February 14, 2011 bro, do the roof.... so when raining not so noisy... roof is last option, now my next target is firewall area which is the hardest part. need more study about my car first before doing it Link to post Share on other sites More sharing options...
Janling3 6th Gear February 14, 2011 Share February 14, 2011 It is tiring, 2nd phase for the front i take about 6hrs, most of the time is spent on slowly dismantling the seat, carpet etc. If there is another person to help, it will definitely help to speed up alot. By the way, i uploaded my DIY pictures to here my DIY Sound proofing I find that the front SP is very poor and the engine sound come from there, the firewall area. But I dare not dismantle the front to DIY the SP. Maybe next time after doing some research. Now can only hear engine sound and front wheel which travel through the firewall from the front. Firewall SP is a must!! bro, that is exactly what i have been experiencing for the last 2-3 years, once i hit rough surface asphalt road equivalent with tarmac (usually highway of CTE, PIE, and travel beyond 60km/h, the tire noise turns unbearable.... luckily i do not hear the engine noise.... may be my firewall is a bit better... Link to post Share on other sites More sharing options...
Picanto 3rd Gear February 14, 2011 Share February 14, 2011 bro, that is exactly what i have been experiencing for the last 2-3 years, once i hit rough surface asphalt road equivalent with tarmac (usually highway of CTE, PIE, and travel beyond 60km/h, the tire noise turns unbearable.... luckily i do not hear the engine noise.... may be my firewall is a bit better... its not a bit better. some people have a higher tolerance towards noise level Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear February 14, 2011 Share February 14, 2011 "I weight them. As i said, SD weight about 15kg for 1 box 40pcs. The foam can ignore cause its so light, 1 foam 100gm perhaps. I have used about 45pcs SD and 10 foam for the entire floor, no adverse effect for the added 17kg." entire flooring, not clear enough? add 80kg? thats really funny bro. But I love your joke. My SP DIY sorry didnt read correctly. big difference in sound penetration? feel like lexus proofing now? run over pple also cant hear? Link to post Share on other sites More sharing options...
Stanchiam 1st Gear February 15, 2011 Author Share February 15, 2011 sorry didnt read correctly. big difference in sound penetration? feel like lexus proofing now? run over pple also cant hear? not as good as that lady's lexus the firewall area is the only area where sound coming from as i did SP that portion. the rest of the car can feel quiet, very different Link to post Share on other sites More sharing options...
Stanchiam 1st Gear February 26, 2011 Author Share February 26, 2011 have just finish wheel arc soundproofing. have added the SD only and will add the foam in the future so i can hear the differences with and without foam (10mm thick) DIYWheelArcSoundProofing this method will surely be better than spraying 3M coating spray as the sound deadener is 2.2mm thick I used about 3 pieces of SD for each wheel Link to post Share on other sites More sharing options...
Ghostami 2nd Gear February 26, 2011 Share February 26, 2011 Why not take out the banana skill and put the SD inside?? Wouldn't it be exposed to the environment this way and it will just degrade and drop off suddenly when you drive and worst, if its stuck when its drops, I don't know what will happen. Link to post Share on other sites More sharing options...
Stanchiam 1st Gear February 26, 2011 Author Share February 26, 2011 Why not take out the banana skill and put the SD inside?? Wouldn't it be exposed to the environment this way and it will just degrade and drop off suddenly when you drive and worst, if its stuck when its drops, I don't know what will happen. others have done it before and it is confirm ok, and the best part is their country is with winter. the SD do not absorb water and is made of a kind of rubber, once u stick it there and press onto the surface, it is almost impossible to take off, at most the surface is dirty Wanted to take off the other parts and put SD inside, but I forgot to bring tools...lol Link to post Share on other sites More sharing options...
Stanchiam 1st Gear February 28, 2011 Author Share February 28, 2011 today tried 80km+ on the highway with rough road, the wheel noise is reduced a lot, now it is mostly the engine noise. Think need to do the firewall area to reduce those noise. Btw, before i do the wheel arc, didnt noticed rattle sound on the firewall area when travel high speed on rough road because the wheel noise now that the wheel noise is reduced a lot, can heard that the front does have some rattle noise well, firewall SP DIY next Link to post Share on other sites More sharing options...
Simoncwc Neutral Newbie February 28, 2011 Share February 28, 2011 Dear Bro, I want to diy my civic fd4 sound proof , can help. or u selld the meterial , many tks, Link to post Share on other sites More sharing options...
Ilmw 1st Gear February 28, 2011 Share February 28, 2011 TS, can I check with you, where did you buy the roller? and does it comes with different sizes and what kind of cost is it?? Roller can buy from Art Friend shop. About 5 cm wide. About S$10 or less, can't remember. ↡ Advertisement Link to post Share on other sites More sharing options...
Sound Proofing the car
Whole car sound proof
Heavy and rain proof curtains/blinder recommendations?
Right side speakers no sound
Metal grinding sound on civic
Light clattering clicking sound when accelerating
