RunForrest Neutral Newbie January 2, 2011 Share January 2, 2011 Hi, anybody knows which model from Black & Decker has the most suction power ? Or is there even any difference ? Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Ghostami 2nd Gear January 3, 2011 Share January 3, 2011 Normal ones or handheld type?? Link to post Share on other sites More sharing options...
Whathefish 5th Gear January 3, 2011 Share January 3, 2011 If u mean hand held which for car ... quite powerful considering its size... Think selling at Home fix..cannot recall the price. Link to post Share on other sites More sharing options...
Ghostami 2nd Gear January 3, 2011 Share January 3, 2011 Hand held my vote goes to philips. Go to Courts or any electrical stores, I forgotten which model but price is about 200+. That is a powerful handheld, but the price is pushing me off.. Link to post Share on other sites More sharing options...
Ghostami 2nd Gear January 3, 2011 Share January 3, 2011 http://www.philips.com.sg/c/vacuum-cleaner...-fc6161_04/prd/ This was the model I saw, can be used at home and also in the car. Tried it out at courts, it is quite powerful compared to all the hand held I had use before. As mention, did not buy it because : 1) Brand - Not sure reliable or not 2) Price - I will be only using it in my car, for $200+ abit overpriced for me to consider for a handheld. But this 2 factor is not a problem to you, I say go for this. Link to post Share on other sites More sharing options...
Friedpiggy 2nd Gear January 3, 2011 Share January 3, 2011 the variety/type of attachment is equally important. No point having powerful suction when it cant reach. Link to post Share on other sites More sharing options...
Babyt 4th Gear January 3, 2011 Share January 3, 2011 i also brought one handheld vaccum for my car...electrolux...about $140....but ended up hardly use...the cable is irritating and many areas hard to reach. Link to post Share on other sites More sharing options...
Ghostami 2nd Gear January 3, 2011 Share January 3, 2011 the variety/type of attachment is equally important. No point having powerful suction when it cant reach. The attachments are quite standard, you should go take a look if you are interested. I don't mind buying it if its less pricey.. Link to post Share on other sites More sharing options...
RunForrest Neutral Newbie January 5, 2011 Author Share January 5, 2011 Hey. Thanks for the recommendation. For the Phillips vacuum, it's out of budget definitely. And further more, it doesn't have the 12v car charger. I've read reviews that vacuum that works with rechargeable batteries tends to lose it's suction power after the battery deteriorate. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged January 5, 2011 Share January 5, 2011 I got 1 unit from Esso Yishun. Only $10+, using cigar socket for power. the power cord is long enough to cover the whole car and its strong enough to pickup sands and dust in the car. light to carry around and compact enough to keep in the car. Link to post Share on other sites More sharing options...
Tharatalae Neutral Newbie April 2, 2011 Share April 2, 2011 Hi, anybody knows which model from Black & Decker has the most suction power ? Or is there even any difference ? Thanks! Get karcher brand more powerful n cheap Link to post Share on other sites More sharing options...
Aeromania 1st Gear April 2, 2011 Share April 2, 2011 no need to buy until $100 $200 one la. my black & decker on $60+ can suck my car until swee swee already. Anyway I bought it from autobacs ubi. the design quite stylo also. Pai seh can't find picture for you. Link to post Share on other sites More sharing options...
AGWM Neutral Newbie April 4, 2011 Share April 4, 2011 Hi, I use a handheld black and decker that works out of the cigarette jack for my car interior. Very powerful and easy to empty out after every session. I got it free so not sure about the price you'd be charged for it. Link to post Share on other sites More sharing options...
5936 1st Gear April 4, 2011 Share April 4, 2011 I am using corded electrolux. I think less than a hundred or lightly more. Link to post Share on other sites More sharing options...
Muakmuak Clutched April 6, 2011 Share April 6, 2011 I remembered there are coin operated vacuum machine at some petrol kiosk. Not sure if they are still around? Anyone knows where can I find those at petrol kiosk? Link to post Share on other sites More sharing options...
5936 1st Gear April 8, 2011 Share April 8, 2011 Saw one in esso jurong west ave 1 Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged April 8, 2011 Share April 8, 2011 http://www.philips.com.sg/c/vacuum-cleaner...-fc6161_04/prd/ This was the model I saw, can be used at home and also in the car. Tried it out at courts, it is quite powerful compared to all the hand held I had use before. As mention, did not buy it because : 1) Brand - Not sure reliable or not 2) Price - I will be only using it in my car, for $200+ abit overpriced for me to consider for a handheld. But this 2 factor is not a problem to you, I say go for this. This model i'm using.. damn good n black n decker cannot fight at all.. b&d win only in its lower price. I'm using it as broom& magic wipe replacement at home for home use, occasionally use to vacuum car Link to post Share on other sites More sharing options...
Jeuda Clutched April 8, 2011 Share April 8, 2011 Using a $49.90 black & decker handheld vacuum cleaner... been 4 years liao. Still working fine! ↡ Advertisement Link to post Share on other sites More sharing options...
Any recomendation for Robot cleaner??
SONAX rim cleaner
SONAX rim cleaner
Electrical appliances
Power Tools Brand - Milwaukee versus the rest
Recommend me a good handheld vacuum
Automatic (robotic) vacuum cleaner
DPF Cleaner
DPF Cleaner
Plastic Trim Cleaner and Restorer
