Door sealing strip DIY
Stanchiam
tigershark1976 - BLACK colour carbon fibre sticker (1.27 width, 立体黑色宽1.27M,RMB0.13/cm), 2000 unit (20 meters), link
tigershark1976 - SILVER colour carbon fibre sticker (1.27 width, 立体银色宽1.27M, RMB0.15/cm), 1500 unit (15 meters), http://item.taobao.com/item.htm?id=9615247372
Kwanheng- Fuhe foam 10mm x 10pcs
kwanheng- GN sound deadener x 10 pcs
kwanheng- eye lid, 1, http://item.taobao.com/item.htm?id=7455742545
kwanheng- touch up paint,1, QR-18, http://item.taobao.com/item.htm?id=5890139698
charle130 - door seal 20m http://item.taobao.com/item.htm?id=4763065532&
charle130 - door seal 6m http://item.taobao.com/item.htm?id=4850053866&
charle130 - 20 clips http://item.taobao.com/item.htm?id=4191774826&
kezg1- Fuhe foam 10mm x 5pcs
kezg1- GN sound deadener x 10 pcs
lanevomax - door seal 40m http://item.taobao.com/item.htm?id=4763065532&
lanevomax - door seal 20m http://item.taobao.com/item.htm?id=4850053866&
MK1 - Exos Sports red moulding 6m - Red color http://item.taobao.com/item.htm?id=9515882230
fitzy - door seal 30m http://item.taobao.com/item.htm?id=4763065532& - Contact in ur PM. Do let me know the cost.
if item have different option like color, size etc, please state clearly (do not remove this line)
remember to email me your contact to [email protected] (do not remove this line)
payment only when GB closed. will sent mass email on instruction then.
update list (do not remove this line)
alf08 - GN sound deadener x 40 pcs (can you give the link for this product, i cannot find it in taobao)
alf08 - claybar x 2 pcs http://item.taobao.com/item.htm?id=7671922050&cm_cat=26
Edited by Alf08
alf08 - Fuhe foam 10mm x 10pcs
Hi i would like to order the door sealing strip for my Lancer CS3 but no ideal need how long? can advise!
typical 25m is enough for whole car
Tweakmax2 - door seal 25m http://item.taobao.com/item.htm?id=4763065532&
Chemluber - Fuhe foam 10mm x 10pcs
Chemluber - GN sound deadener x 10 pcs
Chemluber - door seal 30m http://item.taobao.com/item.htm?id=4763065532&
Chemluber - door seal 10m http://item.taobao.com/item.htm?id=4850053866&
Chemluber - claybar x 2 pcs http://item.taobao.com/item.htm?id=7671922050&cm_cat=26
Chemluber - tools 1 set http://item.taobao.com/item.htm?id=2801074438&
Chemluber - roller 1 pc http://item.taobao.com/item.htm?id=9226338210&
Tomminator - EL Car Sticker x 2 pcs http://item.taobao.com/item.htm?id=4352100517
Eric211 - (qty. 1) http://item.taobao.com/item.htm?id=10663485030
Eric211 - (qty. 1) http://item.taobao.com/item.htm?id=8445098941
Eric211 - (qty. 1) (for model: 悦动2010款) http://item.taobao.com/item.htm?id=7752941605
Eric211 - (qty. 1 pair) http://item.taobao.com/item.htm?id=9577661771
Eric211 - (qty. 1) http://item.tmall.com/item.htm?id=91581000...rc=1&is_b=1
Cynidejunkie - door seal 30m http://item.taobao.com/item.htm?id=4763065532&
Hi stan, i've emailed you my contact as well. do check thanks
Edited by Cynidejunkie
mRSlow - Fuhe foam 10mm x 10pcs
mRSlow - GN sound deadener x 10 pcs
mRSlow - http://item.taobao.com/item.htm?id=9226338210& X 1 ( Contact in ur PM. Do let me know the total cost)
Lancer7210 - door seal typical 25m
Got to ensure adhesive is good enough. Did it for my car at an audio shop sometime back. 3M brand. Some parts started coming off within a few days. Got frustrated with the untidy look, ended up removing everything. Was a waste of money.
some of these seals are advertised stating that the adhesives are from 3M. i think you have got the fake ones. real 3M adhseives are super sticky and will not peel off
