Green_carnation Clutched December 26, 2010 Share December 26, 2010 I heard or have read somewhere that there's a vacuum function in a powered hand drill.. and that when drilling, all the dust will be vacuumed into a compartment built-in in the drill. Anyone knows and come across this kinda drill? I wanna get one.. Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
GLZT 6th Gear December 26, 2010 Share December 26, 2010 Never heard of it before, maybe you can just drill traditionally with one hand and hold a vaccum cleaner on the other hand? If it exist, I doubt the vaccum is strong enough unless the entire drill is going to be very huge. Link to post Share on other sites More sharing options...
Sunlight 1st Gear December 26, 2010 Share December 26, 2010 drilling with one hand is dangerous. better get someone to help hold the vacuum cleaner. Link to post Share on other sites More sharing options...
Bystander50 5th Gear December 26, 2010 Share December 26, 2010 if you're concerned about the dust flying around when drilling, there's a cheap n simple solution. Go to those medical shops that sell bottled herbal drinks. Once u finish, throw away the bottle and keep the cap. These caps are usually quite big. Drill a hole ard the center of it. When u are about to drill, position the drill bit n press the cap onto the wall. All the dust will be collected onto the cap. A small amount may spill off. Just vacuum the cap and the hole, the amount of dust is greatly reduced. Been using this method when I do drilling. Link to post Share on other sites More sharing options...
GSwhite 1st Gear December 26, 2010 Share December 26, 2010 http://www.hilti.com.sg/holsg/page/module/...p;nodeId=-36181 check it out at HILTI, basically have to select a drill model, and buy this 'dust removal attachment' for the drill. I had seen some workmen using BOSCH with a same kind of dust remval or vacumn, but can't find them in their web. Heard that they're not cheap 4-500++ per set incl drill On 12/26/2010 at 3:27 PM, Green_carnation said: I heard or have read somewhere that there's a vacuum function in a powered hand drill.. and that when drilling, all the dust will be vacuumed into a compartment built-in in the drill. Anyone knows and come across this kinda drill? I wanna get one.. Thanks Link to post Share on other sites More sharing options...
Chewbacca 1st Gear December 26, 2010 Share December 26, 2010 So, you want to drill AND suck, eh? Hehehee. Link to post Share on other sites More sharing options...
GSwhite 1st Gear December 26, 2010 Share December 26, 2010 On 12/26/2010 at 4:24 PM, GSwhite said: http://www.hilti.com.sg/holsg/page/module/...p;nodeId=-36181 check it out at HILTI, basically have to select a drill model, and buy this 'dust removal attachment' for the drill. I had seen some workmen using BOSCH with a same kind of dust remval or vacumn, but can't find them in their web. Heard that they're not cheap 4-500++ per set incl drill looks something like that: Link to post Share on other sites More sharing options...
Green_carnation Clutched December 26, 2010 Author Share December 26, 2010 On 12/26/2010 at 4:00 PM, GLZT said: Never heard of it before, maybe you can just drill traditionally with one hand and hold a vaccum cleaner on the other hand? If it exist, I doubt the vaccum is strong enough unless the entire drill is going to be very huge. thanks bro.. cant rmb where i hv read about it.. trying hard to recall.. Link to post Share on other sites More sharing options...
Green_carnation Clutched December 26, 2010 Author Share December 26, 2010 On 12/26/2010 at 4:27 PM, Chewbacca said: So, you want to drill AND suck, eh? Hehehee. yeah drill and suck.. suck clean clean.. Link to post Share on other sites More sharing options...
Green_carnation Clutched December 26, 2010 Author Share December 26, 2010 On 12/26/2010 at 4:33 PM, GSwhite said: looks something like that: wow thanks bro for the link... i'll try to find out more from there.. Link to post Share on other sites More sharing options...
GSwhite 1st Gear December 26, 2010 Share December 26, 2010 On 12/26/2010 at 4:43 PM, Green_carnation said: wow thanks bro for the link... i'll try to find out more from there.. Bro, Let me know the price after you find out, i'm quite tempted to get one too.. Link to post Share on other sites More sharing options...
Ngck 3rd Gear December 26, 2010 Share December 26, 2010 just paste onto the wall something like a paper soap holder (fold yourself using A4 or newspaper) under the hole you want to drill.... 90% of the dust will drop into it...... i thought of buying these vacuum type also.. but i think it expensive and so far i never seen one yet. maybe only pro use after how many times you are going to use the drill.... unless its part of your working tools Link to post Share on other sites More sharing options...
Gabriel 1st Gear December 26, 2010 Share December 26, 2010 reminds me of M16 after firing a round.. round is kept in the pouch On 12/26/2010 at 4:41 PM, Green_carnation said: thanks bro.. cant rmb where i hv read about it.. trying hard to recall.. Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 27, 2010 Share December 27, 2010 (edited) Here is one from US maker DeWatt. Edited December 27, 2010 by Yeobh Link to post Share on other sites More sharing options...
Freestylers09 5th Gear December 27, 2010 Share December 27, 2010 The best way is use a unwanted paper fold like kachang puteh cone shap use a scotch tape and put under the hole wana drill fast easy n save cost Link to post Share on other sites More sharing options...
Rainman 1st Gear December 27, 2010 Share December 27, 2010 or another way is just self improvise, duct take a portable vacuum near a drill bit.... can use it on any drill as well. Link to post Share on other sites More sharing options...
Yeshe Turbocharged December 27, 2010 Share December 27, 2010 On 12/26/2010 at 3:27 PM, Green_carnation said: I heard or have read somewhere that there's a vacuum function in a powered hand drill.. and that when drilling, all the dust will be vacuumed into a compartment built-in in the drill. Anyone knows and come across this kinda drill? I wanna get one.. Thanks depends wat u intend to use it for. these drills with vacuum mostly used by contractors when doing their work in public areas so that the dust do not affect the public. if at home, just any drill with someone holding on a conventional vacuum will do the job effectively. Link to post Share on other sites More sharing options...
Gatier Neutral Newbie December 27, 2010 Share December 27, 2010 On 12/26/2010 at 3:27 PM, Green_carnation said: I heard or have read somewhere that there's a vacuum function in a powered hand drill.. and that when drilling, all the dust will be vacuumed into a compartment built-in in the drill. Anyone knows and come across this kinda drill? I wanna get one.. Thanks Hi, you could get something like a Karcher DDC50. should cost about $50 at selffix or homfix. ↡ Advertisement Link to post Share on other sites More sharing options...
Electrical appliances
Power Tools Brand - Milwaukee versus the rest
Encounters with tyre shop
