Hand drill.. with vacuum?
Green_carnation
I heard or have read somewhere that there's a vacuum function in a powered hand drill.. and that when drilling, all the dust will be vacuumed into a compartment built-in in the drill.
Anyone knows and come across this kinda drill? I wanna get one..
Thanks :D
Never heard of it before, maybe you can just drill traditionally with one hand and hold a vaccum cleaner on the other hand? If it exist, I doubt the vaccum is strong enough unless the entire drill is going to be very huge.
if you're concerned about the dust flying around when drilling, there's a cheap n simple solution.
Go to those medical shops that sell bottled herbal drinks. Once u finish, throw away the bottle and keep the cap. These caps are usually quite big. Drill a hole ard the center of it.
When u are about to drill, position the drill bit n press the cap onto the wall. All the dust will be collected onto the cap. A small amount may spill off. Just vacuum the cap and the hole, the amount of dust is greatly reduced. Been using this method when I do drilling.
http://www.hilti.com.sg/holsg/page/module/...p;nodeId=-36181
check it out at HILTI, basically have to select a drill model, and buy this 'dust removal attachment' for the drill.
I had seen some workmen using BOSCH with a same kind of dust remval or vacumn, but can't find them in their web.
Heard that they're not cheap 4-500++ per set incl drill
Thanks :D
looks something like that:
thanks bro.. cant rmb where i hv read about it.. trying hard to recall..
wow thanks bro for the link... i'll try to find out more from there..
Bro,
Let me know the price after you find out, i'm quite tempted to get one too.. ^_^
just paste onto the wall something like a paper soap holder (fold yourself using A4 or newspaper) under the hole you want to drill....
90% of the dust will drop into it......
i thought of buying these vacuum type also.. but i think it expensive and so far i never seen one yet. maybe only pro use
after how many times you are going to use the drill.... unless its part of your working tools
Thanks :D
depends wat u intend to use it for. these drills with vacuum mostly used by contractors when doing their work in public areas so that the dust do not affect the public. if at home, just any drill with someone holding on a conventional vacuum will do the job effectively.
Thanks :D
Hi, you could get something like a Karcher DDC50. should cost about $50 at selffix or homfix.
