Lightweight Crank pulley
Enforcer533
Hi all
Hi i am thinking of changing to a light weight crank pulley. Does it help on
improving the car performance ? Roughly how much does it cost ??
Thanks .
Pls search thru threads talking about light weight crank pulleys and you will know the problems associated with it. if you want better acceleration, go for a light weight flywheel instead.
please dun use mod or lighten flywheel in your everyday car. It might just send your engine to the workshop for a complete overhaul due to too much vibration. google more if u want.
I had a lighten crank pulley it in my old car. Help pick up a bit in the low end. Thats about it. Its not too expensive mod. Power/torque gain, not too much. At most 1-2hp if at all.
Its up to you lah. Like Versatile said, after a while, you won't feel the different, I guess its the same with all mod, unless you have mod that increase your hp significantly.
I believe cheaper and easier to inflate tire 10% above recommended pressure
hi bro inflate tyre pressure too high will make u lose grip during cornering right ??
No mention what tyre inflation pressure is too high
No mention what road surface
No mention what travelling speed
No mention turning radius of corner
No mention pattern of tire
No mention weight of vehicle
No mention road adhersion of vehicle design
No mention on driving technique/skill of driver
No idea how to reply with logical/sensible answer
with light weight stuff you won in the resposive time of the engine, but always are problems with this kind of work, is important know how much material yo can remove and then remove less, so you get less effect but your engine must run more time
Do you think the manufacturer purposely put a heavy crank pulley in the engine to sabotage the performance? Please think carefully before performing any mods.
he reason why most aftermarket crank pulleys are a lot lighter is because they are missing harmonic dampeners that help absorb vibrations. Without the harmonic dampener it is much easier for a early crank pulley failure to happen and you'll just end up spending more money.
Edited by Sabe
Actually, the material use is also a factor. Most Manufacturer use carbon steel, which are heaver, while after market ones may use aluminium which is a much lighter metal, but more expensive. From a cost point of view, using the heavy steel makes sense.
Car production is about compromising. When they decided to launch a new car, they will set a target price, & design their car base on this target. They will decide, where to put more money, where less. So it doesn't mean what comes out of the factory is the best.
bro no offence but i believe people in this forum consist of newbies to the moderate to the extremely knowledgeable, so we should help each other.of course newbies have no idea or limited idea on the issues u mentiones above (except the last one u qoute! lol! ).
