Crazecow Neutral Newbie December 14, 2010 Share December 14, 2010 Seriously, I don't quite understand. I seen several cars having Brembo (mostly Brembo lar) BBKs. Then I see their rear brakes.... WTF.... Drum brakes?? Whats the point of using Brembo brakes for the front and your rear is drum brake? You will create such a big brake imbalance. I did use Brembo 4 pots before with 325mm rotors front but stock rear and I lock up my front on hard braking (cause no ABS). It really sucks. I believe ABS should that but whats the point with ABS kicking in all the time? Then whats worse is that they use big Calipers (all looks like 4 pot brakes) but the rotors are very small. Caliper look so big but rotors so small? For what? ↡ Advertisement Link to post Share on other sites More sharing options...
Baphomet 3rd Gear December 14, 2010 Share December 14, 2010 fake covers? Link to post Share on other sites More sharing options...
JaydenSTI 1st Gear December 14, 2010 Share December 14, 2010 Seriously, I don't quite understand. I seen several cars having Brembo (mostly Brembo lar) BBKs. Then I see their rear brakes.... WTF.... Drum brakes?? Whats the point of using Brembo brakes for the front and your rear is drum brake? You will create such a big brake imbalance. I did use Brembo 4 pots before with 325mm rotors front but stock rear and I lock up my front on hard braking (cause no ABS). It really sucks. I believe ABS should that but whats the point with ABS kicking in all the time? Then whats worse is that they use big Calipers (all looks like 4 pot brakes) but the rotors are very small. Caliper look so big but rotors so small? For what? those are brake cover only, take a close look next time and u will notice the original metal caliper cover is hidden under the red BREMBO cover...... Link to post Share on other sites More sharing options...
Crazecow Neutral Newbie December 14, 2010 Author Share December 14, 2010 fake covers? I don't know. Cause I don't look at them close up. But some do look fake to me. Give them benefit of doubt, I assume they are real ones. But I just wonder whats the point? Link to post Share on other sites More sharing options...
Benarsenal Turbocharged December 14, 2010 Share December 14, 2010 Style only lah. Link to post Share on other sites More sharing options...
Icebrush79 4th Gear December 14, 2010 Share December 14, 2010 Style only lah. Yeah, most bread and butter car has them for aesthetic purposes only....... Sorta like an ego booster as well.... Link to post Share on other sites More sharing options...
JX83 3rd Gear December 14, 2010 Share December 14, 2010 Seriously, I don't quite understand. I seen several cars having Brembo (mostly Brembo lar) BBKs. Then I see their rear brakes.... WTF.... Drum brakes?? Whats the point of using Brembo brakes for the front and your rear is drum brake? You will create such a big brake imbalance. I did use Brembo 4 pots before with 325mm rotors front but stock rear and I lock up my front on hard braking (cause no ABS). It really sucks. I believe ABS should that but whats the point with ABS kicking in all the time? Then whats worse is that they use big Calipers (all looks like 4 pot brakes) but the rotors are very small. Caliper look so big but rotors so small? For what? I heard that is more dangerous if u put on the brake cover on.. Since u need to drill hole in order to put up the cover.. Link to post Share on other sites More sharing options...
Aeromania 1st Gear December 14, 2010 Share December 14, 2010 These are people who buy things that they dun need Link to post Share on other sites More sharing options...
Thedream 3rd Gear December 14, 2010 Share December 14, 2010 Seriously, I don't quite understand. I seen several cars having Brembo (mostly Brembo lar) BBKs. Then I see their rear brakes.... WTF.... Drum brakes?? Whats the point of using Brembo brakes for the front and your rear is drum brake? You will create such a big brake imbalance. I did use Brembo 4 pots before with 325mm rotors front but stock rear and I lock up my front on hard braking (cause no ABS). It really sucks. I believe ABS should that but whats the point with ABS kicking in all the time? Then whats worse is that they use big Calipers (all looks like 4 pot brakes) but the rotors are very small. Caliper look so big but rotors so small? For what? cos they are like you when you were with the BBK in front and stock rear brakes Link to post Share on other sites More sharing options...
SimonTan 2nd Gear December 14, 2010 Share December 14, 2010 (edited) You know nowadays many taxi like to step brake. Its better to have the best set up so that the car can stop in time behind the taxi. The cost of BKK how much? $2-3k? It pays for itself, if it can save u from banging into a taxi just once! Always be prepared. Edited December 14, 2010 by SimonTan Link to post Share on other sites More sharing options...
I-LOVE-CARS 1st Gear December 14, 2010 Share December 14, 2010 Mostly just a cover only...other people see thinks you cool what ↡ Advertisement Link to post Share on other sites More sharing options...
Unusual or Rare Cars - Part 3
Electric cars
Electric cars
Guess the Cars
Guess the Cars
How many here kena rape, attempted rape or molested?
