villan 2nd Gear November 16, 2021 Share November 16, 2021 @ER-3682 when i turn out of a carpark (downslope with hump), there will be a TUK sound. this is the front suspension issue that you are referring to? or is it a steering rack issue? ↡ Advertisement Link to post Share on other sites More sharing options...
Melody288 2nd Gear November 16, 2021 Share November 16, 2021 1 hour ago, villan said: @ER-3682 when i turn out of a carpark (downslope with hump), there will be a TUK sound. this is the front suspension issue that you are referring to? or is it a steering rack issue? I also heard this TUK sound - usually 1st turn out downslope in the morning. After that no sound till the next morning. Link to post Share on other sites More sharing options...
villan 2nd Gear November 16, 2021 Share November 16, 2021 @Melody288 same...wonder if its worthwhile bringing in to TEK... Link to post Share on other sites More sharing options...
ER-3682 Twincharged November 16, 2021 Share November 16, 2021 9 hours ago, villan said: @ER-3682 when i turn out of a carpark (downslope with hump), there will be a TUK sound. this is the front suspension issue that you are referring to? or is it a steering rack issue? Yes,could be it... Link to post Share on other sites More sharing options...
Blitz74 1st Gear November 18, 2021 Share November 18, 2021 @villan @Melody288 This is a known problem for M6. Feedback on your next service and they will replace the parts when the parts are in. Link to post Share on other sites More sharing options...
subnozzle Neutral Newbie November 19, 2021 Share November 19, 2021 Anyone tried bringing mazda 6 bodykit from taobao? Link to post Share on other sites More sharing options...
Yjunz Neutral Newbie November 26, 2021 Share November 26, 2021 How much for normal servicing in outside workshop ? The normal oil change and where would you go? Link to post Share on other sites More sharing options...
ER-3682 Twincharged November 26, 2021 Share November 26, 2021 10 hours ago, Yjunz said: How much for normal servicing in outside workshop ? The normal oil change and where would you go? KHY,about $160.00 Shell 0w20 & Oil Filter. Link to post Share on other sites More sharing options...
zenooi Clutched November 28, 2021 Share November 28, 2021 Hi, any kind soul can recommend leather repair for driver seat, 4.5 years old, left side facing exit has teared. Link to post Share on other sites More sharing options...
zenooi Clutched November 28, 2021 Share November 28, 2021 Any bros have done their 120,000km servicing, any estimated cost for this major servicing? Link to post Share on other sites More sharing options...
ER-3682 Twincharged November 28, 2021 Share November 28, 2021 26 minutes ago, zenooi said: Any bros have done their 120,000km servicing, any estimated cost for this major servicing? Go outside do..see what you want to change...Engine Oil,filter,ATF,Air Filter,Spark Plugs & Belt+Tensioner...Brake Fluid. Link to post Share on other sites More sharing options...
Banz86 5th Gear November 28, 2021 Share November 28, 2021 @cckboy I didn't change my sequence. If I make any changes, I just press M + 1 or 2. Just one day after my battery died and did a replacement. My car seat couldn't store the memory and I had to adjust the seat every time family members use the car. I'm not sure what I did but after going through the process, it works. 1 Link to post Share on other sites More sharing options...
alex976 5th Gear December 5, 2021 Share December 5, 2021 Bros, any idea wads the name of the plastic housing circled in blue? i accidentally crack mine when i change my front dash cam myself so nw when i drive above 50km/hr can hear a very irritating loose flapping sound. wanna buy a new one to replace but dunno wad it is called. try googling it but no results Link to post Share on other sites More sharing options...
ER-3682 Twincharged December 5, 2021 Share December 5, 2021 7 hours ago, alex976 said: Bros, any idea wads the name of the plastic housing circled in blue? i accidentally crack mine when i change my front dash cam myself so nw when i drive above 50km/hr can hear a very irritating loose flapping sound. wanna buy a new one to replace but dunno wad it is called. try googling it but no results Sensors Back Cover. Link to post Share on other sites More sharing options...
ER-3682 Twincharged December 5, 2021 Share December 5, 2021 (edited) 8 hours ago, alex976 said: Bros, any idea wads the name of the plastic housing circled in blue? i accidentally crack mine when i change my front dash cam myself so nw when i drive above 50km/hr can hear a very irritating loose flapping sound. wanna buy a new one to replace but dunno wad it is called. try googling it but no results Double check did you break it.?I took out before,it is a 2 pieces design...left & right piece just joint together.. Edited December 5, 2021 by ER-3682 Link to post Share on other sites More sharing options...
alex976 5th Gear December 5, 2021 Share December 5, 2021 3 hours ago, ER-3682 said: Double check did you break it.?I took out before,it is a 2 pieces design...left & right piece just joint together.. i broke the one on the left side Link to post Share on other sites More sharing options...
QQDreamer 4th Gear December 5, 2021 Share December 5, 2021 6 hours ago, alex976 said: i broke the one on the left side if cannot find the new cover. alternative is to use tape. hope you can find the covre soon. else another alternative is to go back mazda agent to order it if not can try scrapyard. 1 Link to post Share on other sites More sharing options...
ER-3682 Twincharged December 5, 2021 Share December 5, 2021 7 hours ago, alex976 said: i broke the one on the left side If just broke the Clip,just put a bit of Black Sillicon...or go Scrapyard to find.[i just scrap mine 3 months ago]. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Next Generation Toyota Crown
[Spyshots] 2025 3rd Generation Mercedes CLA
