MAZDA 6
Voxy28
Boh sim lah u..... must wait till so long....... how about tomorrow I burn give u instead? [:p]
No need lah, I already got savings/stocks/bonds liow. But kumsian your kind thoughts.
Now, if you don't mind hor, this thread is about Mazda 6 and Mazda 6 alone, the discussion has digressed
past the discussion topic. I will thus end here and not go further into replying you.
Enough is enough, and respect has to be given to the TS. Thank you.
[thumbsup] .... Agreed.... must respect TS...... thanks for the timely reminder! [nod]
Bros, any recommendation for replacement tyres? So far only found BS GR-90 and Michelin XM2 to have the 205/60/R15 profile. Don't really wanna change rims also, so will stick to this size. Any other tyres that have this size? Not looking to giam here there for the only 4 contact points to the road. Any advice is welcome. :)
Need advice here. Today I found out that my floor carpet (driver's side) both front and rear were soaked with water. A check on the passenger's side showed no sign of it being wet (v dry). What could have happened? leak from under carriage? so when driving on wet roads, water sip through? Anyone experienced it before? Appreciate any advice from anyone.
Thanks.
Edited by Frostie
hi all mazda 6 owner,i jus bought a 2nd hand 2005 mazda 6 n i cant find e trunk release lever.usually for most car,e lever is together with e pump lever but mine is not.can u all advice mi where is e lever?thks in advance ^^
There's none in the car, the release lever is at the boot itself...
could it be air con pipe jam?
Any smell of coolant? Ever had once before in my 99 mivec. Floor wet because a hose to my heater leak. Did a bypass and everything good to go. But mine didn't wet all the way to rear.
yep the driver cannot help with the trunk release...passenger has to "self serve" with the release lever at the boot :)
Thanks.
check air-con pipping possible leak?
Hi all, anyone using HID on their 2006-2007 Mazda 6 SP? How's the visibility compared to the stock bulb?
Thinking if I should convert to HID or get a HIR bulb... cost are very close I guess?
Hmm.....HID is not legal and the TP is quite "active" in clamping down on HID so u might want to re-consider.
If you need a set, I have 1 used set for my Mazda 6...used for <1 year which i can sell to u at a low cost
The Michelin is good, very quiet, and good grip as well. I changed my last M6 tires to these.
There isn't one inside the car, when all doors are locked, the trunk is locked as well, only way to open is from the trunk itself, you got to go behind and press the lever to open the trunk. Fuel and bonnet same area.
Those lever types are old skool, most new cars come without. You need to remote unlock and press a soft switch on the boot itself to open.
The question came from a bro who bought an old 2005 Mazda 6 mah..
