Mattjoe 1st Gear November 15, 2010 Share November 15, 2010 Accidentally scratched my rims against kerb. Can any one recommend repair? Where to go? Thanks in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
Davidklt Supercharged November 15, 2010 Share November 15, 2010 (edited) Try Arrow Tyres at First Center. Edited November 15, 2010 by Davidtkl Link to post Share on other sites More sharing options...
Mattjoe 1st Gear November 15, 2010 Author Share November 15, 2010 Ok, thanks. Any idea how much it will cost? Link to post Share on other sites More sharing options...
Cerano 1st Gear November 15, 2010 Share November 15, 2010 have you considered diy sanding? Link to post Share on other sites More sharing options...
Mattjoe 1st Gear November 15, 2010 Author Share November 15, 2010 How do I do it? I'm not really a diy person when it comes to cars. If i can get it fixed cheap enough, i'll just send it in. Sekali do wrongly, rims will look like sh*, then i will be worse off... Link to post Share on other sites More sharing options...
Cerano 1st Gear November 15, 2010 Share November 15, 2010 How do I do it? I'm not really a diy person when it comes to cars. If i can get it fixed cheap enough, i'll just send it in. Sekali do wrongly, rims will look like sh*, then i will be worse off... i did on my rims and it was quite ok. just buy some sandpaper and lacquer. Link to post Share on other sites More sharing options...
Mattjoe 1st Gear November 15, 2010 Author Share November 15, 2010 Sand paper part i think i can handle, what kind of lacquer did you use? Link to post Share on other sites More sharing options...
Cerano 1st Gear November 15, 2010 Share November 15, 2010 Sand paper part i think i can handle, what kind of lacquer did you use? simple acrylic spray paint! Link to post Share on other sites More sharing options...
Mattjoe 1st Gear November 16, 2010 Author Share November 16, 2010 Thanks, will try this weekend. Link to post Share on other sites More sharing options...
Sony 1st Gear November 16, 2010 Share November 16, 2010 Hurry tyre along Bt Timah road, near Serene Center. about $20 per rim. depends on condition and finishing of your rim. Link to post Share on other sites More sharing options...
Swingarm 1st Gear November 16, 2010 Share November 16, 2010 do they do dent rim? mine go over pothole Link to post Share on other sites More sharing options...
Mattjoe 1st Gear November 16, 2010 Author Share November 16, 2010 Thanks for info. Will get a quote from them, only minor scratches. Link to post Share on other sites More sharing options...
Jeremylwf Neutral Newbie January 17, 2013 Share January 17, 2013 Hey Guys, Went a bit fast into the MSCP today and my back tire made contact with the kerb. See the picture below: anyone got lobang to get this rim re-sprayed? and how much? just some minor surface scratch so i guess it only need some sanding and spraying. would be great if the shop can lend a spare rim as I have to use the car daily for work. live at amk/yck area so any shop nearby will be great! Link to post Share on other sites More sharing options...
Junjian Neutral Newbie January 17, 2013 Share January 17, 2013 Hey Guys, Went a bit fast into the MSCP today and my back tire made contact with the kerb. See the picture below: http://postimage.org/image/lw4zl0j9z/ anyone got lobang to get this rim re-sprayed? and how much? just some minor surface scratch so i guess it only need some sanding and spraying. would be great if the shop can lend a spare rim as I have to use the car daily for work. live at amk/yck area so any shop nearby will be great! Wah bro, you made a long duration contact with the kerb sia. How come when you first made contact you never stop? Link to post Share on other sites More sharing options...
LookingBusy Neutral Newbie January 17, 2013 Share January 17, 2013 I also have some scratches on my rims after hitting the kerb when parking, is it okay to leave it alone and still safe to drive? My back tyre hit the kerb as well after reversing a little too fast Pls advise Link to post Share on other sites More sharing options...
Jeremylwf Neutral Newbie January 17, 2013 Share January 17, 2013 i went in a bit too fast and didnt negotiate the bend properly :( great way to end a tiring work day. Link to post Share on other sites More sharing options...
Dee_farrell Neutral Newbie January 17, 2013 Share January 17, 2013 Go to Kim Hoe..check under marketplace,tyres and rims & rims refurbishment column in here. Just did mine last week.workmanship very good and it looks like never been kerb rashed bfo. ↡ Advertisement Link to post Share on other sites More sharing options...
Lee Sheng Auto - One Stop Auto Repair Centre! From accident repair & claims, spray painting, diagnostics, general repairs to servicing.
Car repair and maintenance
Used Mercedes buyer spends $40,000 on repairs
Grinding racket
Grinding racket
Does rims change shape/warp over time?
