Noel Clutched November 8, 2010 Share November 8, 2010 Hi all, With more advance ionizers and other car odor removal gadgets available in the market, i do wonder if those traditional ones are still in use such as; 1. Pandan Leaves And Bread (Heard that it will attract pests) 2. Rolls Of Toilet Paper / Charcoal (Some say that your car might catch fire if it was parked directly under the sun, esp for owners who do not drive often such as OPC cars) 3. Turn on the car heater with your windows down (There are claims saying it will spoil your air-con faster) Are these claims fact or myth? Which one is better? The advance gadgets, the traditional methods or both? Personally, i use both charcoal gels/blocks and ionizers to neutralise the smell after a Sunday affair from the market. Your opinions and views. Thanks. Cheers! ↡ Advertisement Link to post Share on other sites More sharing options...
Boyboy 1st Gear November 8, 2010 Share November 8, 2010 I don't see how toilet paper could work, and I've never heard it mentioned before, but I can vouch for charcoal and its variants. For pandan leaves, it leaves a smell of its own. more to deter cockroaches, so I heard, but I never tried. Another mention is ground coffee. The key is not to eat in the car, and to air out the car after transporting strong smelling stuff. I personally avoid da-baoing cooked food in the car for this reason. When I park in unsheltered lot at workplace, I will also wind down the windows a crack (i got visors) to allow heat to escape, and also for ventilation to minimise the smell. My ride has very little smell (i ask my passengers to test for me too) despite more than 4 years and 60000km (yeah, previous owner didn't use it much). my previous ride 90k kms and 4 plus years now driven by my sis, stinks of stale car "air freshener". She uses ambi pur which will stay in the aircon system and smell quite bad after awhile.. ard 80 plus k when I was still driving it, no such issues. oh yes, I also use activated carbon gel blocks like u do. i buy from daiso! Link to post Share on other sites More sharing options...
Sky_vinz Clutched November 8, 2010 Share November 8, 2010 My Maier air ionizer does a good job at removing all kinds of smell. Be it fragrance or odor. Link to post Share on other sites More sharing options...
Dpsk Neutral Newbie November 8, 2010 Share November 8, 2010 oh. can i ask if you all know what can remove the ambi pure air refreshener smell? Link to post Share on other sites More sharing options...
Sirex Neutral Newbie November 8, 2010 Share November 8, 2010 (edited) Just bought this air purifier from caltex. The name is NewFresh. Basically it uses granular carbon to filter the air with the help of a fan. Pretty effective in my opinion as it removes tobacco scent in my car after merely 15min of usage. http://www.newfresh.com.sg/site/coral.html This is a locally developed product. Heard can even remove durian odour too. Got it at $39. Can use Thanks points to redeem too! Cheers! Edited November 8, 2010 by Sirex Link to post Share on other sites More sharing options...
Voodooman Supersonic November 8, 2010 Share November 8, 2010 oh. can i ask if you all know what can remove the ambi pure air refreshener smell? Max heat with blowers at max speed for a 20 minutes drive, repeat if necessary. Smell will be gone forever. It always work for me. Pandan leave is toally useless on cockroaches, from my 1 week experiment. Baygon is far more effective, gas them and they shall not return. Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged November 8, 2010 Share November 8, 2010 i have charcoal inside a used air freshener container, works well. Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear November 8, 2010 Share November 8, 2010 usually three options. 1) ionizer. 2) charcoal. 3) pandan leaves. ionizer and charcoal are odourless which i like it. pandan leaves will have a very strong smell, i don't like. other than that are car perfumes. but it can only solve the odour temporary. one more better way is to open all your doors during a hot & sunny day. let the moisture from your car to evaporate. hope it helps. =p Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged November 8, 2010 Share November 8, 2010 Charcoal 100% works! Link to post Share on other sites More sharing options...
Crazecow Neutral Newbie November 9, 2010 Share November 9, 2010 Charcoal does work. Its used in many products as an odour remover. Air ionizer also works to remove smell. Turning on the heater is to dry up the aircon coil. If its wet all the time, it will have a bad smell just like your house aircon. Actually its a good practice to dry the coil (don't need heater just off the compressor and let aircon blow out normal air) after you have used it. Just for the last 5-10min of your journey. It keeps the coil dry and keep the smell away. It also makes the coil last longer. Coil leaks arieses from corrosion due to water (Water + Aluminium = corrosion). However, have to take note of one thing. Charcoal and air ionizer only removes the smell, it does not get rid of the source of smell. Thus a better method would be to remove the smell from its source Eg. carpet and roof. All the fibers on these places trap dirt, oil (esp. from cigarette) etc..... Thus if you don't clean them, the smell will always be there. Link to post Share on other sites More sharing options...
Noel Clutched November 11, 2010 Author Share November 11, 2010 Another mention is ground coffee. Interesting. Ground coffee. Any reasons why it can remove the odor in our car? Link to post Share on other sites More sharing options...
Noel Clutched November 11, 2010 Author Share November 11, 2010 Just bought this air purifier from caltex. The name is NewFresh. Basically it uses granular carbon to filter the air with the help of a fan. Pretty effective in my opinion as it removes tobacco scent in my car after merely 15min of usage. http://www.newfresh.com.sg/site/coral.html This is a locally developed product. Heard can even remove durian odour too. Got it at $39. Can use Thanks points to redeem too! Cheers! Thanks for sharing. Perhaps can give it a try too. Link to post Share on other sites More sharing options...
Karebu 1st Gear November 11, 2010 Share November 11, 2010 (edited) charcoal works. get the biggest container from daiso. er, as for toilet paper. even the papers on their own kinda smell like s--t already. edit: charcoal is not the ji-tie ji-tie one for BBQ one hor. and the 'real thing' works better if u put in car and let them bake under the sun. any s--t smell should be gone. Edited November 11, 2010 by Karebu Link to post Share on other sites More sharing options...
Airy777 Neutral Newbie November 25, 2010 Share November 25, 2010 Charcoal works. Link to post Share on other sites More sharing options...
Wamphyri Neutral Newbie November 25, 2010 Share November 25, 2010 Hi All, I am also using charcoal from diaso, those circular kind about 5cm in diameter. I place one under the driver's seat and one on the dashboard and they seem to work quite well. May I ask how long is it before they need to be replaced? Currently those 2 pieces in my car has been there for about 5 months. Thanks. Link to post Share on other sites More sharing options...
GruneMedizin Neutral Newbie January 28, 2011 Share January 28, 2011 Hi any ideas on going to a shop for removing odor, Im about to buy a used car but the previous owner was a heavy smoker and the car stinks. So any ideas guys?? Link to post Share on other sites More sharing options...
Sky_vinz Clutched January 28, 2011 Share January 28, 2011 GruneMedizin: You may need to.. 1) Flush air-con and change filter. 2) Go for car cabin sanitizing treatment (Clean all fabric and seats). 3) Get an air ionizer too. It helps. Link to post Share on other sites More sharing options...
Altivo 3rd Gear January 28, 2011 Share January 28, 2011 charcoal... i get mine from daiso. Put one each under the front seats and one more in the boot ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding – Feb 2025
COE Bidding - January 2025
2024 Suzuki Swift
2024 Suzuki Swift
Australia: Car Rental in Melbourne
COE Bidding - December 2024
Used Car, what STA Inspection grade then can buy?
