Little_prince Supersonic November 6, 2010 Share November 6, 2010 I have a problem also. I cannot go Harwarezone website. The stupid Canon and Open Net Advertisement keeps repeating itself. Anyone has a solution? use adblock. google for it ↡ Advertisement Link to post Share on other sites More sharing options...
Little_prince Supersonic November 6, 2010 Share November 6, 2010 where can i find a reliable pc repair shop? so that i can confirm the fault. try pc clinic at simlim... quite reasonable and cheap Link to post Share on other sites More sharing options...
Mazdaowner Moderator November 6, 2010 Share November 6, 2010 Motherboard issue, have it replaced. when i turn on my laptop, it will auto off after a few minutes. this process will last a few times. it will only remain on after several attempts. and it will auto turn off in the middle of my work. i dun think it is over heated, the laptop has not even warm up yet. besides, i have a usb fan pad on. laptop running window vista. anyone experienced this before? scan virus nothing found too. Link to post Share on other sites More sharing options...
Ez_rider Neutral Newbie November 6, 2010 Share November 6, 2010 thanks for identifying but how to make the mouse work? Shutdown the laptop first and off the power.Take out the mouse from the usb slot and put it back again.Turn on your laptop.It should be detected by laptop unless your mouse is spoilt or your operating system corrupted. Link to post Share on other sites More sharing options...
Alechi 2nd Gear November 6, 2010 Share November 6, 2010 either motherboard faulty or CPU battery (20cts coin size) flat pray its the battery, otherwise be prepared to buy new PC if it's no longer under warranty when i turn on my laptop, it will auto off after a few minutes. this process will last a few times. it will only remain on after several attempts. and it will auto turn off in the middle of my work. i dun think it is over heated, the laptop has not even warm up yet. besides, i have a usb fan pad on. laptop running window vista. anyone experienced this before? scan virus nothing found too. Link to post Share on other sites More sharing options...
Dec_allion Clutched November 6, 2010 Share November 6, 2010 I have similar issue as TS but I often get a message is BIOS failed to update, loading default BIOS setting. Is. The battery going flat, as my system time is always reset back to the manufacture date Link to post Share on other sites More sharing options...
Tleslie 1st Gear November 6, 2010 Author Share November 6, 2010 sent my laptop to 1 of the simlim repair shop. diagonsed motherboard chipset problem and re-format hd. problem solved by spending $$$$ ↡ Advertisement Link to post Share on other sites More sharing options...
MyResponder app to call SCDF
Help with STA report remarks
