Trex101 3rd Gear November 11, 2010 Share November 11, 2010 guess depends on how much the car means to the owner... for me drive shaft i feel like getting both new ones...but after some thinking i guess recon ones enuf... 6months warranty and new dust covers... as for my power steering, i have checked the leak is from a bolt... very slight leak so much so that my power steering fluid is still almost max... i hear no sound and no loss in power for the steering rack... so i will just top up the fluid and monitor next oil change if the leak has gotten worse... another way is to put news paper under my car at night... next morning can check how serious the leak.... but my leak is not serious enuf to 'drip' yet... Try changing it to a Syn ATF for your power steering, normally these type of ATF will have seal conditioning properties, might slow or even stop your steering leak. RL D4 would be a good choice. Easy to DIY too, just salvage this type of pump from your used shampoo bottle and pump out all your PSF. Do it 2-3 time and your fluid will be almost 100% new. ↡ Advertisement Link to post Share on other sites More sharing options...
Ken4555 1st Gear November 11, 2010 Author Share November 11, 2010 Try changing it to a Syn ATF for your power steering, normally these type of ATF will have seal conditioning properties, might slow or even stop your steering leak. RL D4 would be a good choice. Easy to DIY too, just salvage this type of pump from your used shampoo bottle and pump out all your PSF. Do it 2-3 time and your fluid will be almost 100% new. thanks for the tip bro... if this works then will save so much hassle... Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 11, 2010 Share November 11, 2010 guess depends on how much the car means to the owner... for me drive shaft i feel like getting both new ones...but after some thinking i guess recon ones enuf... 6months warranty and new dust covers... as for my power steering, i have checked the leak is from a bolt... very slight leak so much so that my power steering fluid is still almost max... i hear no sound and no loss in power for the steering rack... so i will just top up the fluid and monitor next oil change if the leak has gotten worse... another way is to put news paper under my car at night... next morning can check how serious the leak.... but my leak is not serious enuf to 'drip' yet... Fr 2nd hand driveshaft, u better check how ty recon. Some places just grind n smoothen e 'crown' to stop e tak tak sound but it comes back soon after. If ty change a new CV joint with oem parts n properly done them maybe worth. If ty just grind, dont waste yr $.Get a new oem pair or just 1 side better. Yr ps bolt did u check if its tight? If it is, maybe it just needs a new washer or rubber gasket. Something is causing e fluid to leak fm there. Link to post Share on other sites More sharing options...
Ken4555 1st Gear November 12, 2010 Author Share November 12, 2010 Fr 2nd hand driveshaft, u better check how ty recon. Some places just grind n smoothen e 'crown' to stop e tak tak sound but it comes back soon after. If ty change a new CV joint with oem parts n properly done them maybe worth. If ty just grind, dont waste yr $.Get a new oem pair or just 1 side better. Yr ps bolt did u check if its tight? If it is, maybe it just needs a new washer or rubber gasket. Something is causing e fluid to leak fm there. thanks for the tip on my ps bolt... i think the leak is only from the bolt... my frd got 2sides 2nd hand driveshaft and the kok kok sound came back in a month... so i guess its suay? so far autosaver quote me $210 per side and $30 workmanship per side... works out to be $480.... they said its brand new made in Japan but its not Nissan OEM??? Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 13, 2010 Share November 13, 2010 thanks for the tip on my ps bolt... i think the leak is only from the bolt... my frd got 2sides 2nd hand driveshaft and the kok kok sound came back in a month... so i guess its suay? so far autosaver quote me $210 per side and $30 workmanship per side... works out to be $480.... they said its brand new made in Japan but its not Nissan OEM??? Like i said, last time i tried those 2nd hand ''drive-shaft'' n e sound came back very soon after so i know fr a fact, its not worth. Since then none of my cars needed to change drive shaft cos my driving style i dont turn steering when car is not moving. I use my cars fr abt 10 years b4 i change cos i am a poor man. Wow looking at e cost to change driveshaft nwadays, damm ex. If i ever do need to change ds, i wil look around fr best price fr OEM parts n just change e CV joint as it sud b cheaper. HKS used to b a popular brand of jap cv joint. Now i not sure cos i never needed to change fr a very long time already. Link to post Share on other sites More sharing options...
Forte3737 5th Gear November 13, 2010 Share November 13, 2010 Try changing it to a Syn ATF for your power steering, normally these type of ATF will have seal conditioning properties, might slow or even stop your steering leak. RL D4 would be a good choice. Easy to DIY too, just salvage this type of pump from your used shampoo bottle and pump out all your PSF. Do it 2-3 time and your fluid will be almost 100% new. will this method create air bubbles in the PSF? Link to post Share on other sites More sharing options...
Trex101 3rd Gear November 13, 2010 Share November 13, 2010 will this method create air bubbles in the PSF? 100% no, i did it many time to my own vehicle and my wife car, no problem at all. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 14, 2010 Share November 14, 2010 will this method create air bubbles in the PSF? Dont worry abt air bubbles in psf. It is not like brake fluid where r fluid is stagnant. Psf is pumped round n round like yr coolant. U might get foaming in e psf but that means its already overdue to b changed. When i changed mine recently, i did notice e fluid foaming slightly. After it was changed, its nice n fluid again without any foaming. Link to post Share on other sites More sharing options...
Thedream 3rd Gear November 14, 2010 Share November 14, 2010 Dont worry abt air bubbles in psf. It is not like brake fluid where r fluid is stagnant. Psf is pumped round n round like yr coolant. U might get foaming in e psf but that means its already overdue to b changed. When i changed mine recently, i did notice e fluid foaming slightly. After it was changed, its nice n fluid again without any foaming. I think it does matter that there's air in the power steering fluid, but of course don't take my word for it... http://www.ehow.com/how_6181809_remove-air...ing-system.html http://www.jpmagazine.com/techarticles/sus...pump/index.html http://www.thirdgen.org/noises-power-steering-pump Link to post Share on other sites More sharing options...
Thedream 3rd Gear November 14, 2010 Share November 14, 2010 Dont worry abt air bubbles in psf. It is not like brake fluid where r fluid is stagnant. Psf is pumped round n round like yr coolant. U might get foaming in e psf but that means its already overdue to b changed. When i changed mine recently, i did notice e fluid foaming slightly. After it was changed, its nice n fluid again without any foaming. After replying, I noticed you mentioned coolant as well, so went to find another few websites that say it's important not to have air bubbles in coolant. BTW, in the first link in my post above, it says that foam is caused by air bubbles, not because it needs to be replaced. http://www.buzzle.com/editorials/6-28-2006-100752.asp http://www.denlorstools.com/home/dt1/page_...ing_system.html http://www.bmwe34.net/Wiki/tiki-index.php?...ant+replacement Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 14, 2010 Share November 14, 2010 I think it does matter that there's air in the power steering fluid, but of course don't take my word for it... http://www.ehow.com/how_6181809_remove-air...ing-system.html http://www.jpmagazine.com/techarticles/sus...pump/index.html http://www.thirdgen.org/noises-power-steering-pump Air in ps fluid is easily expelled as u turn e steering. I just turn steering fm lock to lock to get any air out. Then just top-up to e full mark n u r done. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 14, 2010 Share November 14, 2010 (edited) After replying, I noticed you mentioned coolant as well, so went to find another few websites that say it's important not to have air bubbles in coolant. BTW, in the first link in my post above, it says that foam is caused by air bubbles, not because it needs to be replaced. http://www.buzzle.com/editorials/6-28-2006-100752.asp http://www.denlorstools.com/home/dt1/page_...ing_system.html http://www.bmwe34.net/Wiki/tiki-index.php?...ant+replacement Dunno leh. My ps fluid change no problems. I just expell e old fluid n replace with fresh fluid. E old fluid was foamy. I checked e fresh fluid n there was no foaming. Coolant change u do need to bleed any air in e system but mine is self bleeding so i just run engine n top-up coolant n it was done. Maybe if u not sure how to do, just go to a reputable ws n get them to do it fr u n u can watch how it is done. I think u hv not done these things b4 so better u let e mech do it 1st n u can learn from him. I've done these stuff b4 so mine is practical experience wh hands on unlike u who seem to put too much reliance on what u read only. After u hv ''hands-on'' a few times then u wil ustand how its done much better. Edited November 14, 2010 by Pisces69 Link to post Share on other sites More sharing options...
Thedream 3rd Gear November 15, 2010 Share November 15, 2010 Air in ps fluid is easily expelled as u turn e steering. I just turn steering fm lock to lock to get any air out. Then just top-up to e full mark n u r done. no prob. Was just confirming that we do need to worry about air bubbles in the power steering fluid, they are not removed by the pump, and foaming is caused by air bubbles and not an indication that the fluid needs to be replaced. Dont worry abt air bubbles in psf. It is not like brake fluid where r fluid is stagnant. Psf is pumped round n round like yr coolant. U might get foaming in e psf but that means its already overdue to b changed. When i changed mine recently, i did notice e fluid foaming slightly. After it was changed, its nice n fluid again without any foaming. Link to post Share on other sites More sharing options...
Thedream 3rd Gear November 15, 2010 Share November 15, 2010 Maybe if u not sure how to do, just go to a reputable ws n get them to do it fr u n u can watch how it is done. I think u hv not done these things b4 so better u let e mech do it 1st n u can learn from him. I've done these stuff b4 so mine is practical experience wh hands on unlike u who seem to put too much reliance on what u read only. After u hv ''hands-on'' a few times then u wil ustand how its done much better. no prob. I leave it to my workshop to change the fluids. Just so long as you understand the importance of not having air bubbles in the power steering fluid or coolant or engine oil, for that matter. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 15, 2010 Share November 15, 2010 no prob. I leave it to my workshop to change the fluids. Just so long as you understand the importance of not having air bubbles in the power steering fluid or coolant or engine oil, for that matter. Ok tks fr yr advice. Yr comments hv been noted. ↡ Advertisement Link to post Share on other sites More sharing options...
Steering leather wrapping
Porsche’s First Steer-By-Wire System Is Designed For Less Feedback, Not More
Home power back up
Home power back up
Steering column
Steering column
Honda Stream 2009 No Power and High fuel Consumption
Alcades power optimizer
Microsoft to buy solar power in Singapore
