Icyfreakass 1st Gear August 22, 2011 Share August 22, 2011 upz this thread again! anyone had done DRL on your ride? for example, below picture. how much is the damage, the part model and where did you get it done? how to know whether it is really bright enough to see during day time? note: pls do not discuss about LTA approval or not, this and that. thanks. =p We have something similar to this. Will be installing later and post up pics soon after. ↡ Advertisement Link to post Share on other sites More sharing options...
SimonTan 2nd Gear August 22, 2011 Share August 22, 2011 Are there DRL that is exactly the same design as the fog light? Meaning the the fog light IS the LED DRL. Since fog lights are sort of legal....many cars can also install fog lights and will not face police trouble. I know my Honda jazz can install fog lights. If the DRL can be made exactly into the fog lights shape, then it will acceptable right? 1 Link to post Share on other sites More sharing options...
Achee 4th Gear September 14, 2011 Share September 14, 2011 Fog light is not legal unless it is factory fitted, same as DRL 1 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged August 28, 2012 Share August 28, 2012 hi all could anyone share if you have went through & passed vehicle inspection with DRL covered? else i might have to uninstall mine first b4 inspection b4 fix it back again. TIA. 1 Link to post Share on other sites More sharing options...
Kwanheng 1st Gear August 28, 2012 Share August 28, 2012 hi all could anyone share if you have went through & passed vehicle inspection with DRL covered? else i might have to uninstall mine first b4 inspection b4 fix it back again. TIA. just don't let them see the switch, tell them its from previous owner and its faulty. 1 Link to post Share on other sites More sharing options...
Cedricchoo Neutral Newbie August 28, 2012 Share August 28, 2012 hi all could anyone share if you have went through & passed vehicle inspection with DRL covered? else i might have to uninstall mine first b4 inspection b4 fix it back again. TIA. Went thru with DRL (Exposed) + on/off switch for my Accord last year. No problems. Not too sure if the Philips brand helped.... I guess this can be abit heng suay type of inspection.... Link to post Share on other sites More sharing options...
Fuelsaver Supercharged August 28, 2012 Share August 28, 2012 (edited) just don't let them see the switch, tell them its from previous owner and its faulty. but if tell them faulty, they could say y don't i uninstall rite? or u or ur fren actually tried before n it ok w them? which centre? btw, mine was self-installed, followed manual one. no light = drl on; light = drl off, although i could just remove +ive connector n tape up to ensure always in off state. but for drl attached to my grille - need to remove or cover (like spot light requirement i read fr l-t-a webby)? i think if inspector wants, he could treat it that way i heard rite? Edited August 28, 2012 by Fuelsaver Link to post Share on other sites More sharing options...
Fuelsaver Supercharged August 28, 2012 Share August 28, 2012 Went thru with DRL (Exposed) + on/off switch for my Accord last year. No problems. Not too sure if the Philips brand helped.... I guess this can be abit heng suay type of inspection.... means urs is working but u switched off during inspection? Link to post Share on other sites More sharing options...
Kwanheng 1st Gear August 28, 2012 Share August 28, 2012 (edited) but if tell them faulty, they could say y don't i uninstall rite? or u or ur fren actually tried before n it ok w them? which centre? btw, mine was self-installed, followed manual one. no light = drl on; light = drl off, although i could just remove +ive connector n tape up to ensure always in off state. but for drl attached to my grille - need to remove or cover (like spot light requirement i read fr l-t-a webby)? i think if inspector wants, he could treat it that way i heard rite? just make sure drl not working be it with light or no light. and your master switch is concealed cause ideal is to let them know its not working. if they as why never uninstall ( tell them: you don't even know what is that, it does not do anything ) i go STA at sing ming. Edited August 28, 2012 by Kwanheng Link to post Share on other sites More sharing options...
Cedricchoo Neutral Newbie August 29, 2012 Share August 29, 2012 means urs is working but u switched off during inspection? Yes Bro. Kah motor sent it in for me, and they switched it off while going thru inspection. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged August 30, 2012 Share August 30, 2012 just make sure drl not working be it with light or no light. and your master switch is concealed cause ideal is to let them know its not working. if they as why never uninstall ( tell them: you don't even know what is that, it does not do anything ) i go STA at sing ming. thks Kwanheng. unfortunately, i'm 1st owner so cannot siam. i think i cover it first & disconnect +ive cable and see how it goes when the time comes or if there'd be other diff response subsequently in this thread. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged August 30, 2012 Share August 30, 2012 Yes Bro. Kah motor sent it in for me, and they switched it off while going thru inspection. tks Cedricchoo. Perhaps i oso can consider C&C send in for me. I didn't know AD provide such services Link to post Share on other sites More sharing options...
Fuelsaver Supercharged January 14, 2013 Share January 14, 2013 Just a quick chk - anyone got their drl approved by l t a? Link to post Share on other sites More sharing options...
Fuelsaver Supercharged January 16, 2013 Share January 16, 2013 Just a quick chk - anyone got their drl approved by l t a? No one do before? Link to post Share on other sites More sharing options...
Nightmare77 Neutral Newbie January 16, 2013 Share January 16, 2013 No one do before? I don't think LTA will approve unless the policy changes. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged January 16, 2013 Share January 16, 2013 I don't think LTA will approve unless the policy changes. If no way, then Bo Bian. Link to post Share on other sites More sharing options...
ER-3682 Twincharged January 16, 2013 Share January 16, 2013 If no way, then Bo Bian. Don't install is the best. Link to post Share on other sites More sharing options...
Nightmare77 Neutral Newbie January 17, 2013 Share January 17, 2013 Don't install is the best. or buy a car with a factory fitted DRL ↡ Advertisement Link to post Share on other sites More sharing options...
Running light for armed
