Honda-Fit Neutral Newbie October 29, 2010 Share October 29, 2010 How long can Spark Plugs last? Can any experience user give me a reliable answer... ↡ Advertisement Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 29, 2010 Share October 29, 2010 Refer to here: http://www.mycarforum.com/index.php?showto...2654912&hl= Comes with photos and spark plug gap taken as proof. Easily 30,000 ~ 40,000 km for the copper plugs on my car. Link to post Share on other sites More sharing options...
Fresh Clutched October 29, 2010 Share October 29, 2010 yup, changed my copper ones at 50k. Link to post Share on other sites More sharing options...
Honda-Fit Neutral Newbie October 29, 2010 Author Share October 29, 2010 On 10/29/2010 at 1:35 PM, Octopus said: Refer to here: http://www.mycarforum.com/index.php?showto...2654912&hl= Comes with photos and spark plug gap taken as proof. Easily 30,000 ~ 40,000 km for the copper plugs on my car. Bro, im using OWS spark plugs.. should the spark plugs last longer than normal ones? Link to post Share on other sites More sharing options...
Furrynadz 5th Gear October 29, 2010 Share October 29, 2010 no definite answer good plugs can have bad apples good plugs can be spoilt by lousy fuel eg constant truly asia fuel lousy plugs can last long if used in the ideal conditions end of day, play safe check every 20k, or at most 40k Link to post Share on other sites More sharing options...
Keromond 1st Gear October 29, 2010 Share October 29, 2010 On 10/29/2010 at 3:59 PM, Furrynadz said: no definite answer good plugs can have bad apples good plugs can be spoilt by lousy fuel eg constant truly asia fuel lousy plugs can last long if used in the ideal conditions end of day, play safe check every 20k, or at most 40k so Truely asia fuel so bad ar? Even for Vpower racing>? Link to post Share on other sites More sharing options...
Happily1986 5th Gear October 29, 2010 Share October 29, 2010 anyone care to share symptoms and/or tell tale signs of worn spark plugs? Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear October 29, 2010 Share October 29, 2010 On 10/29/2010 at 1:24 PM, Honda-Fit said: How long can Spark Plugs last? Can any experience user give me a reliable answer... Examined those copper electrodes spark plugs on my previous Kelisa after 50k km to be in order. Re-installed them since no sign of wear for replacement Link to post Share on other sites More sharing options...
Mini-itx2010 Neutral Newbie October 30, 2010 Share October 30, 2010 On 10/29/2010 at 4:56 PM, Happily1986 said: anyone care to share symptoms and/or tell tale signs of worn spark plugs? You will get misfiring. Once you get that, it means your gap is too big already. Need to regap the plugs provide the center and grounding electrode still in good shape. Link to post Share on other sites More sharing options...
Forte3737 5th Gear October 30, 2010 Share October 30, 2010 On 10/29/2010 at 1:24 PM, Honda-Fit said: How long can Spark Plugs last? Can any experience user give me a reliable answer... what type of plugs are you using? Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 30, 2010 Share October 30, 2010 On 10/29/2010 at 2:55 PM, Honda-Fit said: Bro, im using OWS spark plugs.. should the spark plugs last longer than normal ones? I'm not familiar with OWS plugs, so no comment. Spark plugs life depend on the particular engine type, how it is driven and any modification made. Better to check the condition yourself to judge how long it can last, visual inspection and measurement of the gap by feeler gauge. Link to post Share on other sites More sharing options...
Ckchong8 1st Gear October 30, 2010 Share October 30, 2010 OWS iridium according to my WS need to change at 20K. Last used NGK iridium for 45K I keep as wear not so much. Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear October 30, 2010 Share October 30, 2010 what are the sign of misfiring? ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
Tool to change Spark Plug
Avatar : The Last Airbender
Spark Car Care
Spark Car Care
Kenny Rogers Roasters will serve its last meal on Apr 14
Aftermarket vs. OEM Spark Plug Wires
How long can engine oil be stored?
Replace spark plugs
Replace spark plugs
